[python] probléme avec un check button
j'ai un probléme, je suis nouveau dans la programmation python et ca fait une semaine que je qalére avec un check button
je veut que mon checkbutton soit cocher quand je charge le frame.
si le checkbutton cocher il y'a un field"A" qui est enbele, et s'il est decocher il y'a un filed "B" qui est enabled et vice vers ca.
voila mon code:
def setFrameStepSelectServices(setupFrame):
setupFrame.createNewFrameStep(SELECT_SERVERS_CONFIG_MESSAGE)
setupFrame.setNextPreviousState(True, True)
rowId=0
f = Frame(setupFrame.centerFrame)
f.grid(row=rowId, sticky=EW)
columnID = 0
#Server list with checkBox
for server in serverList:
if not server in countedServerList:
if not setupFrame.serversList.has_key(server):
setupFrame.serversList[server] = IntVar()
setupFrame.serversList[server].set(True)
"""check = Checkbutton(f, text=server, variable=setupFrame.serversList[server])"""
check = Checkbutton(f, text=DIC_OF_TYPE.get(server,server), variable=setupFrame.serversList[server])
check.grid(row=rowId, column=columnID, sticky=W)
if columnID:
rowId = rowId + 1
columnID = 0
else:
columnID = columnID + 1
if columnID:
rowId = rowId + 1
#Server List with parameters
for server in countedServerList:
#inner = Frame(f)
setupFrame.serversList[server] = StringVar()
setupFrame.serversList[server].set('1')
#if server == 'PROCESSING':
#setupFrame.serversList[server].set('1')
#else:
inner = Frame(f)
rowId = rowId + 1
Label(inner, text=server).pack(side=LEFT)
setupFrame._entryProcessing = Entry(inner,textvariable=setupFrame.serversList[server], width=4, state=NORMAL)
setupFrame._entryProcessing.pack(side=RIGHT)
inner.grid(row=rowId, column=0, sticky=EW)
inner = Frame(f)
setupFrame.ckAsynch = Checkbutton(inner , text="ASYNCHRONE" , variable = setupFrame.ASYN_PROCESSING_.get(), onvalue="y", offvalue="n" )
setupFrame.ckAsynch.pack(side=LEFT)
inner.grid(row=rowId, column=1, sticky=EW)
rowId = rowId + 1
inner = Frame(f)
Label(inner, text="THREAD_COUNTER").pack(side=LEFT)
setupFrame._entryMaxTh =Entry(inner,textvariable=setupFrame.MAXTHREAD_PROCESSING_, width=4, state=NORMAL)
setupFrame._entryMaxTh.pack(side=RIGHT)
rowId = rowId + 1
else:
rowId = rowId + 1
inner = Frame(f)
_entry = Entry(inner,textvariable=setupFrame.serversList[server], width=4)
_entry.pack(side=RIGHT)
rowId = rowId + 1
setupFrame.ckAsynch.bind("<ButtonPress>",lambda event : ON_ASYNCHRONE_CHECKED(setupFrame,event))
ON_ASYNCHRONE_CHECKED(setupFrame,None)
def ON_ASYNCHRONE_CHECKED(setupFrame,evt):
X=setupFrame.ASYN_PROCESSING_.get()
if X=="y":
#self._entryMaxTh=1
setupFrame._entryMaxTh.delete(0,END)
setupFrame._entryMaxTh.insert(INSERT,1)
setupFrame._entryProcessing.config(state = NORMAL)
setupFrame._entryMaxTh.config(state = DISABLED)
else:
#self._entryProcessing=1
setupFrame._entryProcessing.delete(0,END)
setupFrame._entryProcessing.insert(INSERT,1)
#self._entryProcessing.enable =false
setupFrame._entryProcessing.config(state = DISABLED)
setupFrame._entryMaxTh.config(state = NORMAL)
le setupFrame.ASYN_PROCESSING_.get() contient "y"
mon probléme est que mon check button quand le frame est charger est décocher alors que ca valeur est "y"
et puis quand je le coche est le decoche il n'ya rien qui se passe
s'il vous plait peut etre que c'est debile mais vraiment jy' arrive pas, donc SOS
merci pour votre aide
  1. s'il vous plait un minimum d'aide:((
    y'a personne qui a une idéé??
    1. si quelqu'un aura le meme probléme que moi, voila comment faire
      au lieu de
      faire
      setupFrame.variable = StringVar()
      setupFrame.variable.set(setupFrame.ASYN_PROCESSING_.get())
      setupFrame.ckAsynch = Checkbutton(inner , text="ASYNCHRONE" , variable = setupFrame.variable, onvalue="y", offvalue="n" )
      X=setupFrame.variable.get()#
      1. Salut,
        vous avez mis trop de code, j'ai pas pu suivre, désolé!
        1. ca ne fait rien, merci commeme ,
          la prochaine fois j'essayerai de faire le tri
