Pentax ist DL Power On Issue
nadg -
 Ba2ghera -
Hello,
I have a problem with my PENTAX IST DL camera: after changing the batteries, when I turned the camera back on, the battery light keeps blinking "no batteries," and since then I haven't been able to turn on my camera.
Has anyone else had this problem?
What should I do?
Thank you for your advice.
  1. Ba2ghera
    Hello,
    I just encountered this problem and I searched the forums. In my case, it’s not due to an internal battery (there isn’t one), nor is it a problem with the Eneloop (my *ist has always worked with any battery). I have the (bad?) habit of always removing the batteries from my device when I’m not using it: so I emptied the internal memory. I attempted the last-ditch effort: put in batteries and, most importantly, leave them in! I turned it on from time to time to check and after a few hours: miracle of technology: it’s working again!!!!
    It’s definitely worth trying before any disassembly or sending it to customer service!
    Yours photographically!
    10
  2. kanaille
    Hi,
    I’m currently having the same problem as you. Were you able to solve it? And how?
    Thanks for your help
    (I also use alkaline batteries)
    2
    1. Martial
      Hello everyone!
      I'm experiencing the same issue and after several searches on different forums, it seems there's no answer...
      In any case, it doesn't seem to come from the batteries or rechargeable batteries.
      I've done several "tests" with different "quality of batteries" (both expensive and inexpensive, rechargeable or not) and the result is the same :(
      If anyone finds any information one of these days, please pass it on... ;)
      Have a nice day!
      1. Alain > Martial
        Hello everyone,
        I am experiencing exactly the same problem.
        Like you, I have tried everything: batteries, power sources... but the result remains the same: the "empty" light is flashing.
        If anyone has a lead, thank you in advance.
    2. Maouii
      the same.. :(
  3. <ji<bi
    I'll take it apart, but it doesn't seem obvious to me. And a little patience! I just got the optician's screwdrivers and mini-torx.... Well, I just received the IST DL2 I ordered as a replacement (necessary for taking photos!!!). Does anyone know if, basically, there are any differences in settings between the DL and the DL2? I only have the manual for the DL....
  4. BTO Posted messages 46 Status Member 9
    Hello friend,
    Do you use saline or alkaline batteries? In the first case, replace them with alkaline ones; they are more "durable."
    If you are using rechargeable batteries supplied for the device, make sure they are indeed original batteries or from the "manufacturer" brand.
    I advise against "cheap exotic rechargeable batteries..." because if they are cheap, it's because:
    - They have a shorter lifespan, much shorter than those from the manufacturer.
    - They overheat much more than those from the brand.
    - There is a risk of overheating, even "exploding," with low-quality batteries, so be careful!
    Finally, it should be noted that if they are rechargeable batteries, when the charging indicator shows a "green light," it means that the charge is about 80% full for some of them; You should "continue" charging for a while on "trickle charge" to achieve optimal charging.
    Practical detail if you are using your built-in flash, it "consumes" a lot of energy as well, and you will therefore quickly deplete your "batteries"; the same goes for rechargeable batteries, the phenomenon is the same.
    Finally, if the "problem" persists with new rechargeable batteries or new alkaline batteries, seek advice from your brand retailer. You can also visit a specialized photography community site:
    https://www.virusphoto.com/
    http://www.absolut-photo.com/
    http://www.pentaxiste.org/spip.php?article76
    1. nadg
      Thank you for your response,
      I use alkaline batteries (low-end), and the problem occurred when I replaced them with new ones: they were completely new...
      I will try to buy another type of battery to see, but I remain puzzled...
  5. fred
    change the lithium battery of the internal memory
  6. glouglou200
    Hello,
    how do you change the lithium battery of the internal memory??
  7. JiBi
    Glouglou 200 is right. All the parameters (time, settings, ...) are stored in a small permanent INTERNAL memory within the device. This explains why you find your settings back after changing the batteries of the device. I am an amateur electronics enthusiast. This problem just happened to me. I unscrewed a few screws from the bottom of the case, but I wasn't able to unscrew them all. It must be a button cell type, like the ones found in watches. 3V is more than enough for a CMOS memory... As soon as I take off the bottom, I'll take the photos... I promise.
    1. &lt;ji&lt;bi
      Almost impossible to dismantle!!! Too many special tools (imprints,.....
      ; <I'm doing what I can or I'll have to "smash it" completely.
  8. gabelou
    Hello
    and the photo report?
    Thank you for this debate which concerns me as well.
  9. Tompi57 Posted messages 11 Status Member 1
    I have the same problem as you... I wonder if there is a grid for the IST?
