Error in your SQL syntax...help!
Voici l'erreur que j'ai:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '?-- phpMyAdmin SQL Dump
-- version 3.1.3.1
-- http://www.phpmy
Que dois-je faire?
Merci!
CC
-- version 3.1.3.1
-- http://www.phpmy
Que dois-je faire?
Merci!
CC
