Problem writing in OpenOffice Writer
Solved/Closed
kesan Posted messages 4 Status Membre -
 Rowana -
Hello everyone,
I am currently writing a text in Writer and I don't know why, suddenly when I type new characters in a sentence, the following ones get deleted.
In fact, the new characters are replacing the old ones.
I know it's a trivial issue, probably due to some misstep on my part, but I can't find any solutions...
Thanks in advance for your help!!
see you later
Configuration: Windows Vista Firefox 3.0.10
Nera
Press "Insert" to see... (on your keyboard, I specify...)
19
Rowana
THANK YOU very much
Anonymous user
Hi,
This often happens to me!!! I only know one solution that works. Make sure to save your text, close Open Office, and when you reopen it, the letters won’t disappear as you type.
It has to do with corrections... but I don't know more than that :)
__________________________________________________________________________
I oppose violence because when it seems to produce good,
the good that results is only temporary, while the harm done is permanent.
°º¤ø,¸(Marie-Josée) °º¤ø,¸
3
OOoForum Posted messages 3871 Registration date   Status Membre Last intervention   964
>These are bugs
Thank you for stopping the nonsense.
This is because you are in Replace mode and not Insert mode. Look in help F1 to see what I’m talking about.
<signature>Why hack MS-Office when there is a free solution?
Use OpenOffice.org</signature>
2
Anonymous user
Listen, give the solution!
I tell him how to fix it for now. When I have a job to do, and it happens to me, I do it like this. It was to help, and if you have the solution, give it to him instead of criticizing others.
Because I don't understand your bug explanation! OooOOoooOO
Have a good evening
I oppose violence because when it seems to bring about good, the good that results is only temporary, while the harm produced is permanent.
Anonymous user
OH REALLY?! THEN WHY DOES IT WORK IN THE INTERNET BROWSER?! AND IN FLASH PLAYER??!!! HUH?! HUH?! Why?!
So stop saying that I'm talking nonsense!!!
Anonymous user > Anonymous user
I was talking to the ooOOOooo forum, not to you.
The Kesan problem is solved.....and thanks also for the information Oooforum! :)
Because now I too will know what to do, rather than closing and reopening my text!
I oppose violence because when it seems to produce good, the resulting good is only temporary, while the evil produced is permanent.
ok thank you oooforum, problem solved!!
actually you just need to press the insert key to switch from insert mode to overwrite mode, it's that simple!!
Thanks again : )
vivine
Thank you so much, I'm struggling with my students!!!
Anonymous user
It's bugs, in all computers and in all word processing software, even in Windows Mail or Live Mail, even when you're writing something on the NET, it does that!
Best regards ;)
Anonymous user
Set the topic to Resolved!
