TV and TNT decoder power on
PAPOU 2 Posted messages 88 Status Member -
Hello,
When turning on the TV and the TNT decoder (both are plugged into a power strip with a switch), the light on the decoder is green, but the picture on the TV only appears after a few minutes, or not at all. During these few minutes, the TV screen is full of static. I should mention that this is an old TV, but the decoder is new.
If anyone has any ideas, I'd be grateful. Thank you in advance for your responses.
Anonymous user
Check that your decoder is correctly set to TV mode, meaning it "takes over" automatically through the scart, otherwise, as mentioned above, you switch manually to AV or EXT depending on the brand of the TV.
5
PAPOU 2 Posted messages 88 Status Member 8
So no interest in my problem?
2
123456@ Posted messages 457 Registration date   Status Member Last intervention   86
perfectly
so:
you turn on your decoder
you look behind the TV where the decoder cable is connected (peritel: ext1/AV1-ex2/AV2...)
then on the TV remote you press AV (or source or the icon of a screen with an arrow coming out)
normally it works
First of all, thank you for your replies, but even turning on the decoder a few minutes before the TV, it's the same.
However, I don't know how to check if my decoder is in TV mode.
Sorry, but I'm not an expert.
Anonymous user
On the other hand, I don't know how to check if my decoder is in TV mode.
There's often a button on the remote, otherwise nothing beats reading the manual!!
Unfortunately, the manual doesn't tell me much.
However, I just discovered, thanks to you, that there is indeed a TV button on the remote, but after pressing this button, with the TV on, of course, nothing happens. I should mention that this button is labeled: TV/Radio.
ce bouton sert à passer des chaînes TV aux chaînes de la RADIO
Anonymous user
TV/Radio it's obviously not that one!!, marked AV, TV, a rectangle with an arrow, well, each manufacturer does as they please...........
The TV is old and the remote control is too. Is it possible that there is no AV or EXT button on the remote? Or am I that much of an IDIOT?
Anyway, thank you for your patience.
Anonymous user
I have an old Grundig that's nearly 20 years old (yes, really!) and there is an AV button (the same one as "0").
press AV1 (or 2, depending on where you plugged in your decoder) the decoder is a TNT HD decoder, so it takes about 30 seconds to turn on ;)
The problem: there is only one SCART port at the back of the TV. It's an old TV.
so you directly press av or ext on the remote control
Anonymous user
so you press directly on av or ext on the remote of the TV
Yes...
Anonymous user
I would like to clarify because I was talking earlier about the same button on the set-top box.
yes ;)
There is indeed a button with a rectangle and an arrow that you mentioned earlier. Could it be that one? After trying, this button has no action on the TV?
Anonymous user
rectangle with arrow on the TV remote is indeed the external switch (scart)
its press should switch directly to the DTT !!
The remote control button is unresponsive.
However, on the TV, there is a program button that leads to: EXTERNAL: AV or SVideo?
Anonymous user
So 2 external inputs!!!
You might have to press the remote several times to get to the right input.
Well, the problem is not solved tonight, but the night brings counsel, tomorrow may bring the solution???.
Thanks to those who responded and see you tomorrow.
