Sony Bravia TV issue, vertical line on screen
Solved
rhcp111 Posted messages 74 Status Membre -
pablo1954 Posted messages 1 Status Membre -
Hello, I have a problem with my TV screen; there are two vertical lines on the right side of my screen as soon as I turn it on. The TV hasn’t been subjected to any shock, so I would like to know where this could be coming from, and if the problem persists, whether it's possible to claim the warranty.
Thank you in advance
Configuration: Windows XP Internet Explorer 8.0
Gégé
It might be useful for you to specify the model of your TV.
As for me, I encountered a similar problem with my 46X4500. I solved it by slightly enlarging the image in the XrossMediaBar menu under "screen command (for inputs other than PC)" and then "display area," where I enlarged the image so that the edges were outside the visible display area.
You can also seek advice from SONY's customer service at 0149787840.
8
There are flies all over the meadow right now and they're coming onto my Sony! So I decided to clean it with a glass cleaner, screen off of course! And now there are vertical lines all over my Bravia Sony... did the glass cleaner ruin my screen?
-1
