J arrive pas a lancer wolfenstein help
je voudrais lancer le jeux mais quand je clik dessus t bien o debut il y a une petite fenetre ou il y a ecrit et console et o millieux il y a ecrit des truc et apres l ecran est tut noir quel secoind apres environ 4 ou 5 et bien il y a la mem fenetre quao debut j y comprend rien aide moi
bonjour j ai pas compris et svp commencer votre mesage pars bonjours ou salut mer
disable L'open GL:)
je vous ecrit ce quil y a ecrit dessus
ET 2.55 win-x86 May 27 2003
----- FS_Startup -----
Current search path:
C:\PROGRA~1\WOLFEN~1\etmain\pak0.pk3 (3725 files)
C:\PROGRA~1\WOLFEN~1\etmain\mp_bin.pk3 (4 files)
C:\PROGRA~1\WOLFEN~1/etmain
3729 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
aider moi s il vous plait je sait pas quoi faire sos et tout en bha ya 3 bouton copier clear et quit quesque je doit faire
