Problem with the 8 on keyboard
monick88
Posted messages
7
Status
Member
billy 182 -
billy 182 -
Hello, I bought a Logitech wireless keyboard and mouse, the problem is that I cannot find the underscore under the 8, what should I do? Thank you and best regards
Configuration: Mac OS X TIGER Internet Explorer 5.23
It's normal that there isn't an underscore (which is called underscore), look, here's a keyboard like yours: http://www.anaonlinemarket.com/nz/images/products/51349.jpg
The key for underscore is to the right of the 0
With XP we were on the edge of the abyss...
With Vista, we're making a big leap forward! ^^ -
What is your keyboard model?
Life is worth nothing, but nothing is worth life.
Not long ago, I was pretentious, now I am perfect. ^^ -
Well, I think you have a problem with your keyboard. Try changing it to see. To troubleshoot, go to Start, then Run, type this command: osk, and a visual keyboard will appear where you can find the underscore ( _ ) on 8 that you're looking for. Bye!
