Suseconfig --module syslog-ng ne marche pas
hi
i use suse 10 sp2
i am making same change in the file /etc/syslog-ng/syslog-ng.con.in
i follow the instructio of this howto http://www.novell.com/coolsolutions/feature/18044.html
but som were it sais to Save the file and run SuSEconfig --module syslog-ng
and when i tri to do so her what happens
:~> suseconfig --module syslog-ng
-bash: suseconfig: command not found
even with sudo
sudo suseconfig --module syslog-ng
-bash: :~: command not found33
SOS i realy need this
help
thanks
Firefox 3.0.6
9 réponses
  1. it me answering me hihihi
    the solution is first
    1 ad a file names syslog-ng.conf.SuSEconfig
    destination std {
    file ("/var/log/HOSTS/$YEAR-$MONTH/$HOST/$FACILITY-$YEAR-$MONTH-$DAY"
    owner(root) group(root) perm(0600) dir_perm(0700) create_dirs(yes) it was y/es
    2 run this command
    SuSEconfig --force --module syslog-ng it is better
    for more detail fiolow this link
    http://www.commentcamarche.net/forum/affich 11051806 syslog ng not retsarting
    1. hi the problem was resolved before my last post
      but her is a new one
      this one i passed a lot of time to reslove it but nat a chance
      i added in syslog-ng.config.in this i waas folowing this how to for setting syslog server
      destination std {
      owner(root) group(root) perm(0600) dir_perm(0700) create_dirs(y\es)
      ligne 201
      ligne 202
      after lanching:
      this erro ocures
      Starting SuSEconfig, the SuSE Configuration Tool...
      Running module syslog-ng only
      Reading /etc/sysconfig and updating the system...
      Executing /sbin/conf.d/SuSEconfig.syslog-ng...
      Checking //etc/syslog-ng/syslog-ng.conf.SuSEconfig file: syntax error at 202
      Parse error reading configuration file, exiting. (line 202)
      Please correct the //etc/syslog-ng/syslog-ng.conf.in file.
      Finished.
        Have you tried with all the path :
        /etc/sysconfig/suseconfig --module syslog-ng
        1. Sorry
          i was fool
          i did not gat it the first time
          thank you
          1. if u have seen my last post you will discover it
            # suseconfig syslog-ng
              Except if you write the result in the forum it is not normal that your shell return the result with this case. For example if, as simple user, I type
              SuSEconfig hello
              it returns
              SuSEconfig: command not found
              and not
              You understand ?
              Type su in your shell and press Return key. Then enter your password (which won't appear) et press another time Return.
              Now, paste this line
              what's the answer ?
              edit > ok for your last post
              1. see even if i am su same thing
                the problem that i have to make it woek as soon as possible
                1. i did it
                  but same thing
                  see
                  sudo: suseconfig: command not found²
                  the proble wich is making me crasy tht
                  if i do
                  :/etc/sysconfig> ls|grep suse
                  suseconfig
                  i fing the suseconfig
                  even like this
                  sudo ./sudo suseconfig --module syslog-ng
                  same thing
                    Shell's commands are case-sensitive. So try, as root, with
