Audio issue with SCART cable
NicoDarko
Eyael -
Eyael -
Hello,
I have a sound issue with my Schneider SDV 439 DVD player. There are imperfections, a sort of faint growling in the background, very slight but enough to be annoying.
It apparently comes from the Scart connection... because I connected it with three cables (digital, three colors, I don't know what that's called) and there was no more problem (but the picture is worse).
It doesn't come from the scarts either, since I've tried three different ones... so I'm wondering if it comes from the Scart socket on the TV or from the one on the DVD player... it's very difficult to tell, since the problem doesn't show up right away.
Do you have any idea what the cause might be?
Thank you.
Thank you.
Configuration: Windows XP Firefox 3.0.4
Have you solved your problem? Because I have exactly the same thing. When I connect my DVD player to my sound system, I no longer have that kind of buzzing noise sometimes. I think it comes from the SCART cables because I have the same issue with TV shows when I watch them with my TNT decoder. Likewise, if I connect the TNT decoder to the sound system, there’s no more hissing or buzzing noise.
Digital output: off, PCM, all (I've set it to all)
Night mode: off
Subsampling: on
I don't see what other settings there are.
