Optical cable connection home cinema -> TV
Solved
Jotech Posted messages 786 Registration date   Status Member Last intervention   -
 alghour -
Hello,
So here it is, I bought a LED screen and a home cinema system,
I would like the sound from my LED screen to go through my home cinema. I asked in store and they told me to buy an optical cable, which I did, but nothing changed...
My optical cable is connected to the TV (Optical digital audio out) and then connected to my home cinema (optical)
LED screen: LG 47LE5310 - 119 cm https://www.lcd-compare.com/televiseur-LGLE47LE5310-LG-47LE5310.htm
Home cinema: THOMSON HT400TB https://www.homecine-compare.com/ensemble-home-cinema-THOHT400TB-THOMSON-HT400TB.htm
Thank you in advance for your help
Configuration: Windows 7 / Safari 534.24
A thank you is always appreciated.
  1. Blog_LG_France Posted messages 1870 Status Member 2 044
    Hello Jotech,
    You need to check the output settings of your television. To do this, go to the menu of your TV using the menu button on the remote, then navigate to the "SOUND" section and finally turn your speakers off.
    80
    1. Marif
      Thank you for this information and have a nice day.
      Marie Françoise
    2. alghour
      Thank you
