Problem with portable DVD VD Tech PDV 310
--JoRdaN--
Posted messages
Status
capucine -
capucine -
Hello,
I have a portable DVD player, VD Tech PDV 310, but I lost the user manual. Can you help me?
The issue is that my screen displays upside down, so I have to put it upside down to watch it :s
Thank you!
Thank you!
Hi, your problem is the Li-ion battery that has gone below its minimum threshold (I tinker a lot as a repairer of this type of product). The best thing is to change it or to boost it (sometimes it works!).
Hello,
I also have a Bluetech PDV 310 portable DVD player, and I have lost the manual as well...
Actually, I would like to know how to operate the SD card reader and the USB port. When I insert the SD card or the USB cable, the DVD player does indicate that it has found them, but it doesn’t read what’s inside???
I would also like to know if "gnondpom" could send me the manual via email.
Thank you in advance.
