Acer laptop power cable issue
Hello everyone in the community :),
Here I will get straight to the point. I have a laptop that is almost 2 years old and I'm having a problem with the power supply. The computer is plugged in, but the power cable connected to the back of the laptop is giving me trouble. Indeed, since this morning, when I plug in the cable, the screen remains dark and the battery icon stays at the bottom right of the screen. To fix the problem, I have to wiggle the base of the cable until the laptop recognizes it. But I think this solution won't last long, so I hasten to ask for your advice. What is causing the problem?? Should I just change the power cable or disassemble the laptop (I've heard about soldering) or is the problem just temporary and could depend on the heat or the fact that I transported my laptop the day before???
Anyway, I have always found what I was looking for on this site, so I'm not worried. :)
Thanks,
Configuration: Windows XP Firefox 2.0.0.13
  1. Hello,
    As a computer repair technician at a large company, a colleague brought me an Acer laptop with the same problem as yours.
    After investigation and complete disassembly of the laptop, the issue became clear: the female socket for the power supply, meaning the connector soldered to the motherboard, is broken and makes contact with the male plug (the connector on the power supply side) only when the power connector is moved.
    The solution is to find an identical connector and replace it on the motherboard.
    I hope this helps you.
    JP
    1. Hi Ushuaia,
      do you have a plan to get this type of part?
    2. Is the colleague's name not Mansour by any chance?
    3. Hello everyone, well I have the same problem with my Aspire 8930 G laptop, but I'm lucky it seems to still be under warranty... grandpa J.P.
    4. I have the same problem as the person with the food issue.
      How much does it cost to find an identical connector and replace it on the motherboard?
      Thank you
    5. Hello, I have the following problem: when I turn on my Acer 8930, it shuts down by itself and turns back on, and it keeps doing this. Can you give me a solution? Thank you.
