Cursor issue in 3Ds MAX
Mattioouu -
3DSMAN09 Posted messages 1 Status Membre -
Hello, I’m not sure if this subject has already been addressed, but I couldn't find it.
I'm having an issue with the cursor in 3Ds Max; it’s no longer showing up... No matter if I select move, scale, or rotate, I just get three gray lines instead of the original cursors. It must be an option that I accidentally activated, but I can’t find where it is. This isn't the first time this has happened to me. The only solution was to reinstall 3Ds... /cry.. If someone could provide a solution, I would be very grateful.
Thank you in advance.
Mathieu
Configuration: Mac OS X Safari 522.12.1
3DSMAN09 Posted messages 1 Status Membre 3
Hello SOS SOS SOS SOS
Same problem for me, no more cursor, and if I press X on the keyboard, all the toolbars disappear but the cursor doesn't come back..
In the meantime, I've set up a toolbar X Y Z, but I have to click on it every time I change the axis! It's super annoying... anyway, sniff sniff, I want my cursor! : )
....To whom it may concern, THANK YOU..
3
Mattioouu
Lol, I found it... you just have to press " X " .. Sorry for this stupid question, mods feel free to delete it!
so'
Thank you, I didn't have it either, and no time to look for it.
