HDMI problem: no signal on my TV.
Solved/Closed
canellecracotte
Dago -
Dago -
Hello,
I just bought a 1.5m HDMI cable to watch movies and series on my TV from my laptop, but the TV displays "no signal"!!! I have spent hours looking on several forums, I tried changing the resolutions, etc. Often, the problem for others is the opposite, the laptop not detecting the TV. What should I do?? I have an Acer with Vista and NVIDIA GeForce 9300 M GS and an LED LG TV, thank you for any help you can provide!
10 réponses
Hello,
I’m far from being an expert, but I think I’ve found the right menu and the solution.... Indeed, my Samsung was working very well with my daughter's HP... And then crash boom UUUU.
Here's what works:
At this point, it's good to have connected your TV to one of the HDMI outputs (I used HDMI3, but Samsung recommends the one used for the DVD player)
So you have to say YES.
And then miraculous, the entire desktop appears on the TV...
All that’s left is to choose a good movie to stream....
Here's what works:
- go to control panel
- personalization tab...
- click on the link that appears in the left menu bar of the screen linking to connect an external projector or other device.
- in the new window, click on detect a new monitor
- the system then detects the new monitor and .... two screens appear.
- the system asks if you want to extend the display to both screens...
as proposed by manjapatanas:
Here’s what works:
go to the control panel
click on the link that appears in the left menu bar of the screen "connect an external projector or any other device."
At this point, it's good to have your TV connected to one of the HDMI outputs, I used a Samsung HDMI2
"The system asks if we want" to connect a monitor ": click on it and 2 screens appear, just click on "duplicate my desktop on all screens (mirrored)" and the TV duplicates the desktop.
Thank you
