Bluescreen intempestif, help!
Voila 2 jours consecutifs que mon ordi crash, je le demarre, vas sur internet, crash! redémarrage, attente, vas sur internet, crash...
J'ai telecharger whocrashed
est voici le resultat:
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 24/03/2015 05:51:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-43493-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8004B6A1D8, 0xB6000000, 0x10015)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
On Tue 24/03/2015 05:42:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-33805-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80047A0038, 0xB6000000, 0x10015)
On Mon 23/03/2015 05:50:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032315-45926-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80047AC1D8, 0xB6000000, 0x10015)
On Mon 23/03/2015 05:46:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032315-39717-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800488B1D8, 0xB6000000, 0x10015)
Quelqu'un pour m'aider svp??
  1. :/ est si je télécharge anticrash, ça peut aider ou non?
      je ne pense pas.
    2. ok! ben merci quand meme! ;)
  2. Merci d'avoir repondu! et comment je peut réparer ça alors???
      Vois avec un magasin d'informatique.
  3. Modérateur
    Problème matériel :
    Plus d'infos sur les écrans bleus : https://forum.malekal.com/viewtopic.php?t=47660&start=
