Problème d'enregistrement base MySQL
je n'arrive pas a inscrire des information dans ma base de données grace aux requetes préparées.
pouvez vous m'aider?
Code formulaire:
<form method="post" action="Traitement.php" id="contact_form">
<div class="form-group-name">
<label for="name">Name</label>
<input type="text" name="name" id="name" placeholder="Your Name here" required />
</div>
<div class="form-group-email">
<label for="email">Email</label>
<input type="email" name="email" id="email" placeholder="Valid Email please" required />
</div>
<div class="form-group-message">
<label for="message">Message</label>
<textarea name="message" id="message" rows="10" cols="10" placeholder="Write your message HERE" required ></textarea>
</div>
<div class="form-group-send">
<input type="submit" value="Send" name="valid" style="font-family: '3dumbregular', Arial,sans-serif; font-size: 1.5em;"/>
</div>
</form>
code PHP:
<?php
try
$bdd = new PDO('mysql:host=localhost;dbname=****', '****', '****', array(PDO::ATTR_ERRMODE => PDO::ERRMODE_EXCEPTION));
catch(Exception $e)
die('Erreur : '.$e->getMessage());
if(isset($_POST['name']) && isset($_POST['email']) && isset($_POST['message']))
$to = "Souleymane_555@hotmail.com";
$subject = "contact_form";
$message = 'Nom : ' . $_POST['name'] . "\r\n";
$message .= 'Adresse mail : ' . $_POST['email'] . "\r\n";
$message .= 'Message : ' . $_POST['message'];
$from = $_POST['email'];
$headers = "From: " . $from . "\r\n" ;
mail($to,$subject,$message,$headers);
else {
header('Location: notsent.html');
$nom = htmlspecialchars($_POST['name']);
$email = htmlspecialchars($_POST['email']);
$msg = htmlspecialchars($_POST['message']);
$req = $bdd->prepare('INSERT INTO message_perso (nom, email, msg) VALUES(:nom, :email, :msg');
$req->execute(array(
'nom' => $nom,
'email' => $email,
'msg' => $msg ));
cela me met ces erreur:
Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1' in C:\wamp\www\New Project\Traitement.php on line 42
PDOException: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 in C:\wamp\www\New Project\Traitement.php on line 42
la ligne 42 correspond a la dernière ligne"msg => $msg"
Code formulaire:
</div>
</div>
</div>
</div>
</form>
code PHP:
<?php
try
catch(Exception $e)
else {
'nom' => $nom,
'email' => $email,
'msg' => $msg ));
http://www.google.fr/...
c parce que j'ai pas trouvé labas que je viens demander de l'aide ici
Salut!
C'est une erreur que tu peut corriger tout seul... Avant de venir poster, relis correctement ton script... Soit plus rigoureux...
L'erreur viens de ta requête préparé...
Il y a un léger soucis avec cette ligne!
Le prochaine fois, relis-toi mieux!
Merci, vraiment, j'ai beaucoup lu mais j'avais pas vu cela
a croire que je suis aveugle.
dsl du dérangement !!!
