Mabezat solution
Bonjour,voici ce que j ai dans mon ordinateur et j espere bien trouver une solution svp
Scan saved at 14:31:07, on 15/11/2009
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Faronics\Deep Freeze\Install C-0\DF5Serv.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\DHTray.exe
C:\WINDOWS\system32\A0380mon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Documents and Settings\tazebama.dl_
C:\Program Files\Internet Mobile+\Internet Mobile+.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Favoris
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_06\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O4 - HKLM\..\Run: [DHTray] C:\WINDOWS\system32\DHTray.exe
O4 - HKLM\..\Run: [A0380monitor] C:\WINDOWS\system32\A0380mon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKUS\S-1-5-19\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-18\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'Default user')
O4 - Startup: is-1OI6L.lnk = C:\Documents and Settings\ouaadidy abdou\Bureau\Virus Removal Tool\is-1OI6L\startup.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_06\bin\ssv.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O17 - HKLM\System\CCS\Services\Tcpip\..\{B1725C4E-14A7-4A78-A186-A446F04233C1}: NameServer = 194.25.0.68 154.15.199.142
O20 - Winlogon Notify: DfLogon - C:\WINDOWS\SYSTEM32\LogonDll.dll
O23 - Service: DF5Serv - Faronics Corporation - C:\Program Files\Faronics\Deep Freeze\Install C-0\DF5Serv.exe
End of file - 2934 bytes
  1. Salut,
    Essaie cela : http://www.commentcamarche.net/faq/sujet-16138-comment-supprimer-virut
    1. Salut ,
      • Télécharge UsbFix sur ton bureau .
      (!) Branche tes sources de données externes à ton PC, (clé USB, disque dur externe, etc...) susceptible d avoir été infectés sans les ouvrir
      • Double clic sur "UsbFix.exe" présent sur ton bureau .
      • Choisis l' option F pour français et et tape sur [entrée] .
      • choisis l'option 2 ( Suppression ) et tape sur [entrée].
      • Ton bureau disparaitra et le pc redémarrera .
      • Au redémarrage , UsbFix scannera ton pc , laisse travailler l'outil.
      • Ensuite post le rapport UsbFix.txt qui apparaitra avec le bureau .
      • Note : Le rapport UsbFix.txt est sauvegardé a la racine du disque.( C:\UsbFix.txt )
      ( CTRL+A Pour tout selectionner , CTRL+C pour copier et CTRL+V pour coller )
