Problem 513 Front chassis fan not detected
Charlotte -
Ohmygodinesha Posted messages 1 Registration date   Status Member Last intervention   -
Hello,
I have a problem with my HP PC. When I turned it on this morning, I encountered a black screen with the message "Problem 513 Front chassis fan not detected."
By pressing F1, it turns on anyway, but I'm worried about damaging it if there's a fan issue... it makes quite a bit of noise... could it be due to dust or not at all? To the heat? (my desk is like an oven). I work on the computer, so I can't risk damaging it...
Thank you,
Charlotte
  1. Panth33ra Posted messages 23257 Registration date   Status Member Last intervention   Ambassador 2 368
    Hello,
    Do you have a fixed HP PC with a tower?
    The phrase "...Front chassis fan not detected" indicates that the front chassis fan is not working. Check that it is properly connected and spinning.
    ASUS ROG G752 VSK | QuadCore Intel i7 7700HQ | 32 GB-DDR4 | 2 SSD M.2 500 GB | 2 Seagate HDDs 2TB | GeForce GTX 1070M 8 GB | 17.3" Screen (120 Hz) | DirectX 12 | Windows 10 (x64)
    1. Charlotte
      Hello! Yes, that's right. Yes, my fans are running. This morning the message is no longer displaying... I don't know if it could be related to overheating, I downloaded Core Temp and the temperature could go up to https://forums.commentcamarche.net/forum/affich-37249132-probleme-513-front-chassis-fan-not-detected?utm_campaign=Mail+de+Service_&utm_medium=email&seen=2&utm_source=MagNews# just over 80 yesterday. I live under the roof so my office, when it's over 30 outside, is quite unbearable.
      Well, for now the problem seems to be resolved then...
  2. Ohmygodinesha Posted messages 1 Registration date   Status Member Last intervention
    I had the same problem and no solution anywhere!! But when I replaced the original CPU fan with an Arctic P8 Slim PWM PST, I no longer have "Front chassis fan not detected"!!!
