Battery charger overheating
Solved
octopus82 Posted messages 135 Status Member -
le hollandais volant Posted messages 5294 Status Member -
Hello,
I just acquired a charger for an HP laptop, and I notice that it gets quite hot to the point where you can't really hold it in your hand.
So, I would like to know if this is a normal phenomenon or if there's something fishy going on?
Thank you
Configuration: Windows 7 / Firefox 11.0
  1. octopus82 Posted messages 135 Status Member 9
    Thank you for your response, but I didn't say untouchable, especially not at first touch; rather, it's by delaying the touch that we feel the heat more
    Anyway, I just saw a laptop repair specialist, and he told me that it's perfectly normal for the charger to heat up even after just a few minutes
    Thanks again
    8
