Probleme wifi
Bonjour, je viens d'installer linux mint 14 sur un presario c500, tout marche bien, mais impossible d'avoir le wifi (il est active dans le bios,)j'ai beau appuyer sur le bouton wifi, il ne s'allume pas.
ModérateurPeux-tu nous copier-coller le résultat des commandes suivantes, à taper dans un terminal :
http://doc.ubuntu-fr.org/terminal
/sbin/iwconfig /sbin/iwlist scan lspci
Bonne chance -
merci beaucoup
voila donc la copie du terminal
eth0 no wireless extensions.
lutin@lutin-Presario-C500-GF855EA-ABF ~ $ /sbin/iwlist scan
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
lutin@lutin-Presario-C500-GF855EA-ABF ~ $ lspci
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7-M Family) SATA Controller [AHCI mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
06:00.0 Network controller: Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01)
08:08.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
encore merci -
ContributeurSalut,
Au choix :
http://ubuntuforums.org/showthread.php?t=1904233&p=11586158#post11586158
http://doc.ubuntu-fr.org/bcm4328#usage_du_driver_broadcom
merci beaucoup pour cette reponse
je vais essayer ça demain apres midi, et j'envoie le retour
bonne soiree -
bonsoir.
super! grâce a vous la solution est venue!
je connaissais un peu linux, mais la ligne de commande n'est pas mon fort.
grand merci -
alors, je me suis réintallé ubuntu 13.04, et j'ai tape les commandes suivantes:
sudo apt-get remove - purge bcmwl-kernel-source
et:sudo apt-get install linux-firmware-non free
et reboot
bonne soirée et merci encore
