System Fix Error Trojan
RésoluBesoin de votre aide SVP. Mon ordi est infecte par System Fix Error.
Jai lu pas mal vos articles alors je vous joints les rapports requis.
RogueKiller V6.1.12 [12/02/2011] by Tigzy
mail: tigzyRK<at>gmail<dot>com
Feedback: http://www.geekstogo.com/forum/files/file/413-roguekiller/
Blog: http://tigzyrk.blogspot.com
Operating System: Windows 7 (6.1.7600 ) 64 bits version
Started in : Safe mode with network support
User: Moe [Admin rights]
Mode: Remove -- Date : 12/04/2011 11:40:24
¤¤¤ Bad processes: 2 ¤¤¤
[SUSP PATH] mbam-setup-1.51.2.1300.exe -- C:\Users\Moe\Desktop\mbam-setup-1.51.2.1300.exe -> KILLED [TermProc]
[SUSP PATH] mbam-setup-1.51.2.1300.tmp -- C:\Users\Moe\AppData\Local\Temp\is-AL6C0.tmp\mbam-setup-1.51.2.1300.tmp -> KILLED [TermProc]
¤¤¤ Registry Entries: 10 ¤¤¤
[SUSP PATH] HKCU\[...]\Run : fIJsmsUwPvQ.exe (C:\ProgramData\fIJsmsUwPvQ.exe) -> DELETED
[SUSP PATH] HKCU\[...]\Run : Spyware Doctor with AntiVirus (C:\Users\Moe\Desktop\sdasetup_revwire207[1].exe -min) -> DELETED
[WallPP] HKCU\[...]\Desktop : Wallpaper () -> REPLACED (C:\Users\Moe\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg)
[HJ] HKCU\[...]\Advanced : Start_ShowMyComputer (0) -> REPLACED (1)
[HJ] HKCU\[...]\Advanced : Start_ShowSearch (0) -> REPLACED (1)
[HJ] HKLM\[...]\NewStartPanel : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
[HJ] HKCU\[...]\ClassicStartMenu : {59031a47-3f72-44a7-89c5-5595fe6b30ee} (1) -> REPLACED (0)
[HJ] HKLM\[...]\NewStartPanel : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
[HJ] HKCU\[...]\ClassicStartMenu : {20D04FE0-3AEA-1069-A2D8-08002B30309D} (1) -> REPLACED (0)
[HJ] HKCU\[...]\ClassicStartMenu : {645FF040-5081-101B-9F08-00AA002F954E} (1) -> REPLACED (0)
¤¤¤ Particular Files / Folders: ¤¤¤
¤¤¤ Driver: [NOT LOADED] ¤¤¤
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
Finished : << RKreport[1].txt >>
RKreport[1].txt
29 réponses
Le fil porte sur une infection par System Fix Error sur un PC Windows 7 et sur l’utilisation de RogueKiller pour détecter et supprimer les processus malveillants et les entrées de registre associées. Des conseils promeuvent l’exécution en administrateur et l’application des suppressions indiquées par RogueKiller, aboutissant à la création de RKreport[1].txt et à l’élimination de processus et d’entrées Run malveillantes. En cas d’échec ou pour vérification, plusieurs échanges préconisent d’activer les mises à jour automatiques de Windows, puis de générer un nouveau rapport ZHPDiag et d’utiliser ComboFix pour nettoyer d’éventuels restes. Le quatrième échange signale des éléments résiduels possibles et des composants critiques non supprimés, soulignant que le nettoyage peut nécessiter plusieurs essais et outils complémentaires.
Malwarebytes' Anti-Malware 1.51.2.1300
www.malwarebytes.org
Version de la base de données: 8309
Windows 6.1.7600 (Safe Mode)
Internet Explorer 8.0.7600.16385
04/12/2011 11:47:32 AM
mbam-log-2011-12-04 (11-47-32).txt
Type d'examen: Examen rapide
Elément(s) analysé(s): 171087
Temps écoulé: 2 minute(s), 26 seconde(s)
Clé(s) du Registre infectée(s): 0
Valeur(s) du Registre infectée(s): 0
Elément(s) de données du Registre infecté(s): 0
Dossier(s) infecté(s): 0
Fichier(s) infecté(s): 5
c:\$Recycle.Bin\s-1-5-21-392288041-244505017-2593837476-1001\$R6W4D2N.exe (Adware.InstallCore) -> Quarantined and deleted successfully.
c:\Users\Moe\AppData\Local\Temp\71D5.tmp (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\Moe\AppData\Local\Temp\chromeupdtr.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\Moe\AppData\Local\Temp\EA0.tmp (Trojan.FakeAlert) -> Quarantined and deleted successfully.
c:\Users\Moe\AppData\Local\Temp\googleupdate.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully. -
Contributeur sécuritéSalut,
Supprime ta version de RogueKiller (ancienne) puis fais ceci stp :
* Télécharge sur le bureau RogueKiller (par tigzy)
https://www.luanagames.com/index.fr.html
*( Sous Vista/Seven,clique droit, lancer en tant qu'administrateur )
* Quitte tous tes programmes en cours
* Lance RogueKiller.exe.
* Lorsque demandé, tape 1 et valide
*Si le rogue empêche le lancement du programme, Renomme (RogueKiller) en "winlogon" ou "firefox". Sinon renomme le en winlogon.exe ou firefox.exe (rajouter l'extension .exe)
* Un rapport (RKreport.txt) a du se créer à côté de l'exécutable, colle son contenu dans la réponse
* Si le programme a été bloqué, ne pas hésiter a essayer plusieurs fois.
Merci Fish66,
Et voila le rapport sortie par RKiller
Started in : Normal mode
Mode: Scan -- Date : 12/04/2011 14:23:23
¤¤¤ Bad processes: 0 ¤¤¤
¤¤¤ Registry Entries: 0 ¤¤¤
¤¤¤ Infection : ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
Finished : << RKreport[2].txt >>
RKreport[1].txt ; RKreport[2].txt -
Contributeur sécuritéRe,
Nous allons effectuer un diagnostic de ton PC:
*Télécharge ZHPDiag sur ton bureau :
ou :
http://www.premiumorange.com/zeb-help-process/zhpdiag.html
* Laisse toi guider lors de l'installation,coche "Ajouter une icône sur le bureau" et décoche la case "Exécuter ZHPDiag"
/!\Utilisateur de Vista et Seven : Clique droit sur le logo de ZHPdiag, « exécuter en tant qu'Administrateur »
* Clique sur l'icône représentant une loupe (« Lancer le diagnostic »)
* Héberge le rapport ZHPDiag.txt sur un des sites ci dessous, puis copie/colle le lien fourni dans ta prochaine réponse sur le forum : http://www.cijoint.fr/
Si indisponible, tu peux essayer avec l'un de ces liens:
http://dl.free.fr
http://ww38.toofiles.com/fr/documents-upload.html
https://www.terafiles.net/
https://www.casimages.com/
http://pjjoint.malekal.com/
* Tuto zhpdiag :
Hébergement de rapport sur cijoint.fr/
Rend toi sur ce site : http://www.cijoint.fr/
Clique sur Choisissez un fichier
Clique sur "Cliquez ici pour déposer le fichier".
Un lien de cette forme : http://www.cijoint.fr/cjlink.php?file=cj44123/cijSKAP5fU.txt
est ajouté dans la page. Copie ce lien dans ta réponse.
Aide : >>> hébergement ICI <<<
et voila
http://www.toofiles.com/fr/oip/documents/ZHPDiagrapp/zhpdiagrap.html -
Contributeur sécuritéBonjour,
Il n'y a pas un rapport hébergé dans ce lien, héberge le de nouveau stp!
desole
essayer de nouveau
http://www.toofiles.com/fr/oip/documents/txt/zhpdiagrapp.html -
1/
Désinstalle stp ces logiciels :
O42 - Logiciel: Freeze.com NetAssistant -
O42 - Logiciel: NetAssistant -
2/
Avant d'utiliser ComboFix :
Les logiciels d'émulation de CD comme Daemon Tools peuvent gêner les outils de désinfection. Utilise Defogger pour les désactiver temporairement :
si tu as ce genre de d'outils sur ton pc Utilise Defogger pour les désactiver temporairement : sinon passe directement à combofix
. Télécharge Defogger (de jpshortstuff) sur ton Bureau
. Lance le
Une fenêtre apparait : clique sur "Disable"
. Fais redémarrer l'ordinateur si l'outil te le demande
Note : Quand nous aurons terminé la désinfection, tu pourras réactiver ces logiciels en relançant Defogger et en cliquant sur "Re-enable"
Attention, avant de commencer, lit attentivement la procédure
/!\ Ne pas utiliser ce logiciel en dehors du cadre de cette désinfection : DANGEUREUX /!\
? Fais un clic droit sur ce lien, enregistre le dans ton bureau
Voici Aide combofix
* /!\ Déconnecte-toi du net et ARRÊTE TES LOGICIELS DE PROTECTION /!\
*Double-clique sur ComboFix.exe (ou exécuter en tant qu'administrateur pour vista et seven)
Un "pop-up" va apparaître qui dit que ComboFix est utilisé à vos risques et avec aucune garantie... Clique sur oui pour accepter
** SURTOUT INSTALLES LA CONSOLE DE RECUPERATION
(si il te propose de l'installer remets internet)
? Ne touche à rien(souris, clavier) tant que le scan n'est pas terminé, car tu risques de planter ton PC
*En fin de scan, il est possible que ComboFix ait besoin de redémarrer le PC pour finaliser la désinfection, laisse-le faire.
* Une fois le scan achevé, un rapport va s'afficher : Poste son contenu
** /!\ Réactive la protection en temps réel de ton antivirus et de ton antispyware avant de te reconnecter à Internet. /!\
*Note : Le rapport se trouve également là : C:\ComboFix.txt
Merci mais comment desinstaller les 2 logiciel y a rien daccessible sous le menu windows.
Je ne peux pas alller dans Start - control pannel etc..
Autre suggestion ^ -
Relance RogueKiller puis tapes 6 et poste le rapport stp
Bonjour Fish66, et voici le rapport demandE
Mode: Shortcuts HJfix -- Date : 12/05/2011 07:19:13
¤¤¤ File attributes restored: ¤¤¤
Desktop: Success 0 / Fail 0
Quick launch: Success 0 / Fail 0
Programs: Success 1 / Fail 0
Start menu: Success 32 / Fail 0
User folder: Success 15104 / Fail 0
My documents: Success 126 / Fail 0
My favorites: Success 49 / Fail 0
My pictures: Success 28 / Fail 0
My music: Success 10 / Fail 0
My videos: Success 2 / Fail 0
Local drives: Success 1942 / Fail 0
Backup: [FOUND] Success 0 / Fail 254
Drives:
[C:] \Device\HarddiskVolume2 -- 0x3 --> Restored
[D:] \Device\HarddiskVolume3 -- 0x3 --> Restored
[E:] \Device\HarddiskVolume4 -- 0x3 --> Restored
[F:] \Device\CdRom0 -- 0x5 --> Skipped
¤¤¤ Infection : Rogue.FakeHDD ¤¤¤
Finished : << RKreport[3].txt >>
RKreport[1].txt ; RKreport[2].txt ; RKreport[3].txt -
Est ce que tu as récupéré les icones disparus ?
Si oui tu peux effectuer les procédures indiquées >>> ICI <<<
et voila
ComboFix 11-12-05.01 - Moe 05/12/2011 8:12.1.4 - x64
Microsoft Windows 7 Home Premium 6.1.7600.0.1252.2.1033.18.3894.2289 [GMT -5:00]
Running from: c:\users\Moe\Desktop\ComboFix.exe
AV: Norton Internet Security *Disabled/Updated* {88C95A36-8C3B-2F2C-1B8B-30FCCFDC4855}
FW: Norton Internet Security *Disabled* {B0F2DB13-C654-2E74-30D4-99C9310F0F2E}
SP: Norton Internet Security *Disabled/Updated* {33A8BBD2-AA01-20A2-213B-0B8EB45B02E8}
SP: STOPzilla Anti-Spyware *Disabled/Updated* {B2E69928-50DC-94CA-6A80-AAB054008761}
SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\Install.exe
c:\programdata\fIJsmsUwPvQ.exe
c:\programdata\NOQiG1wfzvu38F.exe
c:\users\Moe\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\System Fix.lnk
c:\users\Moe\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\System Fix
c:\users\Moe\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\System Fix\System Fix.lnk
c:\users\Moe\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\System Fix\Uninstall System Fix.lnk
c:\users\Moe\VoiceEditingV1_Update.exe
c:\windows\SysWow64\odbcad32.exe
c:\windows\system32\srrstr.dll . . . . Failed to delete
c:\windows\system32\systemcpl.dll . . . . Failed to delete
c:\windows\system32\termsrv.dll . . . . Failed to delete
((((((((((((((((((((((((( Files Created from 2011-11-05 to 2011-12-05 )))))))))))))))))))))))))))))))
2011-12-05 13:19 . 2011-12-05 13:19 -------- d-----w- c:\users\Default\AppData\Local\temp
2011-12-04 19:42 . 2011-12-04 19:42 512 ----a-w- C:\PhysicalDisk0_MBR.bin
2011-12-04 19:38 . 2011-12-04 19:42 -------- d-----w- C:\ZHP
2011-12-04 19:37 . 2011-12-04 19:42 -------- d-----w- c:\program files (x86)\ZHPDiag
2011-12-04 16:37 . 2011-12-04 16:37 -------- d-----w- c:\users\Moe\AppData\Roaming\Malwarebytes
2011-12-04 16:37 . 2011-12-04 16:37 -------- d-----w- c:\programdata\Malwarebytes
2011-12-04 16:37 . 2011-12-04 16:37 -------- d-----w- c:\program files (x86)\Malwarebytes' Anti-Malware
2011-12-04 16:37 . 2011-08-31 22:00 25416 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-12-04 16:29 . 2011-12-04 16:29 -------- d-----w- c:\programdata\PC Tools
2011-12-04 16:17 . 2011-12-04 16:17 -------- d-----w- c:\program files (x86)\STOPzilla!
2011-12-04 16:17 . 2011-12-04 16:17 -------- d-----w- c:\program files (x86)\Common Files\iS3
2011-12-04 16:17 . 2011-12-05 13:22 -------- d-----w- c:\programdata\STOPzilla!
2011-12-02 12:11 . 2011-11-21 11:40 8822856 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{1DECB485-848C-46C2-9DD5-9ADDCA8222D7}\mpengine.dll
2011-12-01 00:45 . 2011-12-01 00:45 547880 ----a-r- c:\windows\SysWow64\SZComp5.dll
2011-12-01 00:45 . 2011-12-01 00:45 24616 ----a-r- c:\windows\SysWow64\SZIO5.dll
2011-12-01 00:45 . 2011-12-01 00:45 134184 ----a-r- c:\windows\SysWow64\IS3HTUI5.dll
2011-12-01 00:45 . 2011-12-01 00:45 68648 ----a-r- c:\windows\SysWow64\IS3Hks5.dll
2011-12-01 00:45 . 2011-12-01 00:45 482344 ----a-r- c:\windows\SysWow64\SZBase5.dll
2011-12-01 00:45 . 2011-12-01 00:45 457768 ----a-r- c:\windows\SysWow64\IS3DBA5.dll
2011-12-01 00:45 . 2011-12-01 00:45 392232 ----a-r- c:\windows\SysWow64\IS3UI5.dll
2011-12-01 00:45 . 2011-12-01 00:45 30248 ----a-r- c:\windows\SysWow64\IS3XDat5.dll
2011-12-01 00:45 . 2011-12-01 00:45 232488 ----a-r- c:\windows\SysWow64\IS3Win325.dll
2011-12-01 00:45 . 2011-12-01 00:45 105512 ----a-r- c:\windows\SysWow64\IS3Inet5.dll
2011-12-01 00:45 . 2011-12-01 00:45 101416 ----a-r- c:\windows\SysWow64\IS3Svc5.dll
2011-12-01 00:45 . 2011-12-01 00:45 740392 ----a-r- c:\windows\SysWow64\IS3Base5.dll
2011-11-12 17:07 . 2011-11-12 17:07 -------- d-----w- c:\users\Moe\AppData\Local\Facebook
2011-11-09 11:57 . 2011-10-01 05:28 886784 ----a-w- c:\program files\Common Files\System\wab32.dll
2011-11-09 11:57 . 2011-10-01 04:43 708608 ----a-w- c:\program files (x86)\Common Files\System\wab32.dll
2011-11-09 11:57 . 2011-09-29 16:24 1897328 ----a-w- c:\windows\system32\drivers\tcpip.sys
2011-11-09 11:57 . 2011-09-29 04:09 3141120 ----a-w- c:\windows\system32\win32k.sys
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2011-10-01 03:21 . 2011-10-11 22:07 1638912 ----a-w- c:\windows\system32\mshtml.tlb
2011-10-01 02:59 . 2011-10-11 22:07 1638912 ----a-w- c:\windows\SysWow64\mshtml.tlb
2011-09-26 16:21 . 2011-09-26 16:21 74768 ----a-r- c:\windows\SysWow64\drivers\SZKG64.sys
2011-09-26 16:21 . 2011-09-26 16:21 74768 ----a-r- c:\windows\SysWow64\drivers\is3srv64.sys
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}"= "c:\program files (x86)\Freeze.com\NetAssistant\NetAssistant.dll" [2011-06-22 1718472]
[HKEY_CLASSES_ROOT\clsid\{e38fa08e-f56a-4169-abf5-5c71e3c153a1}]
[HKEY_CLASSES_ROOT\NetAssistant.NetAssistantBHO.1]
[HKEY_CLASSES_ROOT\TypeLib\{1E8FC16F-4C51-49C4-BC9B-4FC24BDDCEE7}]
[HKEY_CLASSES_ROOT\NetAssistant.NetAssistantBHO]
[HKEY_LOCAL_MACHINE\Wow6432Node\~\Browser Helper Objects\{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}]
2011-06-22 16:30 1718472 ----a-w- c:\program files (x86)\Freeze.com\NetAssistant\NetAssistant.dll
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"HPAdvisorDock"="c:\program files (x86)\Hewlett-Packard\HP Advisor\Dock\HPAdvisorDock.exe" [2010-01-28 1712184]
"LightScribe Control Panel"="c:\program files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe" [2010-01-22 2363392]
"Skype"="c:\program files (x86)\Skype\Phone\Skype.exe" [2011-01-26 15026056]
"Itibiti.exe"="c:\program files (x86)\Itibiti Soft Phone\Itibiti.exe" [2011-11-08 5284352]
"Facebook Update"="c:\users\Moe\AppData\Local\Facebook\Update\FacebookUpdate.exe" [2011-11-12 137536]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"StartCCC"="c:\program files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2010-01-22 98304]
"Microsoft Default Manager"="c:\program files (x86)\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2010-05-10 439568]
"NortonOnlineBackupReminder"="c:\program files (x86)\Symantec\Norton Online Backup\Activation\NOBuActivation.exe" [2009-12-04 3331944]
"Adobe Reader Speed Launcher"="c:\program files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-02-28 35696]
"HP Software Update"="c:\program files (x86)\Hp\HP Software Update\HPWuSchd2.exe" [2008-12-08 54576]
"TkBellExe"="c:\program files (x86)\Real\RealPlayer\Update\realsched.exe" [2010-12-25 274608]
"SunJavaUpdateSched"="c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2011-04-08 254696]
"Malwarebytes' Anti-Malware"="c:\program files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe" [2011-08-31 449608]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
"ConsentPromptBehaviorUser"= 3 (0x3)
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
"mixer"=wdmaud.drv
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
Notification Packages REG_MULTI_SZ DPPassFilter scecli
Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R2 HP Wireless Assistant Service;HP Wireless Assistant Service;c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWA_Service.exe [2009-12-16 102968]
R3 BBSvc;Bing Bar Update Service;c:\program files (x86)\Microsoft\BingBar\BBSvc.EXE [2011-02-28 183560]
R3 GamesAppService;GamesAppService;c:\program files (x86)\WildTangent Games\App\GamesAppService.exe [2010-10-12 206072]
R3 JLTECH0227;Dual Mode Camera;c:\windows\system32\Drivers\jl2005c.sys [x]
R3 netw5v64;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 64 Bit;c:\windows\system32\DRIVERS\netw5v64.sys [x]
R3 Point64;Microsoft IntelliPoint Filter Driver;c:\windows\system32\DRIVERS\point64.sys [x]
R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys [x]
R3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt64win7.sys [x]
R3 SrvHsfHDA;SrvHsfHDA;c:\windows\system32\DRIVERS\VSTAZL6.SYS [x]
R3 SrvHsfV92;SrvHsfV92;c:\windows\system32\DRIVERS\VSTDPV6.SYS [x]
R3 SrvHsfWinac;SrvHsfWinac;c:\windows\system32\DRIVERS\VSTCNXT6.SYS [x]
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [x]
R3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\DRIVERS\yk62x64.sys [x]
S0 szkg5;szkg5;c:\windows\SySWOW64\DRIVERS\szkg64.sys [2011-09-26 74768]
S1 DVMIO;DeviceVM IO Service;c:\windows\system32\DRIVERS\dvmio.sys [x]
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [x]
S2 AESTFilters;Andrea ST Filters Service;c:\windows\System32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_1c0e2d1db9f5b08e\AESTSr64.exe [2009-03-03 89600]
S2 AMD External Events Utility;AMD External Events Utility;c:\windows\system32\atiesrxx.exe [x]
S2 DvmMDES;DeviceVM Meta Data Export Service;c:\swsetup\QuickWeb\QW.SYS\config\DVMExportService.exe [2010-02-08 338168]
S2 hpsrv;HP Service;c:\windows\system32\Hpservice.exe [x]
S2 HPWMISVC;HPWMISVC;c:\program files\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe [2010-01-18 20480]
S2 MBAMService;MBAMService;c:\program files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe [2011-08-31 366152]
S2 NIS;Norton Internet Security;c:\program files (x86)\Norton Internet Security\Engine\17.0.0.136\ccSvcHst.exe [2009-08-24 126392]
S2 UNS;Intel(R) Management & Security Application User Notification Service;c:\program files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe [2010-03-18 2320920]
S2 vcsFPService;Validity VCS Fingerprint Service;c:\windows\system32\vcsFPService.exe [2010-01-06 2184496]
S3 amdkmdag;amdkmdag;c:\windows\system32\DRIVERS\atipmdag.sys [x]
S3 amdkmdap;amdkmdap;c:\windows\system32\DRIVERS\atikmpag.sys [x]
S3 HECIx64;Intel(R) Management Engine Interface;c:\windows\system32\DRIVERS\HECIx64.sys [x]
S3 Impcd;Impcd;c:\windows\system32\DRIVERS\Impcd.sys [x]
S3 intelkmd;intelkmd;c:\windows\system32\DRIVERS\igdpmd64.sys [x]
S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [x]
S3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys [x]
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
2010-01-22 18:06 451872 ----a-w- c:\program files (x86)\Common Files\LightScribe\LSRunOnce.exe
Contents of the 'Scheduled Tasks' folder
2011-12-03 c:\windows\Tasks\FacebookUpdateTaskUserS-1-5-21-392288041-244505017-2593837476-1001Core.job
- c:\users\Moe\AppData\Local\Facebook\Update\FacebookUpdate.exe [2011-11-12 17:07]
2011-12-04 c:\windows\Tasks\FacebookUpdateTaskUserS-1-5-21-392288041-244505017-2593837476-1001UA.job
--------- x86-64 -----------
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2010-01-22 166424]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2010-01-22 390680]
"Persistence"="c:\windows\system32\igfxpers.exe" [2010-01-22 410136]
"SysTrayApp"="c:\program files\IDT\WDM\sttray64.exe" [2010-01-14 487424]
"HP Quick Launch"="c:\program files\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe" [2010-01-18 451072]
"SmartMenu"="c:\program files\Hewlett-Packard\HP MediaSmart\SmartMenu.exe" [2010-01-20 611896]
"HPToneControl"="c:\program files\Hewlett-Packard\HPToneControl\HPTonectl.exe" [2009-08-20 107832]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2010-03-01 172032]
"HPWirelessAssistant"="c:\program files\Hewlett-Packard\HP Wireless Assistant\DelayedAppStarter.exe" [2009-12-16 8192]
"IntelliPoint"="c:\program files\Microsoft IntelliPoint\ipoint.exe" [2010-07-21 2327952]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"LoadAppInit_DLLs"=0x0
------- Supplementary Scan -------
uStart Page = hxxp://www.google.ca/
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
IE: E&xport to Microsoft Excel - c:\progra~2\MICROS~1\Office12\EXCEL.EXE/3000
IE: Voice Editing Launcher - c:\program files (x86)\Panasonic\Voice Editing\VEd1_IEMenu.html
TCP: DhcpNameServer = 192.168.0.1
- - - - ORPHANS REMOVED - - - -
HKLM-Run-SynTPEnh - c:\program files (x86)\Synaptics\SynTP\SynTPEnh.exe
AddRemove-{495A8A3C-8FD0-4C46-9979-95C26181A1AB} - c:\program files (x86)\InstallShield Installation Information\{495A8A3C-8FD0-4C46-9979-95C26181A1AB}\setup.exe
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\NIS]
"ImagePath"="\"c:\program files (x86)\Norton Internet Security\Engine\17.0.0.136\ccSvcHst.exe\" /s \"NIS\" /m \"c:\program files (x86)\Norton Internet Security\Engine\17.0.0.136\diMaster.dll\" /prefetch:1"
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10s_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10s_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
@="{FAB3E735-69C7-453B-A446-B6823C6DF1C9}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10s.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.10"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10s.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
------------------------ Other Running Processes ------------------------
c:\program files (x86)\DigitalPersona\Bin\DPAgent.exe
c:\program files (x86)\Common Files\LightScribe\LSSrvc.exe
c:\program files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
c:\program files (x86)\Microsoft\BingBar\SeaPort.EXE
c:\program files (x86)\Real\RealPlayer\update\RealOneMessageCenter.exe
c:\program files (x86)\Skype\Plugin Manager\skypePM.exe
Completion time: 2011-12-05 08:27:08 - machine was rebooted
ComboFix-quarantined-files.txt 2011-12-05 13:27
Pre-Run: 406,806,212,608 bytes free
Post-Run: 407,559,569,408 bytes free
- - End Of File - - 2E2A20A6EF961619EA61570F886B100C -
* Télécharge OTM (OldTimer) sur ton Bureau
ICI >> OTM (OldTimer)
* Double clic "OTMoveIt3.exe"
* Utilisateurs Windows Vista / 7 Clic droit sur "OTMoveIt3.exe" choisis "exécuter en tant qu'administrateur" afin de le lancer.
- Copie (Ctrl+C) le texte suivant en gras ci-dessous :
:files
:Reg
"{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}"=-
- Colle (Ctrl+V) le texte précédemment copié dans le cadre: Paste Instructions for Items to be Moved.
- Clique maintenant sur le bouton MoveIt!
Si un fichier ou dossier ne peut pas être supprimé immédiatement, le logiciel te demandera de redémarrer.
Accepte en cliquant sur YES.
- Poste le rapport situé dans ce dossier : C:\_OTMoveIt\MovedFiles\
Le nom du rapport correspond au moment de sa création : date_heure.log
Re,
========== FILES ==========
File/Folder c:\windows\system32\srrstr.dll not found.
DllUnregisterServer procedure not found in c:\windows\system32\systemcpl.dll
c:\windows\system32\systemcpl.dll moved successfully.
File/Folder c:\windows\system32\termsrv.dll not found.
File/Folder c:\program files (x86)\Freeze.com\NetAssistant\NetAssistant.dll not found.
========== REGISTRY ==========
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks\\{E38FA08E-F56A-4169-ABF5-5C71E3C153A1} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E38FA08E-F56A-4169-ABF5-5C71E3C153A1}\ deleted successfully.
OTM by OldTimer - Version 3.1.19.0 log created on 12052011_130008 -
Lance ZHPDiag depuis le bureau puis prépare stp un nouveau rapport ZHPDiag ( à héberger)
http://www.toofiles.com/fr/oip/documents/txt/7180_zhpdiag.html
1/
Est ce que tu n'as pas essayé de désinstaller ces logiciels ?
Si tu n'as pas pu, utilise le logiciel ci-dessous pour les désinstaller :
Télécharge Revo-uninstaller
Exécute ce fichier pour installation
*******Aide Revo-uninstaller*******
2/
Copie tout le texte présent en gras ci-dessous ( tu le selectionnes avec ta souris / Clique droit dessus et choisis "copier" ou fait Ctrl+C )
[HKLM\Software\Freeze.com] => Infection BT (Adware.BHO)
[HKLM\Software\WOW6432Node\freeze.com] => Infection BT (Adware.BHO)
OPT:O4 - Global Startup: C:\Users\Moe\Desktop\DoraTheExplorerSnapshots.lnk . (...) -- C:\Program Files (x86)\DoraTheExplorerSnapshots\Dora.exe (.not file.)
OPT:O4 - Global Startup: C:\Users\Moe\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\WildTangent Games App - hp.lnk . (.WildTangent.) -- C:\Program Files (x86)\WildTangent Games\App\GameConsole-wt.exe
FirewallRAZ
EmptyFlash
Puis Lance ZHPFix depuis le raccourci du bureau .
* Une fois l'outil ZHPFix ouvert , clique sur le bouton [ H ] ( "coller les lignes Helper" ) .
* Dans l'encadré principal tu verras donc les lignes que tu as copié précédemment apparaitrent .
Vérifie que toutes les lignes que je t'ai demandé de copier (et seulement elles) sont dans la fenêtre.
Clique sur le bouton GO
Copie/Colle le rapport à l'écran dans ton prochain message.
3/
Est ce que : System Fix est il encore présent ?
_ _ _ Fish66_ _ _ I''"""""I_ _ membre _ _I''"""""I_ _ contributeur sécurité_ _ _
¤¤¤ Le meilleur remède pour tous les problèmes, c'est la patience.... ¤¤¤ -
1- Net Assistant je ne le vois lus en utilisant le logiciel suggere
2- le rapport est ci bas
3- Non Ssystem n<est plus la depuis hier
Rapport de ZHPFix 1.12.3373 par Nicolas Coolman, Update du 24/11/2011
Fichier d'export Registre : C:\ZHP\ZHPExportRegistry-12-5-2011-2-07-06 PM.txt
Run by Moe at 12/5/2011 2:07:06 PM
Windows 7 Home Premium Edition, 64-bit (Build 7600)
Web site : http://www.premiumorange.com/zeb-help-process/zhpfix.html
========== Registry Key ==========
NOT FOUND Key: HKLM\Software\Freeze.com
DELETED Key: HKLM\Software\WOW6432Node\freeze.com
========== Registry Value ==========
No Value in Standard Profile Register Key FirewallRaz :
No Value in Domain Profile Register Key FirewallRaz :
DELETED FirewallRaz (None) : {F90FC4B3-2B2A-45CE-9ED1-0FD2977A51D7}
DELETED FirewallRaz (Domain) : NetPres-In-TCP-NoScope
DELETED FirewallRaz (Domain) : NetPres-Out-TCP-NoScope
DELETED FirewallRaz (None) : NetPres-WSD-In-UDP
DELETED FirewallRaz (None) : NetPres-WSD-Out-UDP
DELETED FirewallRaz (Public) : NetPres-In-TCP
DELETED FirewallRaz (Public) : NetPres-Out-TCP
DELETED FirewallRaz (None) : {8E8DF1BB-8E20-4593-A8B1-A33B47A27921}
DELETED FirewallRaz (None) : {310FBD4C-99B2-4778-B47B-ED8F31E53B4F}
DELETED FirewallRaz (None) : {D201519D-687C-40A1-8BD9-B873DC1B4444}
DELETED FirewallRaz (None) : {522EE037-FAFB-4E5F-AB1C-BEF6D5727300}
DELETED FirewallRaz (None) : {E1CC441B-5DF2-4A33-87CC-479E4DC9ED95}
DELETED FirewallRaz (None) : {58B112E4-D81B-4FEF-988B-B992B8961395}
DELETED FirewallRaz (None) : {8E53D523-D687-482B-82C0-A89EBE3A9049}
DELETED FirewallRaz (None) : {5183714C-F076-4ACA-9F2B-B4C647AFB6A6}
========== Repertory ==========
DELETED Flash Cookies: 474
========== File ==========
DELETED File: c:\users\moe\desktop\doratheexplorersnapshots.lnk
DELETED File: c:\users\moe\appdata\roaming\microsoft\internet explorer\quick launch\wildtangent games app - hp.lnk
DELETED Flash Cookies: 329
========== Summary ==========
2 : Registry Key
17 : Registry Value
1 : Repertory
3 : File
End of clean in 01mn AMs
========== Report File ==========
C:\ZHP\ZHPFix[R1].txt - 12/5/2011 2:07:06 PM [1939] -
1/
Fais stp la mise à jour de ton Windows pour passer au pack2
2/Mise à jour de Java:
* Tu peux vérifier ta Console Java en cliquant sur ce lien :https://www.java.com/fr/download/uninstalltool.jsp
* Installe la nouvelle version si besoin (dans ce cas désinstalle avant l'ancienne version).
voici pour desinstaller JavaRa:
* Télécharge ce fichier à partir ce lien : http://raproducts.org/click/click.php?id=1
* Décompresse JavaRa sur le Bureau (Clic droit > Extraire tout).
* Double-clique (clic droit "en tant qu'administrateur" pour Vista) sur le répertoire JavaRa.
* Puis double-clique sur le fichier JavaRa.exe (le exe peut ne pas s'afficher).
* Choisis Français puis clique sur Select.
* Clique sur Recherche de mises à jour.
* Sélectionne Mettre à jour via jucheck.exe puis clique sur Rechercher.
* Autorise le processus à se connecter s'il le demande, clique sur Installer et suis les instructions d'installation qui prennent quelques minutes.
* L'installation est terminée, reviens à l'écran de JavaRa et clique sur Effacer les anciennes versions.
* Clique sur Oui pour confirmer. Laisse travailler et clique ensuite sur OK, puis
une deuxième fois sur OK.
* Un rapport va s'ouvrir. Poste-le dans ta prochaine réponse.
* Ferme l'application.
Note : le rapport se trouve aussi dans C:\ sous le nom JavaRa.log.
- 1
- 2
