System fan has failed startup error
power-noob Posted messages 2 Status Member -
 dom -
Hello,
At startup of my computer, I get "error system fan has failed!" :(
My power supply had a problem and prevented the startup (that's what I think, it was emitting ultrasonic sounds) I changed it and now I can start and see the boot choice page, but after 5 seconds
pc will be automatically powered down in a few seconds
service pc immediately to prevent damage to the system
and SHUTTING DOWN :((((((((((((((((((((((((((((((((((((((((((((
Anyway, this is annoying me, if anyone has a solution or knows where it comes from ^^
  1. jmber Posted messages 2067 Registration date   Status Contributor Last intervention   680
    Good evening, according to the error you provided: "error system fan has failed!", the word FAN means fan, so look into that area...
    @+jmber
    Mutual assistance is valuable.
    5
  2. jmp59 Posted messages 29286 Registration date   Status Contributor Last intervention   6 349
    Hello,
    If you haven't touched the CPU-cooler assembly, you probably forgot to reconnect something.
    The CPU fan isn't running, and luckily everything stops to prevent burning out the processor.
    Check your connections!
    To err is human, to persist is diabolical.
  3. jmp59 Posted messages 29286 Registration date   Status Contributor Last intervention   6 349
    Are you sure you have correctly configured the jumpers on your motherboard (see the manual), especially the ClearCMOS jumper, which is often set to save the battery as long as the motherboard is not powered on?
  4. jmp59 Posted messages 29286 Registration date   Status Contributor Last intervention   6 349
    Have you checked all your connections, including those you haven't touched? When reconnecting the power supply, it's possible that you moved some connectors that are no longer fully seated.
    In particular, the CPU cooler; it spins, but its rotation might not be transmitted to the motherboard.
  5. dom
    I have the same problem after the format, it continues and all my fans seem to be working fine.
  6. mimouton Posted messages 360 Status Member 24
    tu n'as pas le choix, il faut désinstaller Windows et il faut le réinstaller.
  7. power-noob Posted messages 2 Status Member
    The problem is that my fans are working, I cleaned the heatsink but it doesn't change anything :(((
    So I don't know, and I don't think it's possible to reinstall Windows since it shuts down before the boot CD, so it's not even worth it :(((((((((((((((((((((((((((((((((((((((((((((((((((((((
  8. power-noob
    I haven't touched the motherboard, so it can't be that
    but is it possible that it could be my dead battery?
    1. jmp59 Posted messages 29286 Registration date   Status Contributor Last intervention   6 349
      Sorry. Forget post 5. It wasn't meant for you. Mistake!
      And the dead battery doesn't have those symptoms at all.
