Export issue on Sony Vegas Pro
Solved
momi
glandu Posted messages 25506 Registration date Status Contributor Last intervention -
Hello,
I did a video project on Sony Vegas Pro that lasts about 11 minutes. Before finishing the project, I tried to export it to make sure it worked and everything went fine. Now that it’s done, I’ve tried to export it in every possible format but nothing works. Every time I export it, it gives me a 3-minute video with just a black screen (that is to say, with no image and no sound). Do you have a solution or an explanation, please?????
Hello, if you haven't changed the export mode between the first attempt and the end of your project, there may have been an error: deletion or relocation of photo or video files on your hard drive that, as we say, polluted your project. Many people deny it, but for me it's the most common issue.
"Donkeys change their minds, not idiots."
Please remember to mark your message as "resolved" if that's the case.
Hello, knowing your software well so that it can search for the moved files and "missing file search" if you have an idea of which ones, that's the hardest part!! Otherwise, it's like looking for a needle in a haystack. A piece of advice in hindsight, unfortunately, is not to intervene in the folders necessary for your photo editing, music captures on your hard drive when you have an ongoing project. Don't leave too much time to finish a project; a single file moved or deleted and your project is "polluted."
"The donkeys change their minds, not the idiots."
Remember to mark your message as "resolved" if that's the case.
Best regards.
Morgane Bellot
