[PROBLEME] PerWorldPlugins disfonctionnement
Je viens de télécharger le plugin PerWorldPlugins qui permet de séparer les plugins des mondes
mais voilà , une fois installé , (je n'ai donc pas touché à la config ) lorsque je vais sur mon serveur je ne peut plus utiliser de commandes , sauf celles du Craftbukkit
voici la config :
# This Config Controls what plugins work on certain worlds.
# Example
# limit:
# WorldEdit:
# - world
# - world_nether
# Essentials: []
# This will make it so worldedit will only work in world & world_nether, meaning in the end it is not usable.
# When there is no worlds in the list it will allow it for any worlds, in this example allowing all worlds.
# Whenever a plugin is added, this config will automatically add it!
# exempt-login-events is for excluding login events when true, this means if a plugin uses PlayerLogin it will allow it for any world. We advise this to be enabled!
# blocked-msg is the string displayed to a client when a command is blocked
# check-for-updates is the controller for if updates should be alerted to the users with the permissions/op.
exempt-login-events: true
check-for-updates: true
blocked-msg: '&c[Error] This command cannot be performed in this world.'
limit:
GroupManager: []
Anti Enderman: []
WorldEdit: []
TM: []
mcore: []
Vault: []
PlotMe: []
JSONAPI: []
Multiverse-Core: []
Easy Pvp Kits: []
WorldGuard: []
Command iConomy: []
AutoMessage: []
NoEnderChest: []
iConomy: []
Minigames: []
SurvivalGames: []
CombatTagInstakill: []
Lockette: []
MobArena: []
Essentials: []
BowWarfare: []
Jobs: []
Citizens: []
ServerSigns: []
EssentialsSpawn: []
SpotVip: []
CreativeGates: []
HeavySpleef: []
BlockHat: []
SignShop: []
CasinoSlots: []
ChestShop: []
EssentialsChat: []
Factions: []
CreeperHeal: []
Sentry: []
AntiCheat: []
merci d'avance
marcosdu98
  1. Essaye d'en rajouter un.
    Sinon, tu peux toujours contacter le créateur du plugin.
    Ça peut aussi être le plugin qui ne supporte pas les autres.
    1. je ne comprend pas bien ce que tu veut dire !
      tu pense donc que le plugin ne m'autorise pas à utiliser les commandes d'essential car il manque des mondes alors que tout les plugins sont sur [] donc appliqué sur tout les mondes ?
      1. # Cette configuration Controls ce plugins fonctionnent sur ??certains mondes.
        # Exemple
        # Limite:
        # WorldEdit:
        # - Monde
        # - World_nether
        # Essentials: []
        # Il sera donc worldedit ne fonctionne que dans le monde et world_nether, ce qui signifie en fin de compte, il n'est pas utilisable.
        # Quand il n'ya pas de mondes dans la liste, il permettra pour tous les mondes, dans cet exemple permettant à tous les mondes.
        # Quand un plugin est ajouté, cette config ajoute automatiquement!
        # Exonérés d'identification manifestations est d'exclure les événements de connexion lorsque vrai, cela signifie que si un plugin utilise playerlogin il lui permettra de tout monde. Nous conseillons ce doit être activé!
        # Bloqué-msg est la chaîne affichée à un client quand une commande est bloqué
        # Check-pour-jour est le contrôleur car si les mises à jour devraient être sensibilisés aux utilisateurs avec les autorisations / op.
        exonéré d'identification-événements: true
        check-pour-jour: true
        bloqué-msg: '& c [Error] Cette commande ne peut être exécutée dans ce monde. "
        _________________________________________________________________
        D'après ce "texte", ça dit qu'il manque des mondes .
        Après, à toi de voir .
        Chicken <3
