Carousel ne fonctionne pas
J'ai ajouté un caroussel sur mon site avec le framework bootstrap 4 mais il ne fonctionne pas. Je n'arrive pas a passer d'une image à l'autre, il reste statique.
    <link href="//maxcdn.bootstrapcdn.com/font-awesome/4.2.0/css/font-awesome.min.css" rel="stylesheet">
		<link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/4.0.0-alpha.6/css/bootstrap.min.css" integrity="sha384-rwoIResjU2yc3z8GV/NPeZWAv56rSmLldC3R/AZzGRnGxQQKnKkoFVhFQhNUwEyJ" crossorigin="anonymous">
		<script src="https://maxcdn.bootstrapcdn.com/bootstrap/4.0.0-alpha.6/js/bootstrap.min.js" integrity="sha384-vBWWzlZJ8ea9aCX4pEW3rVHjgjt7zpkNpZk+02D9phzyeVkE+jo0ieGizqPLForn" crossorigin="anonymous"></script>
		<link rel="stylesheet" type="text/css" href="views/css/styles.css">
	</head>
    <div id="myCarousel" class="carousel slide" data-ride="carousel">
      <ol class="carousel-indicators">
        <li data-target="#myCarousel" data-slide-to="0" class="active"></li>
        <li data-target="#myCarousel" data-slide-to="1"></li>
        <li data-target="#myCarousel" data-slide-to="2"></li>
      </ol>
      <div class="carousel-inner">
        <div class="carousel-item active">
          <img class="first-slide" src="http://chezalfred.info/wp-content/uploads/2016/06/programmation-informatique.png" alt="First slide">
          <div class="container">
            <div class="carousel-caption d-none d-md-block text-left">
              <h1>TEST</h1>
              <p>TEST TEST TEST</p>
              <p><a class="btn btn-lg btn-primary" href="#" rel="nofollow noopener noreferrer" target="_blank" role="button">Enregistrez vous</a></p>
            </div>
          </div>
        </div>
        <div class="carousel-item">
          <img class="second-slide" src="http://static.hitek.fr/img/actualite/matrice.jpg" alt="Second slide">
            <div class="carousel-caption d-none d-md-block">
              <h1>TEST 2</h1>
              <p>Page test 2</p>
              <p><a class="btn btn-lg btn-primary" href="#" rel="nofollow noopener noreferrer" target="_blank" role="button">TEST 2</a></p>
            </div>
          </div>
        </div>
      <a class="carousel-control-prev" href="#myCarousel" rel="nofollow noopener noreferrer" target="_blank" role="button" data-slide="prev">
        <span class="carousel-control-prev-icon" aria-hidden="true"></span>
        <span class="sr-only">Previous</span>
      </a>
      <a class="carousel-control-next" href="#myCarousel" rel="nofollow noopener noreferrer" target="_blank" role="button" data-slide="next">
        <span class="carousel-control-next-icon" aria-hidden="true"></span>
        <span class="sr-only">Next</span>
      </a>
    </div>
  1. Salut,
    As tu des erreurs dans la console de développement de ton navigateur ?
    N'aurais-tu pas oublier d'inclure le script jQuery ?
    Bonne journée,
    1. Bonjour, je n'ai aucune erreur.
      J'ai tenté de rajouter cette ligne de code, mais cela ne fonctionne toujours pas.
      <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
    2. Effectivement il y avait des erreurs et je l'ai ai corrigé. Je devais charger le jquery avant le bootstrap.min.js.
      Merci !
