Probleme de configation wifi
Résoluj ai en dualboot sur trois ordinateur ubuntu12.04 et windows
En france pas de probleme mais en suisse je n'arrive pas a avoir la wifi sur le pc fix qui est un acer aspire m1610 et sur un netbook samsung
je rentre les meme caracteristique que pour windows a savoir le meme mot de pass et je choisi wpa personal mais ca fonctionne ne pas
voici des information :
cat /etc/lsb-release
mickael@mickael-Aspire-M1610:~$ cat /etc/lsb-release DISTRIB_ID=Ubuntu DISTRIB_RELEASE=12.04 DISTRIB_CODENAME=precise DISTRIB_DESCRIPTION="Ubuntu 12.04 LTS"
lsusb
mickael@mickael-Aspire-M1610:~$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 148f:2573 Ralink Technology, Corp. RT2501/RT2573 Wireless Adapter Bus 003 Device 002: ID 058f:9360 Alcor Micro Corp. 8-in-1 Media Card Reader mickael@mickael-Aspire-M1610:~$
lspci
mickael@mickael-Aspire-M1610:~$ lspci 00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX 00:01.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge 00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01) 00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 IDE Controller (rev 01) 00:03.0 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) 00:03.1 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) 00:03.3 USB controller: Silicon Integrated Systems [SiS] USB 2.0 Controller 00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02) 00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03) 00:06.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge 00:0c.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link) 00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller 01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RV610 video device [Radeon HD 2400 PRO] 01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI RV610 HDMI Audio [Radeon HD 2350/2400 Series]
lspci -nn | grep -i net
mickael@mickael-Aspire-M1610:~$ lspci -nn | grep -i net 00:04.0 Ethernet controller [0200]: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter [1039:0191] (rev 02) mickael@mickael-Aspire-M1610:~$
sudo lshw -C network
mickael@mickael-Aspire-M1610:~$ sudo lshw -C network
[sudo] password for mickael:
*-network
description: Ethernet interface
produit: 191 Gigabit Ethernet Adapter
fabriquant: Silicon Integrated Systems [SiS]
identifiant matériel: 4
information bus: pci@0000:00:04.0
nom logique: eth0
version: 02
numéro de série: 00:1c:25:57:e2:9b
taille: 10Mbit/s
capacité: 100Mbit/s
bits: 32 bits
horloge: 33MHz
fonctionnalités: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sis190 driverversion=1.4 duplex=half latency=0 link=no multicast=yes port=MII speed=10Mbit/s
ressources: irq:19 mémoire:fdffc000-fdffc07f portE/S:fe00(taille=128)
*-network DÉSACTIVÉ
description: Interface réseau sans fil
identifiant matériel: 1
information bus: usb@1:1
nom logique: wlan0
numéro de série: 00:0e:e8:dc:e8:f7
fonctionnalités: ethernet physical wireless
configuration: broadcast=yes driver=rt73usb driverversion=3.2.0-24-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bg
lsmod
mickael@mickael-Aspire-M1610:~$ lsmod Module Size Used by pci_stub 12550 1 vboxpci 22882 0 vboxnetadp 13328 0 vboxnetflt 27211 0 vboxdrv 252189 3 vboxpci,vboxnetadp,vboxnetflt vesafb 13516 1 arc4 12473 2 iptable_nat 13016 0 iptable_mangle 12646 0 snd_hda_codec_hdmi 31775 1 rt73usb 27029 0 rt2x00usb 20061 1 rt73usb rt2x00lib 48858 2 rt73usb,rt2x00usb mac80211 436455 2 rt2x00usb,rt2x00lib cfg80211 178679 2 rt2x00lib,mac80211 snd_seq_midi 13132 0 snd_rawmidi 25424 1 snd_seq_midi snd_hda_codec_realtek 174055 1 ip6t_LOG 16846 4 xt_hl 12465 6 ip6t_rt 12473 3 snd_hda_intel 32765 5 snd_hda_codec 109562 3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel nf_conntrack_ipv6 13581 7 nf_defrag_ipv6 13139 1 nf_conntrack_ipv6 ipt_REJECT 12512 0 snd_seq_midi_event 14475 1 snd_seq_midi ipt_LOG 12783 0 snd_hwdep 13276 1 snd_hda_codec xt_limit 12541 5 xt_tcpudp 12531 9 snd_pcm 80845 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec xt_addrtype 12596 0 xt_state 12514 7 psmouse 87213 0 serio_raw 13027 0 snd_seq 51567 2 snd_seq_midi,snd_seq_midi_event ip6table_filter 12711 1 ip6_tables 22528 3 ip6t_LOG,ip6t_rt,ip6table_filter nf_conntrack_netbios_ns 12585 0 nf_conntrack_broadcast 12541 1 nf_conntrack_netbios_ns nf_nat_ftp 12595 0 nf_nat 24959 2 iptable_nat,nf_nat_ftp nf_conntrack_ipv4 19084 3 iptable_nat,nf_nat nf_defrag_ipv4 12649 1 nf_conntrack_ipv4 nf_conntrack_ftp 13183 1 nf_nat_ftp nf_conntrack 73847 9 iptable_nat,nf_conntrack_ipv6,xt_state,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_nat_ftp,nf_nat,nf_conntrack_ipv4,nf_conntrack_ftp snd_timer 28931 2 snd_pcm,snd_seq bnep 17830 2 iptable_filter 12706 0 snd_seq_device 14172 3 snd_seq_midi,snd_rawmidi,snd_seq ip_tables 18106 3 iptable_nat,iptable_mangle,iptable_filter bluetooth 158438 7 bnep fglrx 2909855 94 ppdev 12849 0 x_tables 21974 15 iptable_nat,iptable_mangle,ip6t_LOG,xt_hl,ip6t_rt,ipt_REJECT,ipt_LOG,xt_limit,xt_tcpudp,xt_addrtype,xt_state,ip6table_filter,ip6_tables,iptable_filter,ip_tables binfmt_misc 17292 1 parport_pc 32114 1 snd 62064 20 snd_hda_codec_hdmi,snd_rawmidi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device mac_hid 13077 0 soundcore 14635 1 snd snd_page_alloc 14115 2 snd_hda_intel,snd_pcm sis_agp 13165 0 lp 17455 0 parport 40930 3 ppdev,parport_pc,lp usb_storage 39646 0 uas 17828 0 firewire_ohci 40180 0 firewire_core 56906 1 firewire_ohci crc_itu_t 12627 2 rt73usb,firewire_core sis190 22575 0 sata_sis 12700 2 floppy 60310 0 mickael@mickael-Aspire-M1610:~$
iwconfig
mickael@mickael-Aspire-M1610:~$ iwconfig
lo no wireless extensions.
wlan0 IEEE 802.11bg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
eth0 no wireless extensions.
ifconfig
mickael@mickael-Aspire-M1610:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:1c:25:57:e2:9b
UP BROADCAST MULTICAST MTU:1500 Metric:1
Packets reçus:0 erreurs:0 :0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
Octets reçus:0 (0.0 B) Octets transmis:0 (0.0 B)
Interruption:19 Adresse de base:0xdead
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
adr inet6: ::1/128 Scope:Hôte
UP LOOPBACK RUNNING MTU:16436 Metric:1
Packets reçus:852 erreurs:0 :0 overruns:0 frame:0
TX packets:852 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:0
Octets reçus:68816 (68.8 KB) Octets transmis:68816 (68.8 KB)
sudo iwlist scan
mickael@mickael-Aspire-M1610:~$ sudo iwlist scan lo Interface doesn't support scanning. wlan0 Interface doesn't support scanning : Network is down eth0 Interface doesn't support scanning.
uname -r -m
mickael@mickael-Aspire-M1610:~$ uname -r -m 3.2.0-24-generic i686
cat /etc/network/interfaces
mickael@mickael-Aspire-M1610:~$ cat /etc/network/interfaces auto lo iface lo inet loopback mickael@mickael-Aspire-M1610:~$
nm-tool
mickael@mickael-Aspire-M1610:~$ nm-tool
NetworkManager Tool
State: disconnected
- Device: wlan0 ----------------------------------------------------------------
Type: 802.11 WiFi
Driver: rt73usb
State: unavailable
Default: no
HW Address: 00:0E:E8:DC:E8:F7
Capabilities:
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points
- Device: eth0 -----------------------------------------------------------------
Type: Wired
Driver: sis190
State: unavailable
Default: no
HW Address: 00:1C:25:57:E2:9B
Capabilities:
Carrier Detect: yes
Wired Properties
Carrier: off
sudo rfkill list
mickael@mickael-Aspire-M1610:~$ sudo rfkill list 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no mickael@mickael-Aspire-M1610:~$
merci d'avance pour vos reponse et bonne journée
"Celui qui se transforme en bête se delivre de la douleur d'être un homme"
La vitesse de la lumière étant supérieur à celle du son,
beaucoup de personne paraissent brillantes,
avant d'ouvrir leur gueule ...
23 réponses
Problème central: dans un environnement dual-boot Windows/Ubuntu 12.04, la connexion wifi ne s'active pas sur des ordinateurs dotés d'une carte USB RT73 et d'un réseau WPA. Des tests et informations système ont été partagés, incluant le détail matériel et logiciel: l'adaptateur wifi RT73usb, l'absence de détection réseau, et des commandes comme lspci, lsusb, lshw et nm-tool. En pratique, plusieurs diagnostics montrent que le périphérique wlan0 existe mais reste non relié, sans blocage rfkill, ni service NetworkManager opérationnel, avec réponse négative lors des scans et des connexions. D'autres pistes évoquent l'essai de solutions comme le live USB, l'installation de paquets USB ou l'expérimentation avec ndiswrapper, indiquant que le problème peut venir de la configuration réseau plutôt que du matériel.
Quand tu cliques sur l'icône de network manager, est-ce que tu vois le nom de ta connexion wifi dans la liste ?
Si ça fonctionne en France, je ne vois pas pourquoi ça ne fonctionnerait pas en Suisse, ça doit être un des paramètres qui ne va pas.
Vérifie aussi que l'option "Activer le réseau sans fil" est cochée lorsque tu fais un clic droit sur l'icône de network manager. -
En France le nom de mon réseau apparaissait la je n ai qu un nom ça doit être celui d un voisin le mien n y figure pas
j ai essayer d'en créer un et bon maintenant il apparait dans la liste mais sans signal et ma clee ne fonctionne pas alors que sous windows si.
ca m ennuie car je prefere nettement linux a windows -
As-tu essayé de faire marcher linux en live ? Il se peut qu'en live le problème n'apparaisse plus...
ben ubuntu est déjà installé depuis un bout de temps et daccord mais dans ce cas la qu es ce que je dois faire, je m y connai un peu en informatique mais la ca depasse mes competence.Es ce que je doit recopier la configuration qu nil y a en live?
merci -
Pour faire tourner son PC en live, voici comment il faut faire : Je te donne un extrait de mon site (WWW.suiteduforumentraide) Remarque importante : la marche à suivre est pour un PC "AAO" (Acer Aspire One), il faut l'adapter à ton propre PC :
Faire tourner votre AAO en live
Pourquoi faire tourner son AAO en live ? Il y a plusieurs avantages :
- Essayer un nouveau Linux, ou voir les avantages d'une nouvelle version sans être obligé de l'installer.
- Tester son AAO quand le disque dur paraît bloqué.
- Aller voir sur le disque dur pour récupérer un dossier quand windows ne veut plus démarrer.
- Aller sur internet autrement que par l'intermédiaire de Windows pour une raison quelconque (peur des virus par exemple).
- Et d'autres raisons que vous allez peut-être m'indiquer...
Comment faut-il procéder ?
Tout d'abord, il faut mettre un linux sur un support bootable, soit une clé, soit un disque bootable : disque gravé ou acheté dans le commerce, ou encore livré avec une revue Linux. Dans ce cas il vous faut un lecteur de DVD externe à brancher en USB à environ 45 €. (Je pense que c'est la solution la plus pratique...)
Quel Linux prendre ?
Je dirais que c'est un peu l'embarras du choix. Allez voir sur Wikipedia pour vous faire une idée.
Choix personnel : EasyPeasy
Quand le choix est fait, vous mettez la clé bootable, ou vous branchez le lecteur USB et vous redémarrez votre AAO.
Dès qu'il redémarre, vous tapotez sur F2, jusqu'à avoir la première page du Bios intitulée : Information. Ensuite, vous passez à la page « Boots » à l'aide des flèches du clavier. Vous avez alors une liste, il faut mettre en premier la ligne : USB HDD si vous utilisez une clé ou la ligne USB CDROM si vous utilisez un lecteur. Pour ceci, il faut sélectionner la ligne choisie à l'aide des flèches du clavier et monter ou descendre la ligne avec F5 ou F6.
Quand la ligne choisie est en place, il faut valider avec F10 et, miracle, l'AAO redémarre en live !
Pour redémarrer normalement, il suffit de retirer la clé ou le lecteur. Cependant, s'il reste bloqué, il faut refaire la dernière manoeuvre et mettre la ligne :
IDEO (suivi d'un long chiffre)
en premier, et tout rentrera dans l'ordre...
BMMWW -
ok j essaye je grave un linux que j essaierai en live
A mon avis le problème sera le même avec une autre distribution.
Ton wifi est peut-être caché. Clique sur l'icône de network manager puis sur Se connecter à un réseau sans fil invisible.
Entre le nom du réseau dans la case SSID (attention aux majuscule/minuscule)
Choisis Mode Infrastructure
Onglet sécurité :
Choisis wpa ou wpa2 personnel
Onglet ipv4 Choisis Automatique (DHCP)
Onglet ipv6 Choisis ignorer
Ferme la fenêtre
Clique à nouveau sur network manager et vois si le nom du réseau apparaît maintenant. Si oui clique dessus, il devrait te demander ta clé wpa et se connecter. -
j essaye de voir en live si sa fonctionne et recopier la configuration
Oui, je me doute !
Si tu arrives à faire tourner ton PC en live et que le wifi marche, c'est signe que ton ubuntu à un défaut... reste à déterminer lequel ! -
petit probleme dans le live c est un clavier americain et dans mon code wifi il y a un ç et sa n existe pas en americain
il detecte bien mon reseau mais n arrive pas a ce conecter
Bravo !
Pour mettre en français voici ce que tu dois faire (toujours extrait de mon site) :
Quand EasyPeasy tourne, pour mettre le wifi en route, vous vous apercevez que vous avez un clavier Anglais ! Assez gênant ! Voici la manipulation qu'il faut faire pour le mettre en Français :
Vous cliquez sur "System" puis sur "Keyboard" là, vous choisissez l'onglet "Layouts" puis vous cliquez sur "Add" : dans la liste vous choisissez "France", bien sûr... quand la petite fenêtre est fermée, vous avez dans la liste :
USA
France
Vous saisissez France avec le curseur de la souris et vous la glissez en première position, ensuite vous cliquez sur "Apply System-Wide" et vous fermez la fenêtre... vous êtes en Français ! -
ok j ai mi le clavieren francais mais pareil sa refuse de se connecter
Donc comme je disai j ai graver ubuntu, le dernier et je l ai mi en live, j ai mi le clavier en francais et j ai taper mon code et sa fonctionne toujour pas c est desperant l idee de retourner sous windows
Alors je vien de tester avec le netbook a coter de la box et sa fonctionne pas, j ai tester ma clee wifi et le code sur un windows et tout fonctionne le probleme vien de linux je suis desperer
quand je clique sur mon reseau il cherche puis apres il me demande de taper la clee et sa ne fonctionne pas -
je vais essayer avec ndiswrapper
Essaie la démarche suivante :
Tu vas dans système puis tu cliques sur gestionnaire de paquets Quand le gestionnaire est opérationnel, dans la recherche tu mets :
wifi
Tu as alors une liste de paquets, tu les prends tous un par un et tu fais un clic droit dessus et tu demandes leurs installation. Quand c'est fini tu cliques sur appliquer et tu laisses faire...
Si tout va bien, ton wifi risque de marcher... -
j ai installer wifi radar et il bloque sur "acquiring ip adress (dhcp)"
je vais esssayer avec le gestionnaire synaptic -
bon j'ai installer le seul paquet que je n avais pas contenant le mot wifi je croi si ma memoire est bonne c est plasma-widget-wifi sans etre sur et sa donne toujour rien
Dommage !
Maintenant essaie en mettant dans la recherche :
usb
Il y a beaucoup de paquets mais tu peux éliminer tous ceux qui mentionnent "HP" et ceux qui visiblement n'ont rien à voir avec le problème... -
J ai supprimer quelque truc usb avec méfiance tout de même et toujours rien pffff
ne pensez vous pas que c est dans le configuration des paramètre de réseau?-
Si ton réseau est vu
- Soit il y a une erreur dans ta configuration du réseau.
- Soit le signal est trop faible pour que la connexion s'établisse (tu as parlé de signal faible plus haut)
En installant des paquets comme ça à la volée sans savoir ce qu'ils font, tu vas encombrer ton système de paquets totalement inutiles voire provoquer des dysfonctionnements s'il y a des incompatibilités avec les paquets installés... -
ok je calme avec les paquets j ai installern les usb et toujours rien .
sous windows le signal est fort mais sous ubuntu il est faible mais la je suis avec le netbook sous windows en wifi et ca va tres bien mais que je me met a coiter de la box sous ubuntu sa fonctionne pas
je pense aussi a une configuration du réseau mais je suis une quiche et je ne sais comment faire j ai essayer des truc aleatoire et rien ne change
en tout cas merci de m'aider -
- 1
- 2
