Problem with wakfu the game won't launch!!
Solved
95robin95
95robin95 Posted messages 10 Registration date Status Membre Last intervention -
Hello,
I have a problem with Wakfu. I downloaded the client, installed the updates, but after launching the game, a rectangle displaying Wakfu appears and then disappears. A window opens, and half a second later it shuts down. Nothing happens, and an error message that I don't understand appears in the Wakfu folder. I'm waiting for a response as soon as possible, thank you.
Configuration: Windows 7 / Internet Explorer 9.0
21 réponses
- 1
- 2
Suivant
yes, here it is
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6903b212, pid=5484, tid=5968
# JRE version: 6.0_18-b07
# Java VM: Java HotSpot(TM) Server VM (16.0-b13 mixed mode windows-x86 )
# Problematic frame:
# C [atioglxx.dll+0xb212]
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x2095e800): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=5968, stack(0x21120000,0x21170000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000008
Registers:
EAX=0x00000008, EBX=0x0059bc60, ECX=0x699aeec4, EDX=0x23e5db98
ESP=0x2116f284, EBP=0x2116f2b0, ESI=0x720cfff6, EDI=0x0059bc6c
EIP=0x6903b212, EFLAGS=0x00010202
Top of Stack: (sp=0x2116f284)
0x2116f284: 00001750 6903a73c 720cfff6 7495af0b
0x2116f294: 00000001 990111a3 00000000 990111a3
0x2116f2a4: 6906fa00 6903a720 0059bcb4 2116f6a0
0x2116f2b4: 7495b0f3 2116f2dc 00000048 00000003
0x2116f2c4: 00000000 2116f34c 00000001 990111a3
0x2116f2d4: 00000000 00000000 00000003 00740061
0x2116f2e4: 006f0069 006c0067 00780078 0064002e
0x2116f2f4: 006c006c 00000000 00000000 03bb8ba8
Instructions: (pc=0x6903b212)
0x6903b202: c5 69 e8 57 db 03 00 8b 15 ac 98 c8 69 83 c0 08
0x6903b212: 8b 00 89 42 20 e8 94 87 04 00 e8 bf 88 00 00 a1
Stack: [0x21120000,0x21170000], sp=0x2116f284, free space=13c2116ed68k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [OPENGL32.dll+0x3b0f3]
C [OPENGL32.dll+0x3b1a9]
C [OPENGL32.dll+0x3c6a4]
C [OPENGL32.dll+0x45658]
C [OPENGL32.dll+0x45dd4]
C [OPENGL32.dll+0x46559]
C [GDI32.dll+0x458b7]
C [jogl.dll+0x1167]
j com.sun.opengl.impl.windows.WGL.ChoosePixelFormat0(JLjava/nio/ByteBuffer;)I+0
j com.sun.opengl.impl.windows.WGL.ChoosePixelFormat(JLcom/sun/opengl/impl/windows/PIXELFORMATDESCRIPTOR;)I+13
j com.sun.opengl.impl.windows.WindowsGLDrawable.choosePixelFormat(Z)V+1033
j com.sun.opengl.impl.windows.WindowsOnscreenGLDrawable.lockSurface()I+230
j com.sun.opengl.impl.windows.WindowsOnscreenGLContext.makeCurrentImpl()I+4
j com.sun.opengl.impl.GLContextImpl.makeCurrent()I+56
j com.sun.opengl.impl.GLDrawableHelper.invokeGL(Ljavax/media/opengl/GLDrawable;Ljavax/media/opengl/GLContext;Ljava/lang/Runnable;Ljava/lang/Runnable;)V+308
j javax.media.opengl.GLCanvas$DisplayOnEventDispatchThreadAction.run()V+35
j java.awt.event.InvocationEvent.dispatch()V+11
j java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V+26
j java.awt.EventDispatchThread.pumpOneEventForFilters(I)Z+204
j java.awt.EventDispatchThread.pumpEventsForFilter(ILjava/awt/Conditional;Ljava/awt/EventFilter;)V+30
j java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V+11
j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
j java.awt.EventDispatchThread.run()V+9
v ~StubRoutines::call_stub
V [jvm.dll+0x19201c]
V [jvm.dll+0x27e891]
V [jvm.dll+0x1921e7]
V [jvm.dll+0x19225d]
V [jvm.dll+0x1bbe20]
V [jvm.dll+0x303d04]
V [jvm.dll+0x27e50c]
C [MSVCR71.dll+0xb381]
C [kernel32.dll+0x1339a]
C [ntdll.dll+0x39ed2]
C [ntdll.dll+0x39ea5]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x1fc0b000 JavaThread "Thread-8" [_thread_blocked, id=6024, stack(0x00290000,0x002e0000)]
0x20950400 JavaThread "SoundAmbEngine" [_thread_blocked, id=984, stack(0x23a20000,0x23a70000)]
0x20954800 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3364, stack(0x211b0000,0x21200000)]
=>0x2095e800 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=5968, stack(0x21120000,0x21170000)]
0x20953400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3320, stack(0x21090000,0x210e0000)]
0x20950c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=5748, stack(0x21000000,0x21050000)]
0x20920400 JavaThread "MessageScheduler" [_thread_blocked, id=1036, stack(0x20f70000,0x20fc0000)]
0x208d7c00 JavaThread "Worker (in OpenGL thread)" [_thread_blocked, id=5928, stack(0x20ee0000,0x20f30000)]
0x20532400 JavaThread "AsyncLoader" [_thread_blocked, id=3472, stack(0x20400000,0x20450000)]
0x1feb8c00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3388, stack(0x1fa70000,0x1fac0000)]
0x1dfe0800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3788, stack(0x1f950000,0x1f9a0000)]
0x1dfdc800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=4288, stack(0x1f8c0000,0x1f910000)]
0x1dfdc000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1524, stack(0x1f830000,0x1f880000)]
0x1dfd9800 JavaThread "Attach Listener" daemon [_thread_blocked, id=4992, stack(0x1f7a0000,0x1f7f0000)]
0x1dfd9000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1796, stack(0x1f710000,0x1f760000)]
0x1dfd6c00 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=5612, stack(0x1f680000,0x1f6d0000)]
0x1df79c00 JavaThread "Finalizer" daemon [_thread_blocked, id=5580, stack(0x1f5f0000,0x1f640000)]
0x1df76c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=2616, stack(0x1f560000,0x1f5b0000)]
0x02aae800 JavaThread "main" [_thread_blocked, id=2720, stack(0x00090000,0x000e0000)]
Other Threads:
0x1df6f800 VMThread [stack: 0x1f4d0000,0x1f520000] [id=1212]
0x1dfe4400 WatcherThread [stack: 0x1f9e0000,0x1fa30000]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 14784K, used 11793K [0x05d80000, 0x06d80000, 0x08580000)
eden space 13184K, 77% used [0x05d80000, 0x067744b0, 0x06a60000)
from space 1600K, 100% used [0x06bf0000, 0x06d80000, 0x06d80000)
to space 1600K, 0% used [0x06a60000, 0x06a60000, 0x06bf0000)
concurrent mark-sweep generation total 49152K, used 21625K [0x08580000, 0x0b580000, 0x19d80000)
concurrent-mark-sweep perm gen total 44924K, used 27063K [0x19d80000, 0x1c95f000, 0x1dd80000)
Dynamic libraries:
0x00400000 - 0x0045c000 C:\Program Files (x86)\Wakfu\Wakfu.exe
0x77820000 - 0x779a0000 C:\Windows\SysWOW64\ntdll.dll
0x76360000 - 0x76470000 C:\Windows\syswow64\kernel32.dll
0x753b0000 - 0x753f6000 C:\Windows\syswow64\KERNELBASE.dll
0x76470000 - 0x76510000 C:\Windows\syswow64\ADVAPI32.DLL
0x76de0000 - 0x76e8c000 C:\Windows\syswow64\msvcrt.dll
0x75230000 - 0x75249000 C:\Windows\SysWOW64\sechost.dll
0x76270000 - 0x76360000 C:\Windows\syswow64\RPCRT4.dll
0x74f10000 - 0x74f70000 C:\Windows\syswow64\SspiCli.dll
0x74f00000 - 0x74f0c000 C:\Windows\syswow64\CRYPTBASE.dll
0x731f0000 - 0x7338e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.DLL
0x76d50000 - 0x76de0000 C:\Windows\syswow64\GDI32.dll
0x76870000 - 0x76970000 C:\Windows\syswow64\USER32.dll
0x74f70000 - 0x74f7a000 C:\Windows\syswow64\LPK.dll
0x761d0000 - 0x7626d000 C:\Windows\syswow64\USP10.dll
0x76520000 - 0x76577000 C:\Windows\syswow64\SHLWAPI.dll
0x75400000 - 0x7604a000 C:\Windows\syswow64\SHELL32.DLL
0x720c0000 - 0x7210c000 C:\Windows\system32\apphelp.dll
0x6f7a0000 - 0x6f82d000 C:\Windows\AppPatch\AcLayers.DLL
0x76b70000 - 0x76ccc000 C:\Windows\syswow64\ole32.dll
0x75320000 - 0x753af000 C:\Windows\syswow64\OLEAUT32.dll
0x73710000 - 0x73727000 C:\Windows\system32\USERENV.dll
0x73700000 - 0x7370b000 C:\Windows\system32\profapi.dll
0x72ac0000 - 0x72b11000 C:\Windows\system32\WINSPOOL.DRV
0x72070000 - 0x72082000 C:\Windows\system32\MPR.dll
0x71d20000 - 0x71f38000 C:\Windows\AppPatch\AcGenral.DLL
0x72bc0000 - 0x72c40000 C:\Windows\system32\UxTheme.dll
0x72a10000 - 0x72a42000 C:\Windows\system32\WINMM.dll
0x73460000 - 0x7346f000 C:\Windows\system32\samcli.dll
0x720a0000 - 0x720b4000 C:\Windows\system32\MSACM32.dll
0x735d0000 - 0x735d9000 C:\Windows\system32\VERSION.dll
0x72a80000 - 0x72a83000 C:\Windows\system32\sfc.dll
0x72090000 - 0x7209d000 C:\Windows\system32\sfc_os.DLL
0x72ba0000 - 0x72bb3000 C:\Windows\system32\dwmapi.dll
0x74f80000 - 0x7511d000 C:\Windows\syswow64\SETUPAPI.dll
0x75250000 - 0x75277000 C:\Windows\syswow64\CFGMGR32.dll
0x76580000 - 0x76592000 C:\Windows\syswow64\DEVOBJ.dll
0x75120000 - 0x75230000 C:\Windows\syswow64\urlmon.dll
0x766a0000 - 0x76858000 C:\Windows\syswow64\iertutil.dll
0x760b0000 - 0x761ca000 C:\Windows\syswow64\WININET.dll
0x777f0000 - 0x777f3000 C:\Windows\syswow64\Normaliz.dll
0x713a0000 - 0x715f9000 C:\Windows\AppPatch\AcXtrnal.DLL
0x74a10000 - 0x74a16000 C:\Windows\system32\SHUNIMPL.DLL
0x749f0000 - 0x74a01000 C:\Windows\system32\SortWindows6Compat.dll
0x76050000 - 0x760b0000 C:\Windows\system32\IMM32.DLL
0x76e90000 - 0x76f5c000 C:\Windows\syswow64\MSCTF.dll
0x6db70000 - 0x6df9b000 c:\program files (x86)\wakfu\jre\bin\server\jvm.dll
0x7c360000 - 0x7c3b6000 C:\Windows\system32\MSVCR71.dll
0x6d7c0000 - 0x6d7e2000 c:\program files (x86)\wakfu\jre\bin\splashscreen.dll
0x6d860000 - 0x6d86c000 c:\program files (x86)\wakfu\jre\bin\verify.dll
0x6d3e0000 - 0x6d3ff000 c:\program files (x86)\wakfu\jre\bin\java.dll
0x6d340000 - 0x6d348000 c:\program files (x86)\wakfu\jre\bin\hpi.dll
0x75280000 - 0x75285000 C:\Windows\syswow64\PSAPI.DLL
0x6d8a0000 - 0x6d8af000 c:\program files (x86)\wakfu\jre\bin\zip.dll
0x6d0b0000 - 0x6d1fa000 C:\Program Files (x86)\Wakfu\jre\bin\awt.dll
0x6d2e0000 - 0x6d334000 C:\Program Files (x86)\Wakfu\jre\bin\fontmanager.dll
0x6d6c0000 - 0x6d6d3000 C:\Program Files (x86)\Wakfu\jre\bin\net.dll
0x76660000 - 0x76695000 C:\Windows\syswow64\WS2_32.dll
0x76860000 - 0x76866000 C:\Windows\syswow64\NSI.dll
0x73500000 - 0x7353c000 C:\Windows\system32\mswsock.dll
0x74c20000 - 0x74c26000 C:\Windows\System32\wship6.dll
0x6d6e0000 - 0x6d6e9000 C:\Program Files (x86)\Wakfu\jre\bin\nio.dll
0x72a60000 - 0x72a76000 C:\Windows\system32\CRYPTSP.dll
0x72e40000 - 0x72e7b000 C:\Windows\system32\rsaenh.dll
0x734f0000 - 0x734f5000 C:\Windows\System32\wshtcpip.dll
0x23a70000 - 0x23abd000 C:\Program Files (x86)\Wakfu\jogl.dll
0x74920000 - 0x749e8000 C:\Windows\system32\OPENGL32.dll
0x748f0000 - 0x74912000 C:\Windows\system32\GLU32.dll
0x73d20000 - 0x73e07000 C:\Windows\system32\DDRAW.dll
0x74c30000 - 0x74c36000 C:\Windows\system32\DCIMAN32.dll
0x72000000 - 0x72010000 C:\Windows\system32\NLAapi.dll
0x71ff0000 - 0x72000000 C:\Windows\system32\napinsp.dll
0x71fd0000 - 0x71fe2000 C:\Windows\system32\pnrpnsp.dll
0x71fa0000 - 0x71fc7000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x734a0000 - 0x734e4000 C:\Windows\system32\DNSAPI.dll
0x71f90000 - 0x71f98000 C:\Windows\System32\winrnr.dll
0x736e0000 - 0x736fc000 C:\Windows\system32\IPHLPAPI.DLL
0x736d0000 - 0x736d7000 C:\Windows\system32\WINNSI.DLL
0x71f40000 - 0x71f46000 C:\Windows\system32\rasadhlp.dll
0x71f50000 - 0x71f88000 C:\Windows\System32\fwpuclnt.dll
0x6d410000 - 0x6d416000 C:\Program Files (x86)\Wakfu\jre\bin\jawt.dll
0x003f0000 - 0x003f5000 C:\Program Files (x86)\Wakfu\jogl_awt.dll
0x69030000 - 0x69d41000 C:\Windows\system32\atioglxx.dll
0x748e0000 - 0x748eb000 C:\Windows\system32\atigktxx.dll
0x74260000 - 0x7430a000 C:\Windows\system32\aticfx32.dll
0x23c80000 - 0x23cb7000 C:\Windows\system32\atiadlxy.dll
0x76630000 - 0x7665d000 C:\Windows\syswow64\WINTRUST.dll
0x769f0000 - 0x76b0d000 C:\Windows\syswow64\CRYPT32.dll
0x76510000 - 0x7651c000 C:\Windows\syswow64\MSASN1.dll
VM Arguments:
jvm_args: -Dexe4j.semaphoreName=c:_program files (x86)_wakfu_wakfu.exe0 -Dexe4j.moduleName=C:\Program Files (x86)\Wakfu\Wakfu.exe -Dexe4j.tempDir=C:\Users\robin\AppData\Local\Temp\e4jEEB4.tmp_dir -Dexe4j.unextractedPosition=367940 -Djava.library.path=C:\Program Files (x86)\Wakfu\.\.;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\EgisTec\MyWinLocker 3\x86;C:\Program Files (x86)\EgisTec\MyWinLocker 3\x64;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Windows Live\Shared;c:\program files (x86)\wakfu\jre\bin -Dexe4j.consoleCodepage=cp0 -server -Xmx320M -Dsun.java2d.noddraw=true -XX:MaxDirectMemorySize=92m -XX:+ForceTimeHighResolution -Dsun.awt.noerasebackground=true -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:CMSIncrementalSafetyFactor=3
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\Program Files (x86)\Wakfu\.\.;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\EgisTec\MyWinLocker 3\x86;C:\Program Files (x86)\EgisTec\MyWinLocker 3\x64;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Windows Live\Shared;c:\program files (x86)\wakfu\jre\bin
USERNAME=robin
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 2, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 Build 7600
CPU:total 4 (8 cores per cpu, 2 threads per core) family 6 model 37 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 4051456k(2634524k free), swap 8101064k(6531556k free)
vm_info: Java HotSpot(TM) Server VM (16.0-b13) for windows-x86 JRE (1.6.0_18-b07), built on Dec 17 2009 13:29:37 by "java_re" with MS VC++ 7.1 (VS2003)
time: Wed Sep 21 15:14:45 2011
elapsed time: 4 seconds
Registers:
C [jogl.dll+0x1167]
Other Threads:
Heap
Dynamic libraries:
VM Arguments:
USERNAME=robin
OS=Windows_NT
So,
I'm not going to get ahead of myself, but often this type of error:
happens when information is stored in a part of your memory that is already occupied.
As a beginner in programming ^^, I've had the same errors.
Wait for another help, I can't assist you, I'm sorry.
The only other option, if you're in a hurry, is to uninstall and reinstall the game and also check if there are any Java updates.
Thank you for your reply. I have already installed the game 3 times along with the updates, the same goes for Java, but thanks anyway ;).
If it’s like in XP,
Click start > right-click on My Computer > properties > choose hardware > Device Manager > right-click on graphics card > properties > Roll back to the previous version.
To access Device Manager on Vista, you need to do the following.
(On Vista, click the blue circle at the bottom left, right-click on Computer, choose Properties, and then click on Device Manager at the top left).
At the moment when I go into its properties, I can't update it either because it has the most recent driver, so I didn't need to do it...
The PC you have, you're not the administrator?
So I suggest you ask someone who knows how to update your components.
Moreover, the error message you have is not resolved for everyone; it might stem from a compatibility issue in 32 or 64-bit mode, your graphics card, or another component.
I tried looking around, and the simplest solution comes from updating your graphics card or, at worst, reducing your screen resolution might also work.
- 1
- 2
Suivant
