System Fix Error Trojan
RésoluBesoin de votre aide SVP. Mon ordi est infecte par System Fix Error.
Jai lu pas mal vos articles alors je vous joints les rapports requis.
RogueKiller V6.1.12 [12/02/2011] by Tigzy
mail: tigzyRK<at>gmail<dot>com
Feedback: http://www.geekstogo.com/forum/files/file/413-roguekiller/
Blog: http://tigzyrk.blogspot.com
Operating System: Windows 7 (6.1.7600 ) 64 bits version
Started in : Safe mode with network support
User: Moe [Admin rights]
Mode: Remove -- Date : 12/04/2011 11:40:24
¤¤¤ Bad processes: 2 ¤¤¤
[SUSP PATH] mbam-setup-1.51.2.1300.exe -- C:\Users\Moe\Desktop\mbam-setup-1.51.2.1300.exe -> KILLED [TermProc]
[SUSP PATH] mbam-setup-1.51.2.1300.tmp -- C:\Users\Moe\AppData\Local\Temp\is-AL6C0.tmp\mbam-setup-1.51.2.1300.tmp -> KILLED [TermProc]
¤¤¤ Registry Entries: 10 ¤¤¤
[SUSP PATH] HKCU\[...]\Run : fIJsmsUwPvQ.exe (C:\ProgramData\fIJsmsUwPvQ.exe) -> DELETED
[SUSP PATH] HKCU\[...]\Run : Spyware Doctor with AntiVirus (C:\Users\Moe\Desktop\sdasetup_revwire207[1].exe -min) -> DELETED
[WallPP] HKCU\[...]\Desktop : Wallpaper () -> REPLACED (C:\Users\Moe\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg)
[HJ] HKCU\[...]\Advanced : Start_ShowMyComputer (0) -> REPLACED (1)
[HJ] HKCU\[...]\Advanced : Start_ShowSearch (0) -> REPLACED (1)
[HJ] HKLM\[...]\NewStartPanel : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
[HJ] HKCU\[...]\ClassicStartMenu : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
[HJ] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
[HJ] HKCU\[...]\ClassicStartMenu : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
[HJ] HKCU\[...]\ClassicStartMenu : {645FF040-5081-101B-9F08-00AA002F954E} (1) -> REPLACED (0)
¤¤¤ Particular Files / Folders: ¤¤¤
¤¤¤ Driver: [NOT LOADED] ¤¤¤
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
Finished : << RKreport[1].txt >>
RKreport[1].txt
29 réponses
Le fil porte sur une infection par System Fix Error sur un PC Windows 7 et sur l’utilisation de RogueKiller pour détecter et supprimer les processus malveillants et les entrées de registre associées. Des conseils promeuvent l’exécution en administrateur et l’application des suppressions indiquées par RogueKiller, aboutissant à la création de RKreport[1].txt et à l’élimination de processus et d’entrées Run malveillantes. En cas d’échec ou pour vérification, plusieurs échanges préconisent d’activer les mises à jour automatiques de Windows, puis de générer un nouveau rapport ZHPDiag et d’utiliser ComboFix pour nettoyer d’éventuels restes. Le quatrième échange signale des éléments résiduels possibles et des composants critiques non supprimés, soulignant que le nettoyage peut nécessiter plusieurs essais et outils complémentaires.
Contributeur sécuritéRe,
De rien :-) ..
merci infiniment
Merci encore pour le suivis
Rapport de ZHPFix 1.12.3373 par Nicolas Coolman, Update du 24/11/2011
Fichier d'export Registre :
Run by Moe at 12/6/2011 7:23:33 AM
Windows 7 Home Premium Edition, 64-bit Service Pack 1 (Build 7601)
Web site : http://www.premiumorange.com/zeb-help-process/zhpfix.html
========== Registry Key ==========
NOT FOUND Key: CLSID BHO: {E38FA08E-F56A-4169-ABF5-5C71E3C153A1}
DELETED Key: SearchScopes :{64607F26-1AF7-4976-90C6-84450D77EC12}
========== File ==========
DELETED File: c:\windows\tasks\facebookupdatetaskusers-1-5-21-392288041-244505017-2593837476-1001core.job
DELETED File: c:\windows\tasks\facebookupdatetaskusers-1-5-21-392288041-244505017-2593837476-1001ua.job
========== Task ==========
DELETED Task: CLMLSvc
DELETED Task: DVDAgent
========== Summary ==========
2 : Registry Key
2 : File
2 : Task
End of clean in 04mn AMs
========== Report File ==========
C:\ZHP\ZHPFix[R1].txt - 12/5/2011 2:07:06 PM [1992]
C:\ZHP\ZHPFix[R2].txt - 12/6/2011 7:23:33 AM [958]-
# DelFix v8.7 - Rapport créé le 06/12/2011 à 07:49:04
# Mis à jour le 01/12/11 à 20h par Xplode
# Système d'exploitation : Windows 7 Home Premium Service Pack 1 (64 bits)
# Nom d'utilisateur : Moe - MOE-PC (Administrateur)
# Exécuté depuis : C:\Users\Moe\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\CQKU4HFH\delfix[1].exe
# Option [Suppression]
~~~~~~ Dossiers(s) ~~~~~~
Supprimé : C:\Qoobox
Supprimé : C:\_OTM
Supprimé : C:\ZHP
Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZHP
Supprimé : C:\Program Files (x86)\ZHPDiag
~~~~~~ Fichier(s) ~~~~~~
Supprimé : C:\ComboFix.txt
Supprimé : C:\JavaRa.log
Supprimé : C:\PhysicalDisk0_MBR.bin
Supprimé : C:\TDSSKiller.2.6.21.0_04.12.2011_11.04.24_log.txt
Supprimé : C:\Users\Moe\Desktop\ZHPDiag2.exe
Supprimé : C:\Users\Moe\Desktop\ZHPFixReport.txt
Supprimé : C:\Users\Public\Desktop\ZHPDiag.lnk
Supprimé : C:\Users\Public\Desktop\ZHPFix.lnk
Supprimé : C:\Users\Public\Desktop\MBRCheck.lnk
Supprimé : C:\Windows\grep.exe
Supprimé : C:\Windows\PEV.exe
Supprimé : C:\Windows\NIRCMD.exe
Supprimé : C:\Windows\MBR.exe
Supprimé : C:\Windows\SED.exe
Supprimé : C:\Windows\SWREG.exe
Supprimé : C:\Windows\SWSC.exe
Supprimé : C:\Windows\SWXCACLS.exe
Supprimé : C:\Windows\Zip.exe
~~~~~~ Registre ~~~~~~
Clé Supprimée : HKLM\SOFTWARE\OldTimer Tools
Clé Supprimée : HKLM\SOFTWARE\Swearware
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ZHPDiag_is1
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\combofix.exe
~~~~~~ Autres ~~~~~~
-> Prefetch Vidé
DelFix[R1].txt - [1734 octets] - [06/12/2011 07:43:06]
DelFix[S1].txt - [1716 octets] - [06/12/2011 07:49:04]
########## EOF - C:\DelFix[S1].txt - [1840 octets] ##########
Contributeur sécuritéBonjour,
On a presque fini, juste quelques lignes à fixer :
Copie tout le texte présent en gras ci-dessous ( tu le selectionnes avec ta souris / Clique droit dessus et choisis "copier" ou fait Ctrl+C )
O2 - BHO: NetAssistantBHO [64Bits] - {E38FA08E-F56A-4169-ABF5-5C71E3C153A1} Orphean Key => Softomate Toolbar
O69 - SBI: SearchScopes [HKCU] {64607F26-1AF7-4976-90C6-84450D77EC12} - (Ask.com) - https://fr.ask.com/?o=0&l=dir&ad=dirN
[MD5.00000000000000000000000000000000] [APT] [CLMLSvc] (...) -- c:\Program Files (x86)\Hewlett-Packard\TouchSmart\Music\Kernel\CLML\CLMLSvc.exe (.not file.)
[MD5.00000000000000000000000000000000] [APT] [DVDAgent] (...) -- c:\Program Files (x86)\Hewlett-Packard\Media\DVD\DVDAgent.exe (.not file.)
O39 - APT:Automatic Planified Task - C:\Windows\Tasks\FacebookUpdateTaskUserS-1-5-21-392288041-244505017-2593837476-1001Core.job
O39 - APT:Automatic Planified Task - C:\Windows\Tasks\FacebookUpdateTaskUserS-1-5-21-392288041-244505017-2593837476-1001UA.job
Puis Lance ZHPFix depuis le raccourci du bureau .
* Une fois l'outil ZHPFix ouvert , clique sur le bouton [ H ] ( "coller les lignes Helper" ) .
* Dans l'encadré principal tu verras donc les lignes que tu as copié précédemment apparaitrent .
Vérifie que toutes les lignes que je t'ai demandé de copier (et seulement elles) sont dans la fenêtre.
Clique sur le bouton GO
Copie/Colle le rapport à l'écran dans ton prochain message.
Pour finir :
Mise à jour Adobe reader
* Télécharge Adobe reader à partir :>>>>Ce lien<<<< en décochant la case : installer McAfee Security Scan Plus (facultatif)
* Désinstalle ta version d'adobe par : ajout/suppression de programme
* Exécute le fichier téléchargé pour installation en suivant les instructions.
Mise à jour de Java:
* Tu peux vérifier ta Console Java en cliquant sur ce lien :https://www.java.com/fr/download/uninstalltool.jsp
* Installe la nouvelle version si besoin (dans ce cas désinstalle avant l'ancienne version).
voici pour desinstaller JavaRa:
* Télécharge ce fichier à partir ce lien : http://raproducts.org/click/click.php?id=1
* Décompresse JavaRa sur le Bureau (Clic droit > Extraire tout).
* Double-clique (clic droit "en tant qu'administrateur" pour Vista) sur le répertoire JavaRa.
* Puis double-clique sur le fichier JavaRa.exe (le exe peut ne pas s'afficher).
* Choisis Français puis clique sur Select.
* Clique sur Recherche de mises à jour.
* Sélectionne Mettre à jour via jucheck.exe puis clique sur Rechercher.
* Autorise le processus à se connecter s'il le demande, clique sur Installer et suis les instructions d'installation qui prennent quelques minutes.
* L'installation est terminée, reviens à l'écran de JavaRa et clique sur Effacer les anciennes versions.
* Clique sur Oui pour confirmer. Laisse travailler et clique ensuite sur OK, puis
une deuxième fois sur OK.
* Un rapport va s'ouvrir. Poste-le dans ta prochaine réponse.
* Ferme l'application.
Note : le rapport se trouve aussi dans C:\ sous le nom JavaRa.log.
Updatechecker :
Téléchage updatechecker pour t'indiquer les logiciels qui ne sont pas à jour et te permet aussi d'effectuer ces mises à jour
===========================================PurRa (éditeur de JavaRa) :
Telecharge ici : PureRa (par l'editeur de JavaRa)
Lance-le (clic droit "executer en tant qu'administrateur" pour Vista/7)
=> Configuration
clique sur "Clean"
L'outil va faire son scan puis son nettoyage
à la fin du rapport tu auras une ligne comme ca :
Total space cleaned: xxxxxxxx bytes
transmets juste cette ligne .
**NettoyageSuppression des outils de désinfections: * Télécharge Delfix sur ton bureau. * Lance le, tape suppression puis valide * Patiente pendant le scan jusqu'à l'ouverture du rapport. * Copie/Colle le contenu du rapport dans ta prochaine réponse. Note : Le rapport se trouve également sous C:\DelFix.txt * Tu peux le desinstaller =========================================== <code>Nettoyage des fichiers et des clés de registre :
* Télécharge et installe CCleaner version Slim
* Lance-le.(clic droit "en tant qu'administrateur" pour Vista et Seven) Va dans Options puis
* Avancé et décoche la case Effacer uniquement les fichiers etc....
* Va dans Nettoyeur, choisis Analyse. Une fois terminé, lance le nettoyage.
* Ensuite, choisis Registre, puis Chercher des erreurs. Une fois terminé, répare toutes les erreurs tant de fois qu il en trouve a l analyse .
** Aide ici : https://www.malekal.com/tutoriel-ccleaner/
Tu peux utiliser Ccleaner une fois par semaine
Purger les points de restauration système:
* Désactive et réactive la restauration de système en suivant les procédures indiquées dans ces liens :
Windows XP
Windows Vista
Windows 7
* Après avoir vidé la restauration du système, il est nécessaire de créer un nouveau point de restauration ...
Conseils :
1/ Je te conseille d'utiliser le navigateur Firefox et d'installer les modules
complémentaires WOT pour t'indiquer les fichiers douteux et Adblock plus pour bloquer les publicités...
2/ Aussi tu peux garder Malwarebytes et l'utiliser aussi une fois par semaine.
3/ Un peu de lecture :
* Les dangers du Peer-To-Peer, Emule etc..
* Comment Sécuriser son ordinateur...
*Pourquoi et comment je me fais infecter
4/ Défragmente tes disques dur par defraggler
Un gros Merci mon ami,
En general tout est Nickel.
voici le dernier rapport
http://www.toofiles.com/fr/oip/documents/txt/1036_zhpdiag.html -
1/
Tu peux effectuer ces étapes pour activer la mise à jour automatique de ton windows
2/
Redémarre ton PC et prépare stp un dernier rapport ZHPDiag pour vérification
3/
Comment va ton PC maintenant ?
Bonne nuit
A demain
MIs a jour WIN7 SP1 complete mais y a pas de SP2 tel que vous avez mentionne !
AJavaRa 1.16 Removal Log.
Report follows after line.
The JavaRa removal process was started on Mon Dec 05 14:39:48 2011
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0001-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0002-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0003-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0004-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0005-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0006-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0007-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0008-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0009-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0010-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0011-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0012-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0013-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0014-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0015-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0016-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0017-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0018-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0019-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0020-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0021-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions\{CAFEEFAC-0016-0022-ABCDEFFDCBA}. The error returned was 124.
Found and removed: Applications\java.exe
Found and removed: Applications\javaw.exeA
Found and removed: JavaPlugin.FamilyVersionSupport
Found and removed: CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0025-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0025-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0026-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0026-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0027-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0027-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0028-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0028-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0029-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0029-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0030-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0030-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-FFFF-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBC}
Found and removed: JavaScript
Found and removed: JavaScript Author
Found and removed: JavaScript1.1
Found and removed: JavaScript1.1 Author
Found and removed: JavaScript1.2
Found and removed: JavaScript1.2 Author
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0015-0000-FFFF-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{E19F9331-3110-11D4-991C-005004D3B3DB}
Found and removed: Software\Classes\JavaPlugin.160_17
Found and removed: Software\JavaSoft\Java Update
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\JavaPlugin
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_02
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_03
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_04
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.2
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.2.0_01
Found and removed: SOFTWARE\Microsoft\Active Setup\Installed Components\{08B0E5C0-4FCB-11CF-AAA5-00401C608500}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4A03706F-666A-4037-7777-5F2748764D10}
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1.2
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1.3
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.2
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.2.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.3
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.3.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.4
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.4.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.4.2
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.5
Finished reporting.
The JavaRa removal process was started on Mon Dec 05 14:40:32 2011
Found and rem -
1/
Fais stp la mise à jour de ton Windows pour passer au pack2
2/Mise à jour de Java:
1- Net Assistant je ne le vois lus en utilisant le logiciel suggere
2- le rapport est ci bas
3- Non Ssystem n<est plus la depuis hier
Fichier d'export Registre : C:\ZHP\ZHPExportRegistry-12-5-2011-2-07-06 PM.txt
Run by Moe at 12/5/2011 2:07:06 PM
Windows 7 Home Premium Edition, 64-bit (Build 7600)
NOT FOUND Key: HKLM\Software\Freeze.com
DELETED Key: HKLM\Software\WOW6432Node\freeze.com
========== Registry Value ==========
No Value in Standard Profile Register Key FirewallRaz :
No Value in Domain Profile Register Key FirewallRaz :
DELETED FirewallRaz (None) : {F90FC4B3-2B2A-45CE-9ED1-0FD2977A51D7}
DELETED FirewallRaz (Domain) : NetPres-In-TCP-NoScope
DELETED FirewallRaz (Domain) : NetPres-Out-TCP-NoScope
DELETED FirewallRaz (None) : NetPres-WSD-In-UDP
DELETED FirewallRaz (None) : NetPres-WSD-Out-UDP
DELETED FirewallRaz (Public) : NetPres-In-TCP
DELETED FirewallRaz (Public) : NetPres-Out-TCP
DELETED FirewallRaz (None) : {8E8DF1BB-8E20-4593-A8B1-A33B47A27921}
DELETED FirewallRaz (None) : {310FBD4C-99B2-4778-B47B-ED8F31E53B4F}
DELETED FirewallRaz (None) : {D201519D-687C-40A1-8BD9-B873DC1B4444}
DELETED FirewallRaz (None) : {522EE037-FAFB-4E5F-AB1C-BEF6D5727300}
DELETED FirewallRaz (None) : {E1CC441B-5DF2-4A33-87CC-479E4DC9ED95}
DELETED FirewallRaz (None) : {58B112E4-D81B-4FEF-988B-B992B8961395}
DELETED FirewallRaz (None) : {8E53D523-D687-482B-82C0-A89EBE3A9049}
DELETED FirewallRaz (None) : {5183714C-F076-4ACA-9F2B-B4C647AFB6A6}
========== Repertory ==========
DELETED Flash Cookies: 474
DELETED File: c:\users\moe\desktop\doratheexplorersnapshots.lnk
DELETED File: c:\users\moe\appdata\roaming\microsoft\internet explorer\quick launch\wildtangent games app - hp.lnk
DELETED Flash Cookies: 329
2 : Registry Key
17 : Registry Value
1 : Repertory
3 : File
End of clean in 01mn AMs
C:\ZHP\ZHPFix[R1].txt - 12/5/2011 2:07:06 PM [1939] -
1/
Est ce que tu n'as pas essayé de désinstaller ces logiciels ?
O42 - Logiciel: Freeze.com NetAssistant -
O42 - Logiciel: NetAssistant -
Si tu n'as pas pu, utilise le logiciel ci-dessous pour les désinstaller :
Télécharge Revo-uninstaller
Exécute ce fichier pour installation
*******Aide Revo-uninstaller*******
2/
[HKLM\Software\Freeze.com] => Infection BT (Adware.BHO)
[HKLM\Software\WOW6432Node\freeze.com] => Infection BT (Adware.BHO)
OPT:O4 - Global Startup: C:\Users\Moe\Desktop\DoraTheExplorerSnapshots.lnk . (...) -- C:\Program Files (x86)\DoraTheExplorerSnapshots\Dora.exe (.not file.)
OPT:O4 - Global Startup: C:\Users\Moe\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\WildTangent Games App - hp.lnk . (.WildTangent.) -- C:\Program Files (x86)\WildTangent Games\App\GameConsole-wt.exe
FirewallRAZ
EmptyFlash
3/
Est ce que : System Fix est il encore présent ?
_ _ _ Fish66_ _ _ I''"""""I_ _ membre _ _I''"""""I_ _ contributeur sécurité_ _ _
¤¤¤ Le meilleur remède pour tous les problèmes, c'est la patience.... ¤¤¤ -
http://www.toofiles.com/fr/oip/documents/txt/7180_zhpdiag.html
Lance ZHPDiag depuis le bureau puis prépare stp un nouveau rapport ZHPDiag ( à héberger)
Re,
========== FILES ==========
File/Folder c:\windows\system32\srrstr.dll not found.
DllUnregisterServer procedure not found in c:\windows\system32\systemcpl.dll
c:\windows\system32\systemcpl.dll moved successfully.
File/Folder c:\windows\system32\termsrv.dll not found.
File/Folder c:\program files (x86)\Freeze.com\NetAssistant\NetAssistant.dll not found.
========== REGISTRY ==========
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks\\{E38FA08E-F56A-4169-ABF5-5C71E3C153A1} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}\ deleted successfully.
OTM by OldTimer - Version 3.1.19.0 log created on 12052011_130008 -
* Télécharge OTM (OldTimer) sur ton Bureau
ICI >> OTM (OldTimer)
* Double clic "OTMoveIt3.exe"
* Utilisateurs Windows Vista / 7 Clic droit sur "OTMoveIt3.exe" choisis "exécuter en tant qu'administrateur" afin de le lancer.
- Copie (Ctrl+C) le texte suivant en gras ci-dessous :
:files
:Reg
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}"=-
- Colle (Ctrl+V) le texte précédemment copié dans le cadre: Paste Instructions for Items to be Moved.
- Clique maintenant sur le bouton MoveIt!
Si un fichier ou dossier ne peut pas être supprimé immédiatement, le logiciel te demandera de redémarrer.
Accepte en cliquant sur YES.
- Poste le rapport situé dans ce dossier : C:\_OTMoveIt\MovedFiles\
Le nom du rapport correspond au moment de sa création : date_heure.log
et voila
ComboFix 11-12-05.01 - Moe 05/12/2011 8:12.1.4 - x64
Microsoft Windows 7 Home Premium 6.1.7600.0.1252.2.1033.18.3894.2289 [GMT -5:00]
Running from: c:\users\Moe\Desktop\ComboFix.exe
AV: Norton Internet Security *Disabled/Updated* {88C95A36-8C3B-2F2C-1B8B-30FCCFDC4855}
FW: Norton Internet Security *Disabled* {B0F2DB13-C654-2E74-30D4-99C9310F0F2E}
SP: Norton Internet Security *Disabled/Updated* {33A8BBD2-AA01-20A2-213B-0B8EB45B02E8}
SP: STOPzilla Anti-Spyware *Disabled/Updated* {B2E69928-50DC-94CA-6A80-AAB054008761}
SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\Install.exe
c:\programdata\fIJsmsUwPvQ.exe
c:\programdata\NOQiG1wfzvu38F.exe
c:\users\Moe\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\System Fix.lnk
c:\users\Moe\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\System Fix
c:\users\Moe\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\System Fix\System Fix.lnk
c:\users\Moe\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\System Fix\Uninstall System Fix.lnk
c:\users\Moe\VoiceEditingV1_Update.exe
c:\windows\SysWow64\odbcad32.exe
c:\windows\system32\srrstr.dll . . . . Failed to delete
c:\windows\system32\systemcpl.dll . . . . Failed to delete
c:\windows\system32\termsrv.dll . . . . Failed to delete
((((((((((((((((((((((((( Files Created from 2011-11-05 to 2011-12-05 )))))))))))))))))))))))))))))))
2011-12-05 13:19 . 2011-12-05 13:19 -------- d-----w- c:\users\Default\AppData\Local\temp
2011-12-04 19:42 . 2011-12-04 19:42 512 ----a-w- C:\PhysicalDisk0_MBR.bin
2011-12-04 19:38 . 2011-12-04 19:42 -------- d-----w- C:\ZHP
2011-12-04 19:37 . 2011-12-04 19:42 -------- d-----w- c:\program files (x86)\ZHPDiag
2011-12-04 16:37 . 2011-12-04 16:37 -------- d-----w- c:\users\Moe\AppData\Roaming\Malwarebytes
2011-12-04 16:37 . 2011-12-04 16:37 -------- d-----w- c:\programdata\Malwarebytes
2011-12-04 16:37 . 2011-12-04 16:37 -------- d-----w- c:\program files (x86)\Malwarebytes' Anti-Malware
2011-12-04 16:37 . 2011-08-31 22:00 25416 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-12-04 16:29 . 2011-12-04 16:29 -------- d-----w- c:\programdata\PC Tools
2011-12-04 16:17 . 2011-12-04 16:17 -------- d-----w- c:\program files (x86)\STOPzilla!
2011-12-04 16:17 . 2011-12-04 16:17 -------- d-----w- c:\program files (x86)\Common Files\iS3
2011-12-04 16:17 . 2011-12-05 13:22 -------- d-----w- c:\programdata\STOPzilla!
2011-12-02 12:11 . 2011-11-21 11:40 8822856 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{1DECB485-848C-46C2-9DD5-9ADDCA8222D7}\mpengine.dll
2011-12-01 00:45 . 2011-12-01 00:45 547880 ----a-r- c:\windows\SysWow64\SZComp5.dll
2011-12-01 00:45 . 2011-12-01 00:45 24616 ----a-r- c:\windows\SysWow64\SZIO5.dll
2011-12-01 00:45 . 2011-12-01 00:45 134184 ----a-r- c:\windows\SysWow64\IS3HTUI5.dll
2011-12-01 00:45 . 2011-12-01 00:45 68648 ----a-r- c:\windows\SysWow64\IS3Hks5.dll
2011-12-01 00:45 . 2011-12-01 00:45 482344 ----a-r- c:\windows\SysWow64\SZBase5.dll
2011-12-01 00:45 . 2011-12-01 00:45 457768 ----a-r- c:\windows\SysWow64\IS3DBA5.dll
2011-12-01 00:45 . 2011-12-01 00:45 392232 ----a-r- c:\windows\SysWow64\IS3UI5.dll
2011-12-01 00:45 . 2011-12-01 00:45 30248 ----a-r- c:\windows\SysWow64\IS3XDat5.dll
2011-12-01 00:45 . 2011-12-01 00:45 232488 ----a-r- c:\windows\SysWow64\IS3Win325.dll
2011-12-01 00:45 . 2011-12-01 00:45 105512 ----a-r- c:\windows\SysWow64\IS3Inet5.dll
2011-12-01 00:45 . 2011-12-01 00:45 101416 ----a-r- c:\windows\SysWow64\IS3Svc5.dll
2011-12-01 00:45 . 2011-12-01 00:45 740392 ----a-r- c:\windows\SysWow64\IS3Base5.dll
2011-11-12 17:07 . 2011-11-12 17:07 -------- d-----w- c:\users\Moe\AppData\Local\Facebook
2011-11-09 11:57 . 2011-10-01 05:28 886784 ----a-w- c:\program files\Common Files\System\wab32.dll
2011-11-09 11:57 . 2011-10-01 04:43 708608 ----a-w- c:\program files (x86)\Common Files\System\wab32.dll
2011-11-09 11:57 . 2011-09-29 16:24 1897328 ----a-w- c:\windows\system32\drivers\tcpip.sys
2011-11-09 11:57 . 2011-09-29 04:09 3141120 ----a-w- c:\windows\system32\win32k.sys
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2011-10-01 03:21 . 2011-10-11 22:07 1638912 ----a-w- c:\windows\system32\mshtml.tlb
2011-10-01 02:59 . 2011-10-11 22:07 1638912 ----a-w- c:\windows\SysWow64\mshtml.tlb
2011-09-26 16:21 . 2011-09-26 16:21 74768 ----a-r- c:\windows\SysWow64\drivers\SZKG64.sys
2011-09-26 16:21 . 2011-09-26 16:21 74768 ----a-r- c:\windows\SysWow64\drivers\is3srv64.sys
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
"{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}"= "c:\program files (x86)\Freeze.com\NetAssistant\NetAssistant.dll" [2011-06-22 1718472]
[HKEY_CLASSES_ROOT\clsid\{e38fa08e-f56a-4169-abf5-5c71e3c153a1}]
[HKEY_CLASSES_ROOT\NetAssistant.NetAssistantBHO.1]
[HKEY_CLASSES_ROOT\TypeLib\{1E8FC16F-4C51-49C4-BC9B-4FC24BDDCEE7}]
[HKEY_CLASSES_ROOT\NetAssistant.NetAssistantBHO]
[HKEY_LOCAL_MACHINE\Wow6432Node\~\Browser Helper Objects\{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}]
2011-06-22 16:30 1718472 ----a-w- c:\program files (x86)\Freeze.com\NetAssistant\NetAssistant.dll
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"HPAdvisorDock"="c:\program files (x86)\Hewlett-Packard\HP Advisor\Dock\HPAdvisorDock.exe" [2010-01-28 1712184]
"LightScribe Control Panel"="c:\program files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe" [2010-01-22 2363392]
"Skype"="c:\program files (x86)\Skype\Phone\Skype.exe" [2011-01-26 15026056]
"Itibiti.exe"="c:\program files (x86)\Itibiti Soft Phone\Itibiti.exe" [2011-11-08 5284352]
"Facebook Update"="c:\users\Moe\AppData\Local\Facebook\Update\FacebookUpdate.exe" [2011-11-12 137536]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"StartCCC"="c:\program files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2010-01-22 98304]
"Microsoft Default Manager"="c:\program files (x86)\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2010-05-10 439568]
"NortonOnlineBackupReminder"="c:\program files (x86)\Symantec\Norton Online Backup\Activation\NOBuActivation.exe" [2009-12-04 3331944]
"Adobe Reader Speed Launcher"="c:\program files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-02-28 35696]
"HP Software Update"="c:\program files (x86)\Hp\HP Software Update\HPWuSchd2.exe" [2008-12-08 54576]
"TkBellExe"="c:\program files (x86)\Real\RealPlayer\Update\realsched.exe" [2010-12-25 274608]
"SunJavaUpdateSched"="c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2011-04-08 254696]
"Malwarebytes' Anti-Malware"="c:\program files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe" [2011-08-31 449608]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
"ConsentPromptBehaviorUser"= 3 (0x3)
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
"mixer"=wdmaud.drv
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
Notification Packages REG_MULTI_SZ DPPassFilter scecli
Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R2 HP Wireless Assistant Service;HP Wireless Assistant Service;c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWA_Service.exe [2009-12-16 102968]
R3 BBSvc;Bing Bar Update Service;c:\program files (x86)\Microsoft\BingBar\BBSvc.EXE [2011-02-28 183560]
R3 GamesAppService;GamesAppService;c:\program files (x86)\WildTangent Games\App\GamesAppService.exe [2010-10-12 206072]
R3 JLTECH0227;Dual Mode Camera;c:\windows\system32\Drivers\jl2005c.sys [x]
R3 netw5v64;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 64 Bit;c:\windows\system32\DRIVERS\netw5v64.sys [x]
R3 Point64;Microsoft IntelliPoint Filter Driver;c:\windows\system32\DRIVERS\point64.sys [x]
R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys [x]
R3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt64win7.sys [x]
R3 SrvHsfHDA;SrvHsfHDA;c:\windows\system32\DRIVERS\VSTAZL6.SYS [x]
R3 SrvHsfV92;SrvHsfV92;c:\windows\system32\DRIVERS\VSTDPV6.SYS [x]
R3 SrvHsfWinac;SrvHsfWinac;c:\windows\system32\DRIVERS\VSTCNXT6.SYS [x]
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [x]
R3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\DRIVERS\yk62x64.sys [x]
S0 szkg5;szkg5;c:\windows\SySWOW64\DRIVERS\szkg64.sys [2011-09-26 74768]
S1 DVMIO;DeviceVM IO Service;c:\windows\system32\DRIVERS\dvmio.sys [x]
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [x]
S2 AESTFilters;Andrea ST Filters Service;c:\windows\System32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_1c0e2d1db9f5b08e\AESTSr64.exe [2009-03-03 89600]
S2 AMD External Events Utility;AMD External Events Utility;c:\windows\system32\atiesrxx.exe [x]
S2 DvmMDES;DeviceVM Meta Data Export Service;c:\swsetup\QuickWeb\QW.SYS\config\DVMExportService.exe [2010-02-08 338168]
S2 hpsrv;HP Service;c:\windows\system32\Hpservice.exe [x]
S2 HPWMISVC;HPWMISVC;c:\program files\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe [2010-01-18 20480]
S2 MBAMService;MBAMService;c:\program files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe [2011-08-31 366152]
S2 NIS;Norton Internet Security;c:\program files (x86)\Norton Internet Security\Engine\17.0.0.136\ccSvcHst.exe [2009-08-24 126392]
S2 UNS;Intel(R) Management & Security Application User Notification Service;c:\program files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe [2010-03-18 2320920]
S2 vcsFPService;Validity VCS Fingerprint Service;c:\windows\system32\vcsFPService.exe [2010-01-06 2184496]
S3 amdkmdag;amdkmdag;c:\windows\system32\DRIVERS\atipmdag.sys [x]
S3 amdkmdap;amdkmdap;c:\windows\system32\DRIVERS\atikmpag.sys [x]
S3 HECIx64;Intel(R) Management Engine Interface;c:\windows\system32\DRIVERS\HECIx64.sys [x]
S3 Impcd;Impcd;c:\windows\system32\DRIVERS\Impcd.sys [x]
S3 intelkmd;intelkmd;c:\windows\system32\DRIVERS\igdpmd64.sys [x]
S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [x]
S3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys [x]
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
2010-01-22 18:06 451872 ----a-w- c:\program files (x86)\Common Files\LightScribe\LSRunOnce.exe
Contents of the 'Scheduled Tasks' folder
2011-12-03 c:\windows\Tasks\FacebookUpdateTaskUserS-1-5-21-392288041-244505017-2593837476-1001Core.job
- c:\users\Moe\AppData\Local\Facebook\Update\FacebookUpdate.exe [2011-11-12 17:07]
2011-12-04 c:\windows\Tasks\FacebookUpdateTaskUserS-1-5-21-392288041-244505017-2593837476-1001UA.job
--------- x86-64 -----------
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2010-01-22 166424]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2010-01-22 390680]
"Persistence"="c:\windows\system32\igfxpers.exe" [2010-01-22 410136]
"SysTrayApp"="c:\program files\IDT\WDM\sttray64.exe" [2010-01-14 487424]
"HP Quick Launch"="c:\program files\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe" [2010-01-18 451072]
"SmartMenu"="c:\program files\Hewlett-Packard\HP MediaSmart\SmartMenu.exe" [2010-01-20 611896]
"HPToneControl"="c:\program files\Hewlett-Packard\HPToneControl\HPTonectl.exe" [2009-08-20 107832]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2010-03-01 172032]
"HPWirelessAssistant"="c:\program files\Hewlett-Packard\HP Wireless Assistant\DelayedAppStarter.exe" [2009-12-16 8192]
"IntelliPoint"="c:\program files\Microsoft IntelliPoint\ipoint.exe" [2010-07-21 2327952]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"LoadAppInit_DLLs"=0x0
------- Supplementary Scan -------
uStart Page = hxxp://www.google.ca/
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
IE: E&xport to Microsoft Excel - c:\progra~2\MICROS~1\Office12\EXCEL.EXE/3000
IE: Voice Editing Launcher - c:\program files (x86)\Panasonic\Voice Editing\VEd1_IEMenu.html
TCP: DhcpNameServer = 192.168.0.1
- - - - ORPHANS REMOVED - - - -
HKLM-Run-SynTPEnh - c:\program files (x86)\Synaptics\SynTP\SynTPEnh.exe
AddRemove-{495A8A3C-8FD0-4C46-9979-95C26181A1AB} - c:\program files (x86)\InstallShield Installation Information\{495A8A3C-8FD0-4C46-9979-95C26181A1AB}\setup.exe
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\NIS]
"ImagePath"="\"c:\program files (x86)\Norton Internet Security\Engine\17.0.0.136\ccSvcHst.exe\" /s \"NIS\" /m \"c:\program files (x86)\Norton Internet Security\Engine\17.0.0.136\diMaster.dll\" /prefetch:1"
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10s_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10s_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
@="{FAB3E735-69C7-453B-A446-B6823C6DF1C9}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10s.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.10"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10s.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
------------------------ Other Running Processes ------------------------
c:\program files (x86)\DigitalPersona\Bin\DPAgent.exe
c:\program files (x86)\Common Files\LightScribe\LSSrvc.exe
c:\program files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
c:\program files (x86)\Microsoft\BingBar\SeaPort.EXE
c:\program files (x86)\Real\RealPlayer\update\RealOneMessageCenter.exe
c:\program files (x86)\Skype\Plugin Manager\skypePM.exe
Completion time: 2011-12-05 08:27:08 - machine was rebooted
ComboFix-quarantined-files.txt 2011-12-05 13:27
Pre-Run: 406,806,212,608 bytes free
Post-Run: 407,559,569,408 bytes free
- - End Of File - - 2E2A20A6EF961619EA61570F886B100C -
Contributeur sécuritéRe,
Est ce que tu as récupéré les icones disparus ?
Si oui tu peux effectuer les procédures indiquées >>> ICI <<<
Bonjour Fish66, et voici le rapport demandE
RogueKiller V6.1.12 [12/02/2011] by Tigzy
mail: tigzyRK<at>gmail<dot>com
Feedback: http://www.geekstogo.com/forum/files/file/413-roguekiller/
Blog: http://tigzyrk.blogspot.com
Operating System: Windows 7 (6.1.7600 ) 64 bits version
Started in : Normal mode
User: Moe [Admin rights]
Mode: Shortcuts HJfix -- Date : 12/05/2011 07:19:13
¤¤¤ Bad processes: 0 ¤¤¤
¤¤¤ Driver: [NOT LOADED] ¤¤¤
¤¤¤ File attributes restored: ¤¤¤
Desktop: Success 0 / Fail 0
Quick launch: Success 0 / Fail 0
Programs: Success 1 / Fail 0
Start menu: Success 32 / Fail 0
User folder: Success 15104 / Fail 0
My documents: Success 126 / Fail 0
My favorites: Success 49 / Fail 0
My pictures: Success 28 / Fail 0
My music: Success 10 / Fail 0
My videos: Success 2 / Fail 0
Local drives: Success 1942 / Fail 0
Backup: [FOUND] Success 0 / Fail 254
Drives:
[C:] \Device\HarddiskVolume2 -- 0x3 --> Restored
[D:] \Device\HarddiskVolume3 -- 0x3 --> Restored
[E:] \Device\HarddiskVolume4 -- 0x3 --> Restored
[F:] \Device\CdRom0 -- 0x5 --> Skipped
¤¤¤ Infection : Rogue.FakeHDD ¤¤¤
Finished : << RKreport[3].txt >>
RKreport[1].txt ; RKreport[2].txt ; RKreport[3].txt -
Relance RogueKiller puis tapes 6 et poste le rapport stp
- 1
- 2
