Problème avec Security Warning Spyware !!
j'ai plusieurs problèmes! Au démarrage, j'ai "security warning spyware detection alert" qui se met en route, ainsi que des messages d'erreurs genre "Regsvr32loadlibrary module introuvable" ou "C:/programfiles/potonqju/pqnsdszs.dll"
Bref je comprends rien!
En + quand je vais sur internet il y a pleins de pubs qui s'affichent ce qui n'était jms arrivé auparavant...
J'ai fais 2 rapports : 1 avec SDfix qui donne
SDFix: Version 1.113
Run by Sally on 07/11/2007 at 11:49
Microsoft Windows XP [version 5.1.2600]
Running From: C:\SDFix
Safe Mode:
Checking Services:
Restoring Windows Registry Values
Restoring Windows Default Hosts File
Rebooting...
Normal Mode:
Checking Files:
Trojan Files Found:
C:\WINDOWS\SYSTEM32\KERNEL32.EXE - Deleted
C:\WINDOWS\SYSTEM32\VVGEOWBV.EXE - Deleted
C:\WINDOWS\system32\ntos.exe - Deleted
Removing Temp Files...
ADS Check:
C:\WINDOWS
No streams found.
C:\WINDOWS\system32
No streams found.
No streams found.
C:\WINDOWS\system32\ntoskrnl.exe
No streams found.
Final Check:
catchme 0.3.1253 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2007-11-07 12:02:51
Windows 5.1.2600 Service Pack 2 NTFS
detected NTDLL code modification:
ZwEnumerateKey, ZwEnumerateValueKey, ZwQueryValueKey, ZwQueryDirectoryFile, ZwQuerySystemInformation
scanning hidden processes ...
scanning hidden services & system hive ...
scanning hidden registry entries ...
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"System"="cspik.exe"
scanning hidden files ...
C:\WINDOWS\System32\cspik.exe 52752 bytes executable
scan completed successfully
hidden processes: 0
hidden services: 0
hidden files: 1
Remaining Services:
Authorized Application Key Export:
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
"%windir%\\system32\\sessmgr.exe"="%windir%\\system32\\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"C:\\Program Files\\Messenger\\msmsgs.exe"="C:\\Program Files\\Messenger\\msmsgs.exe:*:Enabled:Windows Messenger"
"C:\\Program Files\\MSN Messenger\\msnmsgr.exe"="C:\\Program Files\\MSN Messenger\\msnmsgr.exe:*:Enabled:Windows Live Messenger 8.1"
"C:\\Program Files\\MSN Messenger\\livecall.exe"="C:\\Program Files\\MSN Messenger\\livecall.exe:*:Enabled:Windows Live Messenger 8.1 (Phone)"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe:*:Enabled:hpqste08.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe:*:Enabled:hpofxm08.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe:*:Enabled:hposfx08.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe:*:Enabled:hposid01.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqscnvw.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqscnvw.exe:*:Enabled:hpqscnvw.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe:*:Enabled:hpqkygrp.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe:*:Enabled:hpqcopy.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe:*:Enabled:hpfccopy.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe:*:Enabled:hpzwiz01.exe"
"C:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"="C:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe:*:Enabled:hpqphunl.exe"
"C:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"="C:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe:*:Enabled:hpoews01.exe"
"C:\\Program Files\\iTunes\\iTunes.exe"="C:\\Program Files\\iTunes\\iTunes.exe:*:Enabled:iTunes"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
Remaining Files:
File Backups: - C:\SDFix\backups\backups.zip
Files with Hidden Attributes:
Tue 6 Nov 2007 40,183 ..SH. --- "C:\Program Files\Fichiers communs\Yazzle1162OinUninstaller.exe"
Wed 4 Aug 2004 1,667,584 ..SH. --- "C:\Program Files\Messenger\msmsgs.exe"
Mon 5 Nov 2007 6,505 ..SH. --- "C:\WINDOWS\system32\hilnn.bak1"
Wed 7 Nov 2007 252,668 ..SH. --- "C:\WINDOWS\system32\hilnn.bak2"
Tue 16 Jan 2007 4,348 ..SH. --- "C:\Documents and Settings\All Users\DRM\DRMv1.bak"
Tue 6 Nov 2007 2,032 ...HR --- "C:\Documents and Settings\Sally\Mes documents\Ma musique\AVI-MPEG-ASK-WMV Splitter v2.31 serial keygen.zip"
Tue 6 Nov 2007 2,032 ...HR --- "C:\Documents and Settings\Sally\Mes documents\Ma musique\Chemdraw 6 serial keygen.zip"
Tue 6 Nov 2007 653 ...HR --- "C:\Documents and Settings\Sally\Mes documents\Ma musique\TMPGEnc DVD Author v1.5.11.37 serial keygen.zip"
Finished!
Et un autre rapport avec HIJACKthis qui donne
Logfile of HijackThis v1.99.1
Scan saved at 12:13:10, on 07/11/2007
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\System32\alg.exe
C:\WINDOWS\system32\notepad.exe
C:\WINDOWS\system32\TPWRTRAY.EXE
C:\Program Files\TOSHIBA\TouchED\TouchED.Exe
C:\Program Files\Apoint2K\Apoint.exe
C:\WINDOWS\system32\00THotkey.exe
C:\Program Files\TOSHIBA\Commandes TOSHIBA\TFncKy.exe
C:\Program Files\Winamp\winampa.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\Program Files\Apoint2K\Apntex.exe
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Hercules\Audio\Gamesurround Muse Pocket\MuseCPL.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\WINDOWS\system32\janftcdk.exe
C:\Documents and Settings\Sally\Bureau\Marc\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.google.fr/?gws_rd=ssl
O3 - Toolbar: Security Toolbar - {11A69AE4-FBED-4832-A2BF-45AF82825583} - C:\WINDOWS\system32\gbdnwbyb.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE NvQTwk,NvCplDaemon initialize
O4 - HKLM\..\Run: [nwiz] nwiz.exe /installquiet
O4 - HKLM\..\Run: [Tpwrtray] TPWRTRAY.EXE
O4 - HKLM\..\Run: [TouchED] C:\Program Files\TOSHIBA\TouchED\TouchED.Exe
O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
O4 - HKLM\..\Run: [00THotkey] C:\WINDOWS\system32\00THotkey.exe
O4 - HKLM\..\Run: [000StTHK] 000StTHK.exe
O4 - HKLM\..\Run: [TFncKy] TFncKy.exe /Type 20
O4 - HKLM\..\Run: [WinampAgent] C:\Program Files\Winamp\winampa.exe
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe"
O4 - HKLM\..\Run: [iTunesHelper] C:\Program Files\iTunes\iTunesHelper.exe
O4 - HKLM\..\Run: [bkvunoji] rundll32.exe "C:\Program Files\wfilohmp\qzgjsbsx.dll",Init
O4 - HKLM\..\Run: [1cb1e871] rundll32.exe "C:\WINDOWS\system32\cwxluooe.dll",b
O4 - HKLM\..\Run: [CTDrive] rundll32.exe C:\WINDOWS\system32\drvfib.dll,startup
O4 - HKCU\..\Run: [MsgCenterExe] "C:\Program Files\Fichiers communs\Real\Update_OB\RealOneMessageCenter.exe" -osboot
O4 - HKCU\..\Run: [Tshu] "C:\WINDOWS\system32\FNTS~1\winspool.exe" -vt yazb
O4 - Global Startup: Gamesurround Muse Pocket.lnk = C:\Program Files\Hercules\Audio\Gamesurround Muse Pocket\MuseCPL.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: PC Health.lnk = C:\Program Files\TOSHIBA\TOSHIBA Management Console\TOSHealthLocalS.vbs
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object) - http://download.divx.com/player/DivXBrowserPlugin.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{51E29E68-418F-4B8B-961E-53D87EDDC785}: NameServer = 85.255.116.152,85.255.112.8
O17 - HKLM\System\CCS\Services\Tcpip\..\{C1CFDACA-B40C-4942-A9F5-1CAFDA753EC8}: NameServer = 85.255.116.152,85.255.112.8
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.116.152 85.255.112.8
O17 - HKLM\System\CS3\Services\Tcpip\Parameters: NameServer = 85.255.116.152 85.255.112.8
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.116.152 85.255.112.8
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O20 - AppInit_DLLs: C:\WINDOWS\system32\__c0071094.dat
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: DomainService - - C:\WINDOWS\system32\janftcdk.exe
O23 - Service: iPod Service (iPodService) - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
JE NE SAIS ABSOLUMENT PAS QUOI FAIRE !!!
Si quelqu"un peut m'aider !!!
Merci d'avance
Configuration: Windows XP pro
  1. Contributeur sécurité
    slt,
    tu as plusieurs infections:
    1/
    # Télécharger FixWareout sur le bureau :
    http://downloads.subratam.org/Fixwareout.exe
    # Lancer le fix : cliquer sur Next, puis Install, s’assurer que l’option Run fixit est activée puis cliquer sur Finish.
    # Il sera demandé ensuite de redémarrer l’ordinateur : redémarrer le.
    # Si le système met un peu plus de temps au démarrage, c'est normal.
    # Le contenu du rapport qui s'affichera à l'écran sera enregistrai dans un fichier nommé report.txt.
    # Ensuite : relancer HijackThis, les lignes 017 ne devraient à présent plus apparaitre, si ce n'est pas le cas, choisir do a scan only, puis cocher la case devant les lignes ci-dessous et cliquer en bas sur fix checked :
    # Refaire un hijackthis, et s'assurer que les lignes 017 pointant vers l'Ukraine ont bien disparues.
    _____________________________
    2/
    scan avec vundo (colle le rapport)
    Téléchargez VundoFix -> http://www.atribune.org/ccount/click.php?id=4
    Double cliquez VundoFix.exe pour l'exécuter.
    Quand VundoFix s'ouvre, cliquez sur le bouton Scan for Vundo.
    Une fois le scan fini, cliquez sur le bouton Remove Vundo.
    Vous recevrez un avertissement vous demandant si vous voulez effacer ces
    fichiers répondez en cliquant sur YES
    Une fois que vous avez cliqué yes, votre bureau deviendra vide au moment où il
    enlève Vundo.
    Quand c'est fini, il vous sera demandé de redémarrer votre ordinateur, cliquez
    OK.
    ________________________________
    3/ combofix (colle le rapport)
    http://www.techsupportforum.com/sectools/sUBs/ComboFix.exe
    4/
    télécharger sur le bureau
    Navilog.zip
    http://perso.orange.fr/il.mafioso/Navifix/Navilog1.exe
    = Double-Clic navilog1.zip
    = Extraire tout sur le bureau
    = Double-Clic navilog1 qui est sur le bureau
    = Appuyer sur une touche jusqu' arriver aux options
    = Choisir option 1
    un rapport : fixnavi.txt dans C : va se creer
    le copier/coller dans ton prochain message.
    PS:Si ton bureau ne réapparait pas, fais CTRL+ALT+SUPP pour ouvrir le gestionnaire de tâches.
    Puis rends-toi à l'onglet "processus". Clique en haut à gauche sur fichiers et choisis "exécuter"
    Tape explorer et valide. Celà te fera apparaitre ton bureau.
    et recolle un rapport hijackthis
