[Batterie] Battery not charging anymore
Solved/Closed
misterfreeze Posted messages 11 Status Member -
 22 -
Hello,
I have a Packard Bell Easynote W3117 laptop and I'm having a problem with the battery. In fact, it no longer charges. In the power options, it reads:
Current power source: AC power
Remaining battery charge: 0%
Below, the small battery icon is crossed out with a red X.
How can I fix this problem, knowing that I don't see how it's possible to reactivate the charging of this battery? Should I buy a new one, or is there a way to get this battery (Li-ion type) working again?
Thank you in advance.
  1. oili
    • turn off your pc
    • unplug the power supply
    • remove the battery
    • hold down the power button for 30 seconds
    • put the battery back
    • plug in the power supply
    • restart the computer
    & Here I hope it works for you =)
    288
    1. aymen
      Thank you, it worked!!! <3
    2. dobr
      Impressive, it works!! Thanks again!
      I am going to share the information with my colleagues.
