USB connection issue with Alpine car radio
Solved
mimiquagh
jp -
jp -
Hello,
We recently purchased an Alpine CDE-9880 Series car radio that allows us to connect a USB key or an iPod. We have 2 USB keys, one with 2GB that also plays MP3s and another with 4GB that I just bought. The MP3 key works perfectly on the car radio, but the new 4GB key doesn't work at all. Why? What should we do?
- 1
- 2
Next
Hello everyone, the requirements are as follows:
You need a USB drive formatted in FAT 32 (for those who want to use a hard drive, I recommend a self-powered one, meaning a hard drive that powers itself through the USB port; in other words, the device will power it, which avoids potential power supply issues)
The second condition is that you must put a maximum of 99 files (tracks) in a folder; otherwise, the device will have trouble loading the tracks (cache issue)
A third condition for those using a hard drive is that some car stereos do not support 250 GB, while others do, so it's up to you to find out what size the device can handle.
- 1
- 2
Next
