Ryght wireless home speaker sound issue
Turtle -
 Sukui -
Hello,
I bought wireless Ryght Gemeo earbuds a few months ago, and I'm having a sound issue; the sound isn't loud even though it's maxed out on my phone. So I would like to increase the volume of the earbuds; I think that's why it's not high. Unfortunately, I can't find the manual. Could someone please let me know how to do it?
Thank you in advance!
Configuration: Android / Chrome 92.0.4515.159
  1. Idrxp
    Hi, I managed to download the manual online, but there's nothing written on it. I have the same problem from time to time, and to fix it, I recommend pressing the touch button on the earphone until it works again (just spam the button, same thing).
    If it doesn't work, then I'm sorry.
    1. Ltbimsko
      There are two solutions:
      Either the earbuds can adjust the volume or they cannot, I will explain briefly.
      I've been coming here for 2 days to find an answer because one earbud was louder than the other and I couldn't increase the sound via the touch control (I have the Ryght Gemeo2).
      After 2 days, I realized that it wasn't a touch issue, but just that the small grille in the center of the earbud was poorly glued and as a result, the sound was very poor.
      Solution: remove the small grille from both earbuds and everything goes back to normal.
      I hope I have been helpful, have a great day.
      1. Sukui > Ltbimsko
        This unfortunately hasn't helped me. I removed the grid, but the sound is still louder on one side, so I don't know what to do.
