Help urgent javascript svp !!!
bonjour je suis debutant en la matiere et j'aurais voulu savoir comment je pouvait inserer du code javascript dans du php.
voici donc mon code :
var NoOffFirstLineMenus=3;
var FontHighColor="white";
var BorderColor="#aaaacc";
var BorderWidthMain=1;
var BorderWidthSub=1;
var BorderBtwnMain=1;
var BorderBtwnSub=1;
var FontFamily="Arial";
var FontSize=9;
var MenuTextCentered="left";
var MenuCentered="left";
var MenuVerticalCentered="top";
var ChildOverlap=.2;
var ChildVerticalOverlap=.2;
var LeftPaddng=3;
var TopPaddng=2;
var FirstLineHorizontal=1;
var TakeOverBgColor=1;
var MenuWrap=1;
var BaseHref=document.location.href.substring(0,document.location.href.lastIndexOf("/") +1);
var Arrws=[BaseHref+"tri.gif",5,10,BaseHref+"tridown.gif",10,5,BaseHref+"trileft.gif",5,10,BaseHref+"triup.gif",10,5];
var PartOfWindow=1;
var BuildOnDemand=1;
function BeforeStart(){return}
function AfterBuild(){return}
function BeforeFirstOpen(){return}
function AfterCloseAll(){return}
Menu1=new Array("Fichier","MyFile.htm","",2,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu1_1=new Array("Nouveau","MyFile.htm","",2,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu1_1_1=new Array("Personne","v_ajout_contact","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu1_1_2=new Array("Societe","v_ajout_contact_societe","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu1_2=new Array("Fermer","index.php","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu2=new Array("Edition","MyFile.htm","",3,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu2_1=new Array("Menu","MyFile.htm","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu2_2=new Array("Menu","MyFile.htm","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu2_3=new Array("Menu","MyFile.htm","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu3=new Array("Menu","MyFile.htm","",2,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu3_1=new Array("Menu","MyFile.htm","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
Menu3_2=new Array("Menu","MyFile.htm","",0,20,120,"#ffffff","","#000000","","","",-1,-1,-1,"","");
voila ce code est sensé faire un menu dynamique et j'aimerai l'incorporé dans ma page php.
si quelqu'un a la solution ou des idées merci de m'aider svp...
var FontSize=9;
var LeftPaddng=3;
var TopPaddng=2;
var MenuWrap=1;
var PartOfWindow=1;
svp!!!
A priori ce script a été récupéré sur des sites intégrant des menus, le document que tu donnes est juste la déclaration de l'arborescence, il faut donc rajouter le reste (ce doc est un include dans un autre code) donc il faut aussi rajouter dans le document maitre, par exemple tant qu'a pomper, prends aussi le code maitre dans http://www.meekashire.wa.gov.au
Irem -
et tu sais ce qui faut mettre au niveau de la partie a afficher par hasard ? pour appeler ce code ?
peux tu en dire plus sur ton erreur ?
le comme le dit Irem, il suffit d'inclure le code javascript en dehors des balises PHP ( <?php ou <? et ?> pour info)
Il est normal que ton code javascript ne t'indique rien, il ne comporte que des déclarations, le code était probablement en deux parties,
celle que tu as indiqué doit se situer entre les balises HTML <head> et </head>
une autre partie doit se situer à l'endroit ou le menu doit être affiché. -
help!!! svp
non desole ca marche pas et au fait je n'ait pas de phph , ce n'est que du html . le probleme ne viendrait- il pas du code car j'ai fait comme vous m'avez dit c'est a dire :
<script language="javascript">
mon code javascript que je vous ai fait voir plus dans la page
</script>
et en fait il ne m'affiche rien sur la page..? -
simple vous ecrivez le php entre des balises <?php> </php> et le javascript comme d'habitude dans le html cela donne par exemple
<?php>
mon code serveur</php>
<html>
mon script javascript
<?php> mon code php dans le script</php>
</script>
bla bla bla
<?php>mon code php dans la page</php>
</html>
Irem
