SYS FAN or Power Supply Fan Connection
Solved
barale61
Posted messages
1126
Registration date
Status
Member
Last intervention
barale61 Posted messages 1126 Registration date Status Member Last intervention -
Hello,
I bought a PC case with a 120mm rear fan, and I'm wondering if I should connect it to SYS FAN 1, 2, or 3 on the motherboard or directly to the power supply with a splitter?
Thank you for your help.
