Probleme de configation wifi
j ai en dualboot sur trois ordinateur ubuntu12.04 et windows
En france pas de probleme mais en suisse je n'arrive pas a avoir la wifi sur le pc fix qui est un acer aspire m1610 et sur un netbook samsung
je rentre les meme caracteristique que pour windows a savoir le meme mot de pass et je choisi wpa personal mais ca fonctionne ne pas
voici des information :
cat /etc/lsb-release
mickael@mickael-Aspire-M1610:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04 LTS"
lsusb
mickael@mickael-Aspire-M1610:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 148f:2573 Ralink Technology, Corp. RT2501/RT2573 Wireless
Adapter
Bus 003 Device 002: ID 058f:9360 Alcor Micro Corp. 8-in-1 Media Card Reader
lspci
mickael@mickael-Aspire-M1610:~$ lspci
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 IDE Controller (rev 01)
00:03.0 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.1 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.3 USB controller: Silicon Integrated Systems [SiS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02)
00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03)
00:06.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:0c.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RV610 video device [Radeon HD 2400 PRO]
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI RV610 HDMI Audio [Radeon HD 2350/2400 Series]
lspci -nn | grep -i net
mickael@mickael-Aspire-M1610:~$ lspci -nn | grep -i net
00:04.0 Ethernet controller [0200]: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter [1039:0191] (rev 02)
sudo lshw -C network
mickael@mickael-Aspire-M1610:~$ sudo lshw -C network
[sudo] password for mickael:
  *-network
       description: Ethernet interface
       produit: 191 Gigabit Ethernet Adapter
       fabriquant: Silicon Integrated Systems [SiS]
       identifiant matériel: 4
       information bus: pci@0000:00:04.0
       nom logique: eth0
       version: 02
       numéro de série: 00:1c:25:57:e2:9b
       taille: 10Mbit/s
       capacité: 100Mbit/s
       bits: 32 bits
       horloge: 33MHz
       fonctionnalités: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=sis190 driverversion=1.4 duplex=half latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       ressources: irq:19 mémoire:fdffc000-fdffc07f portE/S:fe00(taille=128)
  *-network DÉSACTIVÉ
       description: Interface réseau sans fil
       identifiant matériel: 1
       information bus: usb@1:1
       nom logique: wlan0
       numéro de série: 00:0e:e8:dc:e8:f7
       fonctionnalités: ethernet physical wireless
       configuration: broadcast=yes driver=rt73usb driverversion=3.2.0-24-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bg
lsmod
mickael@mickael-Aspire-M1610:~$ lsmod
Module                  Size  Used by
pci_stub               12550  1
vboxpci                22882  0
vboxnetadp             13328  0
vboxnetflt             27211  0
vboxdrv               252189  3 vboxpci,vboxnetadp,vboxnetflt
vesafb                 13516  1
arc4                   12473  2
iptable_nat            13016  0
iptable_mangle         12646  0
snd_hda_codec_hdmi     31775  1
rt73usb                27029  0
rt2x00usb              20061  1 rt73usb
rt2x00lib              48858  2 rt73usb,rt2x00usb
mac80211              436455  2 rt2x00usb,rt2x00lib
cfg80211              178679  2 rt2x00lib,mac80211
snd_seq_midi           13132  0
snd_rawmidi            25424  1 snd_seq_midi
snd_hda_codec_realtek   174055  1
ip6t_LOG               16846  4
xt_hl                  12465  6
ip6t_rt                12473  3
snd_hda_intel          32765  5
snd_hda_codec         109562  3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
nf_conntrack_ipv6      13581  7
nf_defrag_ipv6         13139  1 nf_conntrack_ipv6
ipt_REJECT             12512  0
snd_seq_midi_event     14475  1 snd_seq_midi
ipt_LOG                12783  0
snd_hwdep              13276  1 snd_hda_codec
xt_limit               12541  5
xt_tcpudp              12531  9
snd_pcm                80845  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
xt_addrtype            12596  0
xt_state               12514  7
psmouse                87213  0
serio_raw              13027  0
snd_seq                51567  2 snd_seq_midi,snd_seq_midi_event
ip6table_filter        12711  1
ip6_tables             22528  3 ip6t_LOG,ip6t_rt,ip6table_filter
nf_conntrack_netbios_ns    12585  0
nf_conntrack_broadcast    12541  1 nf_conntrack_netbios_ns
nf_nat_ftp             12595  0
nf_nat                 24959  2 iptable_nat,nf_nat_ftp
nf_conntrack_ipv4      19084  3 iptable_nat,nf_nat
nf_defrag_ipv4         12649  1 nf_conntrack_ipv4
nf_conntrack_ftp       13183  1 nf_nat_ftp
nf_conntrack           73847  9 iptable_nat,nf_conntrack_ipv6,xt_state,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_nat_ftp,nf_nat,nf_conntrack_ipv4,nf_conntrack_ftp
snd_timer              28931  2 snd_pcm,snd_seq
bnep                   17830  2
iptable_filter         12706  0
snd_seq_device         14172  3 snd_seq_midi,snd_rawmidi,snd_seq
ip_tables              18106  3 iptable_nat,iptable_mangle,iptable_filter
bluetooth             158438  7 bnep
fglrx                2909855  94
ppdev                  12849  0
x_tables               21974  15 iptable_nat,iptable_mangle,ip6t_LOG,xt_hl,ip6t_rt,ipt_REJECT,ipt_LOG,xt_limit,xt_tcpudp,xt_addrtype,xt_state,ip6table_filter,ip6_tables,iptable_filter,ip_tables
binfmt_misc            17292  1
parport_pc             32114  1
snd                    62064  20 snd_hda_codec_hdmi,snd_rawmidi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device
mac_hid                13077  0
soundcore              14635  1 snd
snd_page_alloc         14115  2 snd_hda_intel,snd_pcm
sis_agp                13165  0
lp                     17455  0
parport                40930  3 ppdev,parport_pc,lp
usb_storage            39646  0
uas                    17828  0
firewire_ohci          40180  0
firewire_core          56906  1 firewire_ohci
crc_itu_t              12627  2 rt73usb,firewire_core
sis190                 22575  0
sata_sis               12700  2
floppy                 60310  0
iwconfig
mickael@mickael-Aspire-M1610:~$ iwconfig
lo        no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
eth0      no wireless extensions.
ifconfig
mickael@mickael-Aspire-M1610:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:1c:25:57:e2:9b
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          Packets reçus:0 erreurs:0 :0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          Octets reçus:0 (0.0 B) Octets transmis:0 (0.0 B)
          Interruption:19 Adresse de base:0xdead
lo        Link encap:Boucle locale
          inet adr:127.0.0.1  Masque:255.0.0.0
          adr inet6: ::1/128 Scope:Hôte
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          Packets reçus:852 erreurs:0 :0 overruns:0 frame:0
          TX packets:852 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:0
          Octets reçus:68816 (68.8 KB) Octets transmis:68816 (68.8 KB)
sudo iwlist scan
mickael@mickael-Aspire-M1610:~$ sudo iwlist scan
lo        Interface doesn't support scanning.
wlan0     Interface doesn't support scanning : Network is down
eth0      Interface doesn't support scanning.
uname -r -m
mickael@mickael-Aspire-M1610:~$ uname -r -m
3.2.0-24-generic i686
cat /etc/network/interfaces
mickael@mickael-Aspire-M1610:~$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
nm-tool
mickael@mickael-Aspire-M1610:~$ nm-tool
NetworkManager Tool
State: disconnected
- Device: wlan0 ----------------------------------------------------------------
  Type:              802.11 WiFi
  Driver:            rt73usb
  State:             unavailable
  Default:           no
  HW Address:        00:0E:E8:DC:E8:F7
  Capabilities:
  Wireless Properties
    WEP Encryption:  yes
    WPA Encryption:  yes
    WPA2 Encryption: yes
  Wireless Access Points
- Device: eth0 -----------------------------------------------------------------
  Type:              Wired
  Driver:            sis190
  State:             unavailable
  Default:           no
  HW Address:        00:1C:25:57:E2:9B
  Capabilities:
    Carrier Detect:  yes
  Wired Properties
    Carrier:         off
sudo rfkill list
mickael@mickael-Aspire-M1610:~$ sudo rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
merci d'avance pour vos reponse et bonne journée
"Celui qui se transforme en bête se delivre de la douleur d'être un homme"
La vitesse de la lumière étant supérieur à celle du son,
beaucoup de personne paraissent brillantes,
avant d'ouvrir leur gueule ...
23 réponses
Problème central: dans un environnement dual-boot Windows/Ubuntu 12.04, la connexion wifi ne s'active pas sur des ordinateurs dotés d'une carte USB RT73 et d'un réseau WPA. Des tests et informations système ont été partagés, incluant le détail matériel et logiciel: l'adaptateur wifi RT73usb, l'absence de détection réseau, et des commandes comme lspci, lsusb, lshw et nm-tool. En pratique, plusieurs diagnostics montrent que le périphérique wlan0 existe mais reste non relié, sans blocage rfkill, ni service NetworkManager opérationnel, avec réponse négative lors des scans et des connexions. D'autres pistes évoquent l'essai de solutions comme le live USB, l'installation de paquets USB ou l'expérimentation avec ndiswrapper, indiquant que le problème peut venir de la configuration réseau plutôt que du matériel.
  1. Bonjour ca y est reussi il fallai juste retirer le "ç" du mot de passe c etait tout simple mais des semaines de prises de tete
    1. Non, il faut installer tous les paquets "usb" sauf ceux qui mentionnent HP ou qui visiblement n'ont rien à voir avec le problème...
      Excuse-moi, je me suis mal exprimé !
      1. J ai supprimer quelque truc usb avec méfiance tout de même et toujours rien pffff
        ne pensez vous pas que c est dans le configuration des paramètre de réseau?
        1. Si ton réseau est vu
          - Soit il y a une erreur dans ta configuration du réseau.
          - Soit le signal est trop faible pour que la connexion s'établisse (tu as parlé de signal faible plus haut)
          En installant des paquets comme ça à la volée sans savoir ce qu'ils font, tu vas encombrer ton système de paquets totalement inutiles voire provoquer des dysfonctionnements s'il y a des incompatibilités avec les paquets installés...
        2. ok je calme avec les paquets j ai installern les usb et toujours rien .
          sous windows le signal est fort mais sous ubuntu il est faible mais la je suis avec le netbook sous windows en wifi et ca va tres bien mais que je me met a coiter de la box sous ubuntu sa fonctionne pas
          je pense aussi a une configuration du réseau mais je suis une quiche et je ne sais comment faire j ai essayer des truc aleatoire et rien ne change
          en tout cas merci de m'aider
        3. Si le signal est fort sus windows mais faible sous ubuntu, il faudrait peut-être regarder dans le paramétrage de la box, changer de canal par exemple. D'autant plus que tu as dit que ton wifi fonctionnait très bien en France, donc ça peut pas être un problème de pilote ou de matériel.
        4. Daccord mais je nai aucune idee de comment on change de canal
          je v essayer de trouver mais si vous avez des conseils je suis preneur
        5. J ai tout reconfigurer et ca fonctionne pas j essye de changer de canal pour voir
      2. Dommage !
        Maintenant essaie en mettant dans la recherche :
        usb
        Il y a beaucoup de paquets mais tu peux éliminer tous ceux qui mentionnent "HP" et ceux qui visiblement n'ont rien à voir avec le problème...
        1. bon j'ai installer le seul paquet que je n avais pas contenant le mot wifi je croi si ma memoire est bonne c est plasma-widget-wifi sans etre sur et sa donne toujour rien
          1. j ai installer wifi radar et il bloque sur "acquiring ip adress (dhcp)"
            je vais esssayer avec le gestionnaire synaptic
            1. Essaie la démarche suivante :
              Tu vas dans système puis tu cliques sur gestionnaire de paquets Quand le gestionnaire est opérationnel, dans la recherche tu mets :
              wifi
              Tu as alors une liste de paquets, tu les prends tous un par un et tu fais un clic droit dessus et tu demandes leurs installation. Quand c'est fini tu cliques sur appliquer et tu laisses faire...
              Si tout va bien, ton wifi risque de marcher...
              1. Alors je vien de tester avec le netbook a coter de la box et sa fonctionne pas, j ai tester ma clee wifi et le code sur un windows et tout fonctionne le probleme vien de linux je suis desperer
                quand je clique sur mon reseau il cherche puis apres il me demande de taper la clee et sa ne fonctionne pas
                1. Donc comme je disai j ai graver ubuntu, le dernier et je l ai mi en live, j ai mi le clavier en francais et j ai taper mon code et sa fonctionne toujour pas c est desperant l idee de retourner sous windows
                  1. Il voit ton réseau ?
                  2. ben il indique le nom mais le signal est tres faible peut etre que ma clee wifi est pas assez puissante
                  3. et il ne se connecte pas
                  4. Que se passe t-il lorsque tu cliques sur le nom de ton réseau ?
                    Pardon j'avais pas vu la réponse au dessus.
                    Tu peux pas essayer de terapprocher de la box pour voir ? Si le signal est faible, c'est probablement la cause.
                2. ok j ai mi le clavieren francais mais pareil sa refuse de se connecter
                  1. Bravo !
                    Pour mettre en français voici ce que tu dois faire (toujours extrait de mon site) :
                    Quand EasyPeasy tourne, pour mettre le wifi en route, vous vous apercevez que vous avez un clavier Anglais ! Assez gênant ! Voici la manipulation qu'il faut faire pour le mettre en Français :
                    Vous cliquez sur "System" puis sur "Keyboard" là, vous choisissez l'onglet "Layouts" puis vous cliquez sur "Add" : dans la liste vous choisissez "France", bien sûr... quand la petite fenêtre est fermée, vous avez dans la liste :
                    USA
                    France
                    Vous saisissez France avec le curseur de la souris et vous la glissez en première position, ensuite vous cliquez sur "Apply System-Wide" et vous fermez la fenêtre... vous êtes en Français !
                    1. easypeasy, c'est l'ancêtre d'unity pour ubuntu mais hélas cette distro n'est plus maintenue maintenant. C'était un modèle d'interface claire et simplifiée, ce qu'on ne peut pas dire d'unity .
                      Si le réseau est visible avec easypeasy, il n'y a aucune raison pour qu'il ne le soit pas avec ubuntu.
                    2. j ai fait un live de ubuntu
                  2. petit probleme dans le live c est un clavier americain et dans mon code wifi il y a un ç et sa n existe pas en americain
                    1. Oui, je me doute !
                      Si tu arrives à faire tourner ton PC en live et que le wifi marche, c'est signe que ton ubuntu à un défaut... reste à déterminer lequel !
                      1. j essaye de voir en live si sa fonctionne et recopier la configuration
                        1. ok j essaye je grave un linux que j essaierai en live
                          1. A mon avis le problème sera le même avec une autre distribution.
                            Ton wifi est peut-être caché. Clique sur l'icône de network manager puis sur Se connecter à un réseau sans fil invisible.
                            Entre le nom du réseau dans la case SSID (attention aux majuscule/minuscule)
                            Choisis Mode Infrastructure
                            Onglet sécurité :
                            Choisis wpa ou wpa2 personnel
                            Onglet ipv4 Choisis Automatique (DHCP)
                            Onglet ipv6 Choisis ignorer
                            Ferme la fenêtre
                            Clique à nouveau sur network manager et vois si le nom du réseau apparaît maintenant. Si oui clique dessus, il devrait te demander ta clé wpa et se connecter.
                          2. c EST EXACTEMENT CE QUE J AVAIS FAIT SAUF QUE J AVAIS MI IPV6 en automatique mais sa fonctionne toutjours pas
                        2. Pour faire tourner son PC en live, voici comment il faut faire : Je te donne un extrait de mon site (WWW.suiteduforumentraide) Remarque importante : la marche à suivre est pour un PC "AAO" (Acer Aspire One), il faut l'adapter à ton propre PC :
                          Faire tourner votre AAO en live
                          Pourquoi faire tourner son AAO en live ? Il y a plusieurs avantages :
                          - Essayer un nouveau Linux, ou voir les avantages d'une nouvelle version sans être obligé de l'installer.
                          - Tester son AAO quand le disque dur paraît bloqué.
                          - Aller voir sur le disque dur pour récupérer un dossier quand windows ne veut plus démarrer.
                          - Aller sur internet autrement que par l'intermédiaire de Windows pour une raison quelconque (peur des virus par exemple).
                          - Et d'autres raisons que vous allez peut-être m'indiquer...
                          Comment faut-il procéder ?
                          Tout d'abord, il faut mettre un linux sur un support bootable, soit une clé, soit un disque bootable : disque gravé ou acheté dans le commerce, ou encore livré avec une revue Linux. Dans ce cas il vous faut un lecteur de DVD externe à brancher en USB à environ 45 €. (Je pense que c'est la solution la plus pratique...)
                          Quel Linux prendre ?
                          Je dirais que c'est un peu l'embarras du choix. Allez voir sur Wikipedia pour vous faire une idée.
                          Choix personnel : EasyPeasy
                          Quand le choix est fait, vous mettez la clé bootable, ou vous branchez le lecteur USB et vous redémarrez votre AAO.
                          Dès qu'il redémarre, vous tapotez sur F2, jusqu'à avoir la première page du Bios intitulée : Information. Ensuite, vous passez à la page « Boots » à l'aide des flèches du clavier. Vous avez alors une liste, il faut mettre en premier la ligne : USB HDD si vous utilisez une clé ou la ligne USB CDROM si vous utilisez un lecteur. Pour ceci, il faut sélectionner la ligne choisie à l'aide des flèches du clavier et monter ou descendre la ligne avec F5 ou F6.
                          Quand la ligne choisie est en place, il faut valider avec F10 et, miracle, l'AAO redémarre en live !
                          Pour redémarrer normalement, il suffit de retirer la clé ou le lecteur. Cependant, s'il reste bloqué, il faut refaire la dernière manoeuvre et mettre la ligne :
                          IDEO (suivi d'un long chiffre)
                          en premier, et tout rentrera dans l'ordre...
                          BMMWW
                          1. ben ubuntu est déjà installé depuis un bout de temps et daccord mais dans ce cas la qu es ce que je dois faire, je m y connai un peu en informatique mais la ca depasse mes competence.Es ce que je doit recopier la configuration qu nil y a en live?
                            • 1
                            • 2
