How to connect Under Control multi-gaming wireless controller to PS3 and Switch
zigguy1503
Posted messages
9
Status
Member
mali -
mali -
Hello,
I just bought a new controller at Leclerc, Ref. S/N-2926-0001/0718 compatible with the two consoles mentioned above + PC, and I'm having trouble; it looks like Nintendo NES controllers but is also designed for the Switch. It comes with a USB charger, but I didn’t receive any manual with the purchase?! It has the same buttons + reset, but I don’t know which ones correspond to start and select? I bought this one because it’s multi-gaming, but I should have purchased a pro controller because I’m struggling since then!!!
When I turn on the PS3, the second light comes on when I press the home button, but nothing happens. I’ve turned off the console, connected the USB cable and pressed reset, but nothing changes… it’s not recognized!
Help, please!!!
Thank you in advance for guiding me and especially for making my son happy who no longer has a functioning controller
If any of you also use it on the Switch, please let me know the connection steps
Configuration: Windows / Chrome 75.0.3770.142
Help, please!!!
