How to charge a laptop via USB?
Solved
nour eddine
Utilisateur anonyme -
Hello,
I would like to know if it is possible to power a laptop through a USB port
I mean, instead of using the plug on the laptop, I connect the adapter (charger) to a USB port on the laptop
Some time ago, I had an issue with the socket on the laptop (HP Pavilion zv 5000); the adapter plug didn't fit well into the female socket on the laptop (the one attached to the motherboard), but it was not getting power. I repaired it and it worked for 3 weeks, then the same problem happened again
So I'm wondering if I can power my laptop through a USB port (feed power through the USB port) to avoid having the same issue again
ThanksConfiguration: Windows Vista
Related links:
- Keyboard locked: what to do?
- My PC starts up correctly but my screen won't turn on: what should I do?
- My PC keyboard is not working anymore! Where does the problem come from?
- Turning on a PC without a power button.
- My computer can't find my Wi-Fi. What should I do?
- Locked keyboard: how to unlock it?
Nothing on the laptop recognizes the USBs as "electricity in" but only as "out," except on recent Macs with USB-C, so no, you won't be able to...
EDIT: However, there are external batteries that can charge laptops: https://www.amazon.fr/MAXOAK-50000mAh-capacit%C3%A9-Batterie-ordinateur/dp/B00YP823NA
Best wishes to everyone!
You shouldn't treat people like fools,
But you must never forget that they are.
But manufacturers should think about this, it's very practical, I find that only one universal charger for all phones is simple, but I think their financial interest doesn't align with that
Thanks again
But indeed their financial interest lies elsewhere, even if some are trying USB products.
Best wishes to all!
We must not treat people like fools,
But we must never forget that they are.
