Redmi Note 8 Pro Wi-Fi Problem
Hello everyone,
Happy New Year to you all ???? !
So I have a problem with my Redmi Note 8 Pro. When I'm using mobile data alone, there’s no issue; but when I'm connected to Wi-Fi at the same time, I can't connect to the internet anymore. I tested using mobile data alone and it works, Wi-Fi alone is hit or miss, but using both at the same time works a little and then nothing.
I hope you can help me, this is a nightmare.
One last thing, my box is the Freebox Revolution.
Thanks in advance!
Aurélie
Thanks in advance!
Aurélie
Hello,
I also had the same issue with my Redmi Note 8 Pro and I think I found the solution. Go to your phone's settings, then Wi-Fi, scroll down to the bottom and tap on additional settings, finally enter Wi-Fi assistant and disable the options that are enabled and that's it. I can't guarantee it will work, but it worked for me. Have a nice day.
