Bluescreen tout le temps
Mon ordinateur ne cesse de s'éteindre en m'affichant des Bluescreens.
  1. Avec Whocrashed voici le résultat :
    On Wed 29/08/2012 13:05:59 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\082912-27830-01.dmp
    This was probably caused by the following module: ntkrnlpa.exe (nt+0x4682B)
    Bugcheck code: 0xA (0xFFFFFFFF839FFFE4, 0x2, 0x1, 0xFFFFFFFF82899D2E)
    Error: IRQL_NOT_LESS_OR_EQUAL
    file path: C:\Windows\system32\ntkrnlpa.exe
    product: Microsoft® Windows® Operating System
    company: Microsoft Corporation
    description: NT Kernel & System
    Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
    This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
    The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
    On Wed 29/08/2012 13:01:34 GMT your computer crashed
    crash dump file: C:\Windows\Minidump\082912-34772-01.dmp
    Bugcheck code: 0xA (0xFFFFFFFFC39FFFEC, 0x2, 0x1, 0xFFFFFFFF828D8338)
