Problème phpmyadmin svp !
Problème phpmyadmin
J'ais installé phpmyadmin mais je n'arrive pas à accèder à la page d'acceuil afin de créer des bases de données. Pour cela il faut configurer correctement le fichier config.inc.php
Pouvez-vous m'aider ?
J'ais le message suivant #1045 Connexion au serveur MySQL non permise
voici le contenu du fichier en question :
<?php
* Debian local configuration file
* This file overrides the settings made by phpMyAdmin interactive setup
* utility.
* For example configuration see /usr/share/doc/phpmyadmin/examples/config.default.php.gz
* NOTE: do not add security sensitive data to this file (like passwords)
* unless you really know what you're doing. If you do, any user that can
* run PHP or CGI on your webserver will be able to read them. If you still
* want to do this, make sure to properly secure the access to this file
* (also on the filesystem level).
* Server(s) configuration
$i = 0;
// The $cfg['Servers'] array starts with $cfg['Servers'][1]. Do not use $cfg['Servers'][0].
// You can disable a server config entry by setting host to ''.
$i++;
* Read configuration from dbconfig-common
* You can regenerate it using: dpkg-reconfigure -plow phpmyadmin
if (is_readable('/etc/phpmyadmin/config-db.php')) {
require('/etc/phpmyadmin/config-db.php');
/* Configure according to dbconfig-common if enabled */
if (!empty($dbname)) {
/* Authentication type */
$cfg['Servers'][$i]['auth_type'] = 'config';
/* Server parameters */
if (empty($dbserver)) $dbserver = 'localhost';
$cfg['Servers'][$i]['host'] = $dbserver;
if (!empty($dbport)) {
$cfg['Servers'][$i]['connect_type'] = 'tcp';
$cfg['Servers'][$i]['port'] = $dbport;
//$cfg['Servers'][$i]['compress'] = false;
/* Select mysqli if your server has it */
$cfg['Servers'][$i]['extension'] = 'mysqli';
/* Optional: User for advanced features */
$cfg['Servers'][$i]['controluser'] = $dbuser;
$cfg['Servers'][$i]['controlpass'] = $dbpass;
/* Optional: Advanced phpMyAdmin features */
$cfg['Servers'][$i]['pmadb'] = $dbname;
$cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark';
$cfg['Servers'][$i]['relation'] = 'pma_relation';
$cfg['Servers'][$i]['table_info'] = 'pma_table_info';
$cfg['Servers'][$i]['table_coords'] = 'pma_table_coords';
$cfg['Servers'][$i]['pdf_pages'] = 'pma_pdf_pages';
$cfg['Servers'][$i]['column_info'] = 'pma_column_info';
$cfg['Servers'][$i]['history'] = 'pma_history';
$cfg['Servers'][$i]['designer_coords'] = 'pma_designer_coords';
/* Uncomment the following to enable logging in to passwordless accounts,
* after taking note of the associated security risks. */
// $cfg['Servers'][$i]['AllowNoPassword'] = TRUE;
/* Advance to next server for rest of config */
$i++;
$cfg['Servers'][$i]['auth_type'] = 'cookie';
$cfg['Servers'][$i]['host'] = 'localhost';
//$cfg['Servers'][$i]['connect_type'] = 'tcp';
//$cfg['Servers'][$i]['extension'] = 'mysql';
// $cfg['Servers'][$i]['controluser'] = 'pma';
//$cfg['Servers'][$i]['controlpass'] = 'pmapass';
// $cfg['Servers'][$i]['pmadb'] = 'phpmyadmin';
// $cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark';
// $cfg['Servers'][$i]['relation'] = 'pma_relation';
// $cfg['Servers'][$i]['table_info'] = 'pma_table_info';
// $cfg['Servers'][$i]['table_coords'] = 'pma_table_coords';
// $cfg['Servers'][$i]['pdf_pages'] = 'pma_pdf_pages';
// $cfg['Servers'][$i]['column_info'] = 'pma_column_info';
// $cfg['Servers'][$i]['history'] = 'pma_history';
// $cfg['Servers'][$i]['designer_coords'] = 'pma_designer_coords';
/*Uncomment the following to enable logging in to passwordless accounts,
* End of servers configuration
* Directories for saving/loading files from server
$cfg['UploadDir'] = '';
$cfg['SaveDir'] = '';
<?php
* utility.
$i = 0;
$i++;
$i++;
Ton message dit que le compte avec lequel tu te log n'a pas accès aux BDD.
tu te log avec root ? -
Oui en effet, comment doit je faire pour changer le login ? STP merci
tu as dû mal répondre aux question en installatn phpmyadmin.
le plus simple serait de le réinstaller je pense.
tu as bien un serveur MySQL d'installé ? -
Ok, j'ais bien My SQL, et je pense que la commande pour désinstaller phpmyadmin c'est : sudo rm phpmyadmin
apt-get remove phpmyadmin
Puis réinstallation...
apt-get install phpmyadmin
J'ais le message qui suit :
dbconfig-common: writing config to /etc/dbconfig-common/phpmyadmin.conf
Replacing config file /etc/phpmyadmin/config-db.php with new version
* Reloading web server config apache2 apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
Dans /etc/phpmyadmin j'ais toujours le même fichier de config, est ce que je doit tout supprimmer le dossier phpmyadmin aussi ?
Méthode bourrin ?
faire un
chmod -vR 777 phpmyadmin
déplacer tous les éléments vers la dustbin -
Essa&ie de réinstaller phpmyadmin.
quand il te demande les logs d'accès a la base de donnée, n'oublie pas de lui donner un compte qui a accès à tout.
le second mot de passe qu'i te demande c'est celui avec lequel tu veux te logger
ModérateurSalut,
Si tu as installé phpmyadmin avec apt-get alors tu n'as rien à configurer dans config.inc.php
Il faudra d'abord voir si tu arrives à te connecter à mysql
Affiche le résultat de la commande
mysql -u root -p
Si tu n'as pas mis le mot de passe pour root alors tape sur ENTRER quand il te demande le mot de passe.
A savoir que root de mysql n'est pas le root du ton systèm, il est just l'utilisateur admin de ton serveur de base de données mysql
