Probleme d'ajout de donnée dans BDD
Bonjour, j'ai crée un formulaire pour ajouté un produit a la base de donnée mais il marche plus . mercii
<?php
include_once('includes/connect_database.php');
include_once('functions.php');
<div id="content" class="container col-md-12">
<?php
$sql_query = "SELECT cat_id, cat_title
FROM categories
ORDER BY cat_id ASC";
$stmt_category = $connect->stmt_init();
if($stmt_category->prepare($sql_query)) {
// Execute query
$stmt_category->execute();
// store result
$stmt_category->store_result();
$stmt_category->bind_result($category_data['cat_id'],
$category_data['cat_title']
// marque
$sql_query = "SELECT marque_id, marque_title
FROM marques
ORDER BY marque_id ASC";
$stmt_marque = $connect->stmt_init();
if($stmt_marque->prepare($sql_query)) {
// Execute query
$stmt_marque->execute();
// store result
$stmt_marque->store_result();
$stmt_marque->bind_result($marque_data['marque_id'],
$marque_data['marque_title']
// get currency symbol from setting table
$sql_query = "SELECT Value
FROM tbl_setting
WHERE Variable = 'Currency'";
$stmt = $connect->stmt_init();
if($stmt->prepare($sql_query)) {
// Execute query
$stmt->execute();
// store result
$stmt->store_result();
$stmt->bind_result($currency);
$stmt->fetch();
$stmt->close();
//$max_serve = 10;
if(isset($_POST['btnAdd'])){
$product_title = $_POST['product_title'];
$product_category_id = $_POST['category_ID'];
$product_marque_id = $_POST['product_marque_id'];
$product_price = $_POST['product_price'];
$serve_for = $_POST['serve_for'];
$product_description = $_POST['product_description'];
$product_quantity = $_POST['product_quantity'];
// get image info
$product_image = $_FILES['product_image']['name'];
$image_error = $_FILES['product_image']['error'];
$image_type = $_FILES['product_image']['type'];
// create array variable to handle error
$error = array();
if(empty($product_title)){
$error['product_title'] = " <span class='label label-danger'>Required!</span>";
if(empty($product_category_id)){
$error['product_category_id'] = " <span class='label label-danger'>Required!</span>";
if(empty($product_marque_id)){
$error['product_marque_id'] = " <span class='label label-danger'>Required!</span>";
if(empty($product_price)){
$error['product_price'] = " <span class='label label-danger'>Required!</span>";
}else if(!is_numeric($product_price)){
$error['product_price'] = " <span class='label label-danger'>product_price in number!</span>";
if(empty($product_quantity)){
$error['product_quantity'] = " <span class='label label-danger'>Required!</span>";
}else if(!is_numeric($product_quantity)){
$error['product_quantity'] = " <span class='label label-danger'>product_quantity in number!</span>";
if(empty($serve_for)){
$error['serve_for'] = " <span class='label label-danger'>Not choosen</span>";
if(empty($product_description)){
$error['product_description'] = " <span class='label label-danger'>Required!</span>";
// common image file extensions
$allowedExts = array("gif", "jpeg", "jpg", "png");
// get image file extension
error_reporting(E_ERROR | E_PARSE);
$extension = end(explode(".", $_FILES["product_image"]["name"]));
if($image_error > 0){
$error['product_image'] = " <span class='label label-danger'>Not uploaded!</span>";
}else if(!(($image_type == "image/gif") ||
($image_type == "image/jpeg") ||
($image_type == "image/jpg") ||
($image_type == "image/x-png") ||
($image_type == "image/png") ||
($image_type == "image/pjpeg")) &&
!(in_array($extension, $allowedExts))){
$error['product_image'] = " <span class='label label-danger'>Image type must jpg, jpeg, gif, or png!</span>";
if(!empty($product_title) && !empty($product_category_id)&& !empty($product_marque_id) && !empty($product_price) && is_numeric($product_price) &&
!empty($serve_for) && empty($error['product_image']) && !empty($product_description) && !empty($product_quantity) && is_numeric($product_quantity)){
// create random image file name
$string = '0123456789';
$file = preg_replace("/\s+/", "_", $_FILES['product_image']['name']);
$function = new functions;
$product_image = $function->get_random_string($string, 4)."-".date("Y-m-d").".".$extension;
// upload new image
$upload = move_uploaded_file($_FILES['product_image']['tmp_name'], 'upload/images/'.$product_image);
// insert new data to menu table
$sql_query = "INSERT INTO products (product_title, product_category_id,product_marque_id, product_price, Serve_for, product_image, product_description, product_quantity)
VALUES(?, ?, ?, ?, ?, ?, ?, ?)";
$upload_image = 'upload/images/'.$product_image;
// Bind your variables to replace the ?s
$stmt->bind_param('sssssss',
$product_title,
$product_category_id,
$product_marque_id,
$product_price,
$serve_for,
$upload_image,
$product_description,
$product_quantity
// Execute query
$stmt->execute();
// store result
$result = $stmt->store_result();
$stmt->close();
if($result){
$error['add_menu'] = " <span class='label label-primary'>Success Added</span>";
}else {
$error['add_menu'] = " <span class='label label-danger'>Failed</span>";
<div class="col-md-12">
<h1>Add Menu <?php echo isset($error['add_menu']) ? $error['add_menu'] : '';?></h1>
<hr />
</div>
<form method="post" enctype="multipart/form-data">
<div class="col-md-9">
<label>Menu Name :</label><?php echo isset($error['product_title']) ? $error['product_title'] : '';?>
<input type="text" class="form-control" name="product_title"/>
</div>
<div class="col-md-3">
<br>
<label>product_price (<?php echo $currency;?>) :</label><?php echo isset($error['product_price']) ? $error['product_price']:'';?>
<input type="text" class="form-control" name="product_price"/>
<br/>
<label>Stock :</label><?php echo isset($error['product_quantity']) ? $error['product_quantity']:'';?>
<input type="text" class="form-control" name="product_quantity"/>
<br/>
<label>Status :</label><?php echo isset($error['serve_for']) ? $error['serve_for'] : '';?>
<select name="serve_for" class="form-control">
<option>Available</option>
<option>Sold Out</option>
</select>
<br/>
<label>Category :</label><?php echo isset($error['product_category_id']) ? $error['product_category_id'] : '';?>
<select name="category_ID" class="form-control">
<?php while($stmt_category->fetch()){ ?>
<option value="<?php echo $category_data['cat_id']; ?>"><?php echo $category_data['cat_title']; ?></option>
<?php } ?>
</select>
<label>Marque :</label><?php echo isset($error['product_marque_id']) ? $error['product_marque_id'] : '';?>
<select name="product_marque_id" class="form-control">
<?php while($stmt_marque->fetch()){ ?>
<option value="<?php echo $marque_data['marque_id']; ?>"><?php echo $marque_data['marque_title']; ?></option>
<?php } ?>
</select>
<br/>
<label>Image :</label><?php echo isset($error['product_image']) ? $error['product_image'] : '';?>
<input type="file" name="product_image" id="product_image"/>
</div>
<br>
<label>product_description :</label><?php echo isset($error['product_description']) ? $error['product_description'] : '';?>
<textarea name="product_description" id="product_description" class="form-control" rows="16"></textarea>
<script type="text/javascript" src="css/js/ckeditor/ckeditor.js"></script>
<script type="text/javascript">
CKEDITOR.replace( 'product_description' );
</script>
</div>
</div>
<br/>
<div class="panel panel-default">
<div class="panel-heading">Add</div>
<div class="panel-body">
<input type="submit" class="btn-primary btn" value="Add" name="btnAdd" />
<input type="reset" class="btn-danger btn" value="Clear"/>
</div>
</div>
</div>
</form>
</div>
<div class="separator"> </div>
</div>
<?php
$stmt_category->close();
include_once('includes/close_database.php'); ?>
ModérateurBonjour,
Déjà ... On place le code PHP ... AVANT TOUT LE HTML.
Ca le rend plus simple à lire ....
Voici ton code remis en forme un peu mieux....<?php //Affichage des erreurs PHP '(à mettre au DEBUT de ta page php ! ) error_reporting(E_ALL); // Connexion à la BDD + Fichier de fonctions include_once('includes/connect_database.php'); include_once('functions.php'); $sql_query = "SELECT cat_id, cat_title FROM categories ORDER BY cat_id ASC"; $stmt_category = $connect->stmt_init(); if($stmt_category->prepare($sql_query)) { // Execute query $stmt_category->execute(); // store result $stmt_category->store_result(); $stmt_category->bind_result($category_data['cat_id'], $category_data['cat_title'] ); } // marque $sql_query = "SELECT marque_id, marque_title FROM marques ORDER BY marque_id ASC"; $stmt_marque = $connect->stmt_init(); if($stmt_marque->prepare($sql_query)) { // Execute query $stmt_marque->execute(); // store result $stmt_marque->store_result(); $stmt_marque->bind_result($marque_data['marque_id'], $marque_data['marque_title'] ); } // get currency symbol from setting table $sql_query = "SELECT Value FROM tbl_setting WHERE Variable = 'Currency'"; $stmt = $connect->stmt_init(); if($stmt->prepare($sql_query)) { // Execute query $stmt->execute(); // store result $stmt->store_result(); $stmt->bind_result($currency); $stmt->fetch(); $stmt->close(); } //$max_serve = 10; // RECUPERATION PROPRE DES VARIABLES AVANT DE LES UTILISER $product_title = isset($_POST['product_title']) ? $_POST['product_title'] : NULL; $product_category_id = isset($_POST['category_ID']) ? $_POST['category_ID'] : NULL; $product_marque_id = isset($_POST['product_marque_id']) ? $_POST['product_marque_id'] : NULL; $product_price = isset($_POST['product_price']) ? $_POST['product_price'] : NULL ; $serve_for = isset($_POST['serve_for']) ? $_POST['serve_for']: NULL; $product_description = isset($_POST['product_description']) ? $_POST['product_description'] : NULL; $product_quantity = isset($_POST['product_quantity']) ? $_POST['product_quantity'] : NULL; // get image info $product_image = !empty($_FILES['product_image']['name']) ? $_FILES['product_image']['name'] : NULL; $image_error = !empty($_FILES['product_image']['error']) ? $_FILES['product_image']['error'] : NULL; $image_type = !empty($_FILES['product_image']['type']) ? $_FILES['product_image']['type'] : NULL; //Traitement du submit if(isset($_POST['btnAdd'])){ // create array variable to handle error $error = array(); if(empty($product_title)){ $error['product_title'] = " <span class='label label-danger'>Required!</span>"; } if(empty($product_category_id)){ $error['product_category_id'] = " <span class='label label-danger'>Required!</span>"; } if(empty($product_marque_id)){ $error['product_marque_id'] = " <span class='label label-danger'>Required!</span>"; } if(empty($product_price)){ $error['product_price'] = " <span class='label label-danger'>Required!</span>"; }else if(!is_numeric($product_price)){ $error['product_price'] = " <span class='label label-danger'>product_price in number!</span>"; } if(empty($product_quantity)){ $error['product_quantity'] = " <span class='label label-danger'>Required!</span>"; }else if(!is_numeric($product_quantity)){ $error['product_quantity'] = " <span class='label label-danger'>product_quantity in number!</span>"; } if(empty($serve_for)){ $error['serve_for'] = " <span class='label label-danger'>Not choosen</span>"; } if(empty($product_description)){ $error['product_description'] = " <span class='label label-danger'>Required!</span>"; } // common image file extensions $allowedExts = array("gif", "jpeg", "jpg", "png"); // get image file extension $extension = end(explode(".", $_FILES["product_image"]["name"])); if($image_error > 0){ $error['product_image'] = " <span class='label label-danger'>Not uploaded!</span>"; }else if(!(($image_type == "image/gif") || ($image_type == "image/jpeg") || ($image_type == "image/jpg") || ($image_type == "image/x-png") || ($image_type == "image/png") || ($image_type == "image/pjpeg")) && !(in_array($extension, $allowedExts))){ $error['product_image'] = " <span class='label label-danger'>Image type must jpg, jpeg, gif, or png!</span>"; } if(!empty($product_title) && !empty($product_category_id)&& !empty($product_marque_id) && !empty($product_price) && is_numeric($product_price) && !empty($serve_for) && empty($error['product_image']) && !empty($product_description) && !empty($product_quantity) && is_numeric($product_quantity)){ // create random image file name $string = '0123456789'; $file = preg_replace("/\s+/", "_", $_FILES['product_image']['name']); $function = new functions; $product_image = $function->get_random_string($string, 4)."-".date("Y-m-d").".".$extension; // upload new image $upload = move_uploaded_file($_FILES['product_image']['tmp_name'], 'upload/images/'.$product_image); // insert new data to menu table $sql_query = "INSERT INTO products (product_title, product_category_id,product_marque_id, product_price, Serve_for, product_image, product_description, product_quantity) VALUES(?, ?, ?, ?, ?, ?, ?, ?)"; $upload_image = 'upload/images/'.$product_image; $stmt = $connect->stmt_init(); if($stmt->prepare($sql_query)) { // Bind your variables to replace the ?s $stmt->bind_param('sssssss', $product_title, $product_category_id, $product_marque_id, $product_price, $serve_for, $upload_image, $product_description, $product_quantity ); // Execute query $stmt->execute(); // store result $result = $stmt->store_result(); $stmt->close(); } if($result){ $error['add_menu'] = " <span class='label label-primary'>Success Added</span>"; }else { $error['add_menu'] = " <span class='label label-danger'>Failed</span>"; } } } ?> <!-- Le HTML --> <div id="content" class="container col-md-12"> <div class="col-md-12"> <h1>Add Menu <?php echo isset($error['add_menu']) ? $error['add_menu'] : '';?></h1> <hr /> </div> <div class="col-md-12"> <form method="post" enctype="multipart/form-data"> <div class="col-md-9"> <div class="col-md-12"> <label>Menu Name :</label><?php echo isset($error['product_title']) ? $error['product_title'] : '';?> <input type="text" class="form-control" name="product_title"/> </div> <div class="col-md-3"> <br> <label>product_price (<?php echo $currency;?>) :</label><?php echo isset($error['product_price']) ? $error['product_price']:'';?> <input type="text" class="form-control" name="product_price"/> <br/> <label>Stock :</label><?php echo isset($error['product_quantity']) ? $error['product_quantity']:'';?> <input type="text" class="form-control" name="product_quantity"/> <br/> <label>Status :</label><?php echo isset($error['serve_for']) ? $error['serve_for'] : '';?> <select name="serve_for" class="form-control"> <option>Available</option> <option>Sold Out</option> </select> <br/> <label>Category :</label><?php echo isset($error['product_category_id']) ? $error['product_category_id'] : '';?> <select name="category_ID" class="form-control"> <?php while($stmt_category->fetch()){ ?> <option value="<?php echo $category_data['cat_id']; ?>"><?php echo $category_data['cat_title']; ?></option> <?php } ?> </select> <label>Marque :</label><?php echo isset($error['product_marque_id']) ? $error['product_marque_id'] : '';?> <select name="product_marque_id" class="form-control"> <?php while($stmt_marque->fetch()){ ?> <option value="<?php echo $marque_data['marque_id']; ?>"><?php echo $marque_data['marque_title']; ?></option> <?php } ?> </select> <br/> <label>Image :</label><?php echo isset($error['product_image']) ? $error['product_image'] : '';?> <input type="file" name="product_image" id="product_image"/> </div> <div class="col-md-9"> <br> <label>product_description :</label><?php echo isset($error['product_description']) ? $error['product_description'] : '';?> <textarea name="product_description" id="product_description" class="form-control" rows="16"></textarea> <script type="text/javascript" src="css/js/ckeditor/ckeditor.js"></script> <script type="text/javascript"> CKEDITOR.replace( 'product_description' ); </script> </div> </div> <br/> <div class="col-md-3"> <div class="panel panel-default"> <div class="panel-heading">Add</div> <div class="panel-body"> <input type="submit" class="btn-primary btn" value="Add" name="btnAdd" /> <input type="reset" class="btn-danger btn" value="Clear"/> </div> </div> </div> </form> </div> <div class="separator"> </div> </div> <?php $stmt_category->close(); include_once('includes/close_database.php'); ?>
Ensuite.....
Vires moi tous cesif($stmt->prepare($sql_query)) {
et utilises donc des bloc TRY / CATCH !!
par exemple :<?php $upload_image = 'upload/images/'.$product_image; try{ // insert new data to menu table $sql = "INSERT INTO products (product_title, product_category_id,product_marque_id, product_price, Serve_for, product_image, product_description, product_quantity) VALUES(?, ?, ?, ?, ?, ?, ?, ?)"; $a_datas = array('sssssss', $product_title, $product_category_id, $product_marque_id, $product_price, $serve_for, $upload_image, $product_description, $product_quantity ); $stmt = $connect->stmt_init(); $prepare = $stmt->prepare($sql_query) { // Execute query $result = $prepare->execute($a_datas); $stmt->close(); }catch(Exception $e){ echo "<br><b>Erreur !</b>"; echo "<br><b>Requete SQL :</b> ".$sql; echo "<br><b>a_datas = </b><br>"; print_r($a_datas); }
Cordialement,
Jordane
