Liens connexes:
- How to connect Under Control multi-gaming wireless controller to PS3 and Switch
- Bug controllers Under Control / Switch
- Unable to start the PS4
- I can't connect my Under Control controller that's only compatible with the Switch.
- PS4 Dualshock controller disconnecting on its own
- I can't connect my Under Control controller to PS4.
Yo, same here, I synced my two PS4 controllers to my Android and now it's a disaster on my PS4: disconnecting controllers, sticks moving on their own, latency with the buttons.
I’ve tried every tutorial online: resetting the controller with the console off using the button at the back accessed with a toothpick, resyncing the controller via USB cable to the console.
Nothing works, it's bugging... It has to be related to my syncs on Android because I did it yesterday, and it hasn't worked since on my PS4...
What happens when you connect your controller to your smartphone is that the controller registers this device by default, so even in airplane mode, when you try to turn on your controller, you'll receive a Bluetooth notification on your phone.
What you need to do is turn off the phone in question and have two PS4 controllers available.
Go to PS4 settings, devices, Bluetooth devices, press the PS+Share button until the controller starts flashing, and connect the problematic controller with a USB cable while it keeps flashing white. If it doesn't work right away, press again with the cable connected.
Then you will see a new DualShock appear, your controller will no longer have a white light but a red light, and you won’t be able to use it right away.
This is where you take your second controller, press on the new DualShock that just appeared on the screen, and register the device, and magically it switches to the home screen with the first controller.
