Problème concection erreur sur database.php
j'ai un problème j'ai récupéré ma base de données mais j'ai un problème de connection lorsque je veux voir mon site en ligen erreur sur la ligne 51 voir ci dessous
Parse error: syntax error, unexpected ')' in /homez.92/sohoo/www/includes/functions/database.php on line 51( mise en gras)
<?php
function tep_db_connect($server = DB_SERVER, $username = DB_SERVER_USERNAME, $password = DB_SERVER_PASSWORD, $database = DB_DATABASE, $link = 'db_link') {
global $$link;
if (USE_PCONNECT == 'true') {
$$link = mysq_pconnect($server, $username, $password);
} else {
$$link = mysq_connect($server, $username, $password);
if ($$link) mysq_select_db($database);
return $$link;
function tep_db_close($link = 'db_link') {
global $$link;
return mysq_close($$link);
function tep_db_error($query, $errno, $error) {
die('<font color="#000000"><b>' . $errno . ' - ' . $error . '<br><br>' . $query . '<br><br><small><font color="#ff0000">[TEP STOP]</font></small><br><br></b></font>');
function tep_db_query($query, $link = 'db_link') {
global $$link;
if (defined('STORE_DB_TRANSACTIONS') && (STORE_DB_TRANSACTIONS == 'true')) {
error_log('QUERY ' . $query . "\n", 3, STORE_PAGE_PARSE_TIME_LOG);
$result = mysql_query($query, $$link) or tep_db_error($query, mysql_errno(), mysql_error());
$result_error = mysql_error();
error_log('RESULT ' . $result . ' ' . $result_error . "\n", 3, STORE_PAGE_PARSE_TIME_LOG);
return $result;
function tep_db_perform($table, $data, $action = 'insert', $parameters = '', $link = 'db_link') {
reset($data);
if ($action == 'insert') {
$query = 'insert into ' . $table . ' (';
while (list($columns, ) = each($data)) {
$query .= $columns .';
$query = substr($query, 0, -2) . ') values (';
reset($data);
while (list(, $value) = each($data)) {
switch ((string)$value) {
case 'now()':
$query .= 'now(), ';
break;
case 'null':
$query .= 'null, ';
break;
default:
$query .= '\'' . tep_db_input($value) . '\ ';
break;
$query = substr($query, 0, -2) . ')';
} elseif ($action == 'update') {
$query = 'update ' . $table . ' set ';
while (list($columns, $value) = each($data)) {
case 'now()':
$query .= $columns . ' = now(), ';
break;
case 'null':
$query .= $columns .= ' = null, ';
break;
default:
$query .= $columns . ' = \'' . tep_db_input($value) . '\ ';
break;
$query = substr($query, 0, -2) . ' where ' . $parameters;
return tep_db_query($query, $link);
function tep_db_fetch_array($db_query) {
return mysql_fetch_array($db_query, MYSQL_ASSOC);
function tep_db_num_rows($db_query) {
return mysql_num_rows($db_query);
function tep_db_data_seek($db_query, $row_number) {
return mysql_data_seek($db_query, $row_number);
function tep_db_insert_id() {
return mysql_insert_id();
function tep_db_free_result($db_query) {
return mysql_free_result($db_query);
function tep_db_fetch_fields($db_query) {
return mysql_fetch_field($db_query);
function tep_db_output($string) {
return htmlspecialchars($string);
function tep_db_input($string) {
return addslashes($string);
function tep_db_prepare_input($string) {
if (is_string($string)) {
return trim(tep_sanitize_string(stripslashes($string)));
} elseif (is_array($string)) {
reset($string);
while (list($key, $value) = each($string)) {
$string[$key] = tep_db_prepare_input($value);
return $string;
} else {
return $string;
  1. Bonsoir,
    ton erreur est enfait ligne 49
    $query .= $columns ;
    ensuite je ne comprend pas trop tu concatène $query.= et d'autres fois pas ?
    pourquoi mets tu $$link ?
    1. Merci pour ta réponse , en fait j'ai récupéré ma base de donnée de mon site ansi que le site par lui même aupres de mon fournisseur, donc ce sont les données de l'ancien site en PHP qui se trouve dans database.php
    2. le mieux je crois qu'il va falloir que je recrée un fichier complet php pour acceder à mon site mais le je crois que je vais planter
