Problème de compilation du "Kernel"
salut a tous!
je souhaite personaliser mon kernel avec make xconfig, tout est installer mais quand je le lance j'ai ca qui apparait!
CHECK qt
* Unable to find the QT4 tool qmake. Trying to use QT3
* Unable to find any QT installation. Please make sure that
* the QT4 or QT3 development package is correctly installed and
* either qmake can be found or install pkg-config or set
* the QTDIR environment variable to the correct location.
make[1]: *** No rule to make target 'scripts/kconfig/.tmp_qtcheck', needed by 'scripts/kconfig/qconf.o'. Stop.
make: *** [xconfig] Error 2
  1. Salut,
    fakeroot kernel-package qt4-dev-tools qt4-qmake libncurses5-dev wget bzip2 build-essential zlib1g-dev
    Sont bien installés ?
