[SQL] requête : obtenir le total
sous le code suivant, j'aimerais obtenir le total genre SUM(Stock.Quantity), mais j'obtiens une erreur si je le fait.. quelqu'un peut-il me dire quoi mettre ? Merci d'avance !
include ("connexion_stock.php");
<html>
<head>
</head>
<body>
$sqlconnect=odbc_connect($dsn,$username,$password);
$sqlquery="SELECT Products.ProductName, Products.ProductDesc, Products.type, Stock.Quality FROM Products, Stock where Products.ProductName=Stock.ProductName and Products.Type <> 'S'
Group by Products.ProductName, Products.ProductDesc, Products.type, Stock.Quality order by Products.ProductName, Products.Type;" or die (mysql_error());
$process=odbc_exec($sqlconnect, $sqlquery);
<html>
<head>
<title>Etat du Stock</title>
<link href="../resolutions/style.css" rel="stylesheet" type="text/css">
</head>
<body>
<p align="center"><b><font face="Arial" size="5">Eurosource Stock Report</font></b></p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<table width="90%" border="0" align="center" cellpadding="1" cellspacing="1">
  <tr class="tab04">
    <td>
      <div align="center">ProductName</div></td>
    <td>
      <div align="center">ProductDesc</div></td>
    <td>
      <div align="center">Quality</div></td>
    <td>
      <div align="center">Quantity</div></td>
    <td>
      <div align="center">Type</div></td>
  </tr>
  <?php while(odbc_fetch_row($process)){ $ProductName = odbc_result($process,"ProductName"); $ProductDesc = odbc_result($process,"ProductDesc"); $Type = odbc_result($process,"Type"); $Quality = odbc_result($process,"Quality");   ?>
  <tr class="tab05">
    <td><?php  echo $ProductName ; ?></td>
    <td><?php  echo $ProductDesc ; ?></td>
    <td><div align="center"><?php  echo $Quality ; ?></div></td>
    <td><div align="center"></div></td>
    <td><div align="center"><?php  echo $Type ; ?></div></td>
  </tr><?php }odbc_close($sqlconnect); ?>
</table>
</body>
</html>
</body>
</html>
Cordialement,
Riwalenn
  1. selon la norme SQL92, ta requète devrait s'écrire ainsi:
    SELECT Products.ProductName, Products.ProductDesc, Products.type, Stock.Quality, sum(stock.quantity) FROM Products, Stock where Products.ProductName=Stock.ProductName and Products.Type <> 'S'
    en bref, tu as oublié ton champ d'agrégation (le SUM) ; alors sur quoi veux-tu que ton moteur SQL fasse un regroupement (le group by) ?
    si possible, préfères une clause JOIN à une clause WHERE, elle sera plus rapide à l'exécution
    1. bonjour,
      si je fais ce que tu me dis (chose que j'avais déjà essayé, c'est d'ailleurs pour ça que je demande de l'aide)
      $sqlquery="SELECT Products.ProductName, Products.ProductDesc, Products.type, Stock.Quality, SUM(Stock.Quantity)
      Group by Products.ProductName, Products.ProductDesc, Products.type, Stock.Quality, Stock.Quantity
      order by Products.ProductName, Products.Type ;" or die (mysql_error());
      en rajoutant donc le code suivant :
      <?php while(odbc_fetch_row($process)){ $ProductName = odbc_result($process,"ProductName"); $ProductDesc = odbc_result($process,"ProductDesc"); $Type = odbc_result($process,"Type"); $Quality = odbc_result($process,"Quality"); $Quantity = odbc_result($process,"Quantity");  ?>
        <tr class="tab05">
          <td><div align="center"><?php  echo $Quantity ; ?></div></td>
      j'ai l'erreur suivante :
      Warning: odbc_result(): Field Quantity not found in c:\program files\easyphp1-8\www\eurosource-intranet\references\print_stock.php on line 43
      la ligne 43 étant :
      Merci de m'aider SVP...
      1. Salut ! l'erreur vient de ta requête :
        Enlève "Stock.Quantity" du group by.
        Tu dois faire un group by sur tous les autres champs, mais pas sur le champ aggrégé.
        Essayes de tester ta requête, ça devrait passer beaucoup mieux :)
        1. merci merci beaucoup :))) c'est bon j'ai enfin ce que je veux lol
