Problem require_once en zend framework
bonjour à tous , je viens d'installer zend framework mais j'ai rencontré le problème qui s'affiche dans la photo
si il y a quelqu'un peut me aider et merci d'avance
  1. <?php
     * Zend Framework
     * LICENSE
     * This source file is subject to the new BSD license that is bundled
     * with this package in the file LICENSE.txt.
     * It is also available through the world-wide-web at this URL:
     * [http://framework.zend.com/license/new-bsd]
     * If you did not receive a copy of the license and are unable to
     * obtain it through the world-wide-web, please send an email
     * to license@zend.com so we can send you a copy immediately.
     * @category   Zend
     * @package    Zend_Application
     * @copyright  Copyright (c) 2005-2010 Zend Technologies USA Inc. ([http://www.zend.com)]
     * @license    [http://framework.zend.com/license/new-bsd]     New BSD License
     * @version    $Id: Application.php 20096 2010-01-06 02:05:09Z bkarwin $
     * @category   Zend
    class Zend_Application
         * Autoloader to use
         * @var Zend_Loader_Autoloader
        protected $_autoloader;
         * Bootstrap
         * @var Zend_Application_Bootstrap_BootstrapAbstract
        protected $_bootstrap;
         * Application environment
         * @var string
        protected $_environment;
         * Flattened (lowercase) option keys
         * @var array
        protected $_optionKeys = array();
         * Options for Zend_Application
         * @var array
        protected $_options = array();
         * Constructor
         * Initialize application. Potentially initializes include_paths, PHP
         * settings, and bootstrap class.
         * @param  string                   $environment
         * @param  string|array|Zend_Config $options String path to configuration file, or array/Zend_Config of configuration options
         * @throws Zend_Application_Exception When invalid options are provided
         * @return void
        public function __construct($environment, $options = null)
            $this->_environment = (string) $environment;
            require_once 'Zend/Loader/Autoloader.php';
            $this->_autoloader = Zend_Loader_Autoloader::getInstance();
            if (null !== $options) {
                if (is_string($options)) {
                    $options = $this->_loadConfig($options);
                } elseif ($options instanceof Zend_Config) {
                    $options = $options->toArray();
                } elseif (!is_array($options)) {
                    throw new Zend_Application_Exception('Invalid options provided; must be location of config file, a config object, or an array');
                $this->setOptions($options);
         * Retrieve current environment
         * @return string
        public function getEnvironment()
            return $this->_environment;
         * Retrieve autoloader instance
         * @return Zend_Loader_Autoloader
        public function getAutoloader()
            return $this->_autoloader;
         * Set application options
         * @param  array $options
         * @throws Zend_Application_Exception When no bootstrap path is provided
         * @throws Zend_Application_Exception When invalid bootstrap information are provided
         * @return Zend_Application
        public function setOptions(array $options)
            if (!empty($options['config'])) {
                if (is_array($options['config'])) {
                    foreach ($options['config'] as $tmp) {
                        $_options = $this->mergeOptions($_options, $this->_loadConfig($tmp));
                    $options = $this->mergeOptions($_options, $options);
                } else {
                    $options = $this->mergeOptions($this->_loadConfig($options['config']), $options);
            $this->_options = $options;
            $options = array_change_key_case($options, CASE_LOWER);
            $this->_optionKeys = array_keys($options);
            if (!empty($options['phpsettings'])) {
                $this->setPhpSettings($options['phpsettings']);
            if (!empty($options['includepaths'])) {
                $this->setIncludePaths($options['includepaths']);
            if (!empty($options['autoloadernamespaces'])) {
                $this->setAutoloaderNamespaces($options['autoloadernamespaces']);
            if (!empty($options['autoloaderzfpath'])) {
                $autoloader = $this->getAutoloader();
                if (method_exists($autoloader, 'setZfPath')) {
                    $zfPath    = $options['autoloaderzfpath'];
                    $zfVersion = !empty($options['autoloaderzfversion'])
                               ? $options['autoloaderzfversion']
                               : 'latest';
                    $autoloader->setZfPath($zfPath, $zfVersion);
            if (!empty($options['bootstrap'])) {
                $bootstrap = $options['bootstrap'];
                if (is_string($bootstrap)) {
                    $this->setBootstrap($bootstrap);
                } elseif (is_array($bootstrap)) {
                    if (empty($bootstrap['path'])) {
                        throw new Zend_Application_Exception('No bootstrap path provided');
                    $path  = $bootstrap['path'];
                    $class = null;
                    if (!empty($bootstrap['class'])) {
                        $class = $bootstrap['class'];
                    $this->setBootstrap($path, $class);
                } else {
                    throw new Zend_Application_Exception('Invalid bootstrap information provided');
            return $this;
         * Retrieve application options (for caching)
         * @return array
        public function getOptions()
            return $this->_options;
         * Is an option present?
         * @param  string $key
         * @return bool
        public function hasOption($key)
            return in_array(strtolower($key), $this->_optionKeys);
         * Retrieve a single option
         * @return mixed
        public function getOption($key)
            if ($this->hasOption($key)) {
                $options = $this->getOptions();
                return $options[strtolower($key)];
            return null;
         * Merge options recursively
         * @param  array $array1
         * @param  mixed $array2
         * @return array
        public function mergeOptions(array $array1, $array2 = null)
            if (is_array($array2)) {
                foreach ($array2 as $key => $val) {
                    if (is_array($array2[$key])) {
                        $array1[$key] = (array_key_exists($key, $array1) && is_array($array1[$key]))
                                      ? $this->mergeOptions($array1[$key], $array2[$key])
                                      : $array2[$key];
                    } else {
                        $array1[$key] = $val;
            return $array1;
         * Set PHP configuration settings
         * @param  array $settings
         * @param  string $prefix Key prefix to prepend to array values (used to map . separated INI values)
        public function setPhpSettings(array $settings, $prefix = '')
            foreach ($settings as $key => $value) {
                $key = empty($prefix) ? $key : $prefix . $key;
                if (is_scalar($value)) {
                    ini_set($key, $value);
                } elseif (is_array($value)) {
                    $this->setPhpSettings($value, $key . '.');
            return $this;
         * Set include path
         * @param  array $paths
        public function setIncludePaths(array $paths)
            $path = implode(PATH_SEPARATOR, $paths);
            set_include_path($path . PATH_SEPARATOR . get_include_path());
            return $this;
         * Set autoloader namespaces
         * @param  array $namespaces
        public function setAutoloaderNamespaces(array $namespaces)
            foreach ($namespaces as $namespace) {
                $autoloader->registerNamespace($namespace);
            return $this;
         * Set bootstrap path/class
         * @param  string $path
         * @param  string $class
        public function setBootstrap($path, $class = null)
            // setOptions() can potentially send a null value; specify default
            // here
            if (null === $class) {
                $class = 'Bootstrap';
            if (!class_exists($class, false)) {
                require_once $path;
                    throw new Zend_Application_Exception('Bootstrap class not found');
            $this->_bootstrap = new $class($this);
            if (!$this->_bootstrap instanceof Zend_Application_Bootstrap_Bootstrapper) {
                throw new Zend_Application_Exception('Bootstrap class does not implement Zend_Application_Bootstrap_Bootstrapper');
            return $this;
         * Get bootstrap object
         * @return Zend_Application_Bootstrap_BootstrapAbstract
        public function getBootstrap()
            if (null === $this->_bootstrap) {
                $this->_bootstrap = new Zend_Application_Bootstrap_Bootstrap($this);
            return $this->_bootstrap;
         * Bootstrap application
         * @param  null|string|array $resource
        public function bootstrap($resource = null)
            $this->getBootstrap()->bootstrap($resource);
            return $this;
         * Run the application
         * @return void
        public function run()
            $this->getBootstrap()->run();
         * Load configuration file of options
         * @param  string $file
         * @throws Zend_Application_Exception When invalid configuration file is provided
         * @return array
        protected function _loadConfig($file)
            $environment = $this->getEnvironment();
            $suffix      = strtolower(pathinfo($file, PATHINFO_EXTENSION));
            switch ($suffix) {
                case 'ini':
                    $config = new Zend_Config_Ini($file, $environment);
                    break;
                case 'xml':
                    $config = new Zend_Config_Xml($file, $environment);
                    break;
                case 'php':
                case 'inc':
                    $config = include $file;
                    if (!is_array($config)) {
                        throw new Zend_Application_Exception('Invalid configuration file provided; PHP file does not return array value');
                    return $config;
                    break;
                default:
                    throw new Zend_Application_Exception('Invalid configuration file provided; unknown config type');
            return $config->toArray();
    1. Il faudrait aussi le /public/index.php.
      PS: oublie pas la coloration syntaxique merci.
