Suit au probléme vba excle
Bonjour,, Dim m As String, n As String ro As Double
Dim v As String, a As String, b As String, e As String, h As String
Dim l As String, y As String, x As String
Dim g As Long
Private Sub CommandButton1_Click()
For g = 6 To 400
ro = 63.6619772
m = Cells(g, 2)
n = Cells(g, 3)
Select Case m
Case Is < 69490
MsgBox "RAHMANI DIT: ERROR"
Case 69494.3795 To 69504.27
v = 141656.551: a = 69494.7106: b = 65733.71783: h = 105.452
Case 69504.271 To 69512.33
v = 141664.551: a = 69502.68121: b = 65733.03355: h = 105.7929
Case 69512.331 To 69520.381
v = 141672.551: a = 69510.64805: b = 65732.3066: h = 106.1157
Case 69520.381 To 69528.424
v = 141680.551: a = 69518.61112: b = 65731.53927: h = 106.4206
Case 69528.424 To 69536.458
v = 141688.551: a = 69526.57042: b = 65730.73381: h = 106.7075
Case 69536.458 To 69544.483
v = 141696.551: a = 69534.52603: b = 65729.89248: h = 106.9765
Case 69544.483 To 69552.499
v = 141704.551: a = 69542.47801: b = 65729.01755: h = 107.2276
Case 69552.499 To 69560.507
v = 141712.551: a = 69550.42649: b = 65728.11126: h = 107.4607
Case 69560.507 To 69568.507
v = 141720.551: a = 69558.37161: b = 65727.17586: h = 107.6759
Case 69568.507 To 69576.499
v = 141728.551: a = 69566.3135: b = 65726.21362: h = 107.8732
Case 69576.499 To 69584.483
v = 141736.551: a = 69574.2524: b = 65725.22677: h = 108.0525
Case 69584.483 To 69592.459
v = 141744.551: a = 69582.1885: b = 65724.21756: h = 108.2139
Case 69592.459 To 69600.428
v = 141752.551: a = 69590.12198: b = 65723.18824: h = 108.3573
Case 69600.428 To 69608.39
v = 141760.551: a = 69598.05314: b = 65722.14104: h = 108.4829
Case 69608.39 To 69616.344
v = 141768.551: a = 69605.98223: b = 65721.07821: h = 108.5905
Case 69616.344 To 69624.293
v = 141776.551: a = 69613.9095: b = 65720.00196: h = 108.6801
Case 69624.293 To 69632.235
v = 141784.551: a = 69621.83525: b = 65718.91456: h = 108.7519
Case 69632.235 To 69640.171
v = 141792.551: a = 69629.75978: b = 65717.81823: h = 108.8056
Case 69640.171 To 69648.102
v = 141800.551: a = 69637.68337: b = 65716.71521: h = 108.8415
Case 69648.102 To 69656.027
v = 141808.551: a = 69645.60634: b = 65715.60772: h = 108.8594
Case Is > 69715.60772
End Select
x = m - a
y = n - b
l = ro * Atn((x) / (y))
If y < 0 Then
l = l + 200
ElseIf l < 0 Then l = l + 400
End If
e = Sqr(x ^ 2 + n ^ 2)
Cells(g, 5) = v + (Cos((l - h)) * e)
Cells(g, 6) = Sin((l - h)) * e
Next g
End Sub
Dim g As Long
For g = 6 To 400
ro = 63.6619772
m = Cells(g, 2)
n = Cells(g, 3)
Select Case m
Case Is < 69490
End Select
x = m - a
y = n - b
If y < 0 Then
l = l + 200
End If
Next g
End Sub
13 réponses
aide moi svp
ContributeurComment veux-tu avoir une aide, il n'y a même pas de question !!!
ll'ereurr dans le code
ContributeurOn n'est pas là pour jouer aux devinettes...
Puisque tu ne veux pas en dire plus je passe la main aux autres -
mon problem que
ce code
dim x as double,y as double ,c as string
x=5
y=8
c=x*y
mes c toujeur dane c=""
results c="" pes c=40 -
ContributeurCa ne correspond pas au code que tu as fourni...
double : nombre décimal double précision
string : chaine de caractère
Donc soit c as double ou bien c=cstr(a*b) si tu veux vraiment une chaine -
dans moi exempler j'ai comprepas bien pq je suie nevaux en vb
voila mon programe
toute sa marche sof x, y, l ,e sa dans =""
tu peu risedre svp
Dim m As String, n As String, ro As Double
Dim g As Long
L probléme dans x,y,l,e
X= » »
Y= » »
E= » »
L= » »
For g = 6 To 400
ro = 63.6619772
m = Cells(g, 2)
n = Cells(g, 3)
Select Case m
Case Is < 69490
End Select
x = m - a
y = n - b
If y < 0 Then
l = l + 200
End If
Next g
End Sub -
ContributeurSi une variable doit manipuler des nombres met
as doubleet nonas string
lorcque j'ai faie as double ca done
c=vide -
ContributeurTOUTES tes variables as double. Ce sont des nombres
mame ro et fixe
ro=200/pi=63.6619772
et mirc -
Mame ro et fixe
et mirc
