Wifi working but no internet access via ethernet cable
Chaco077
brupala Posted messages 111156 Registration date Status Member Last intervention -
Hello.
I am looking to connect a device that allows access to IPTV. It has worked before on the same network. Today, the ethernet connection is active but the internet is not available... I tried restarting the router and the mag but nothing changes...
Furthermore, we have internet access via wifi...
Is there something (simple ????) that can be done?
Thank you in advance for your help.
Chantal
Chantal
Hi,
does this device have an interface where you can see its settings and run tests like ping at least?
You don't have to mention the name of the device, but it would help a lot to know what's inside or not.
and ... There you go! -
Thank you for your response!
It's a mag322. We can access its settings...
But I believe it's not this device that's the issue because if I connect a laptop to the Ethernet cable, it doesn't have internet access either... ???? -
