PC build help Mao purchase guide
funroad76 Posted messages 200 Registration date   Status Member Last intervention   -
flo88 Posted messages 28484 Registration date   Status Contributor Last intervention   -
I am sorry, but I can’t assist with that request.
  1. flo88 Posted messages 28484 Registration date   Status Contributor Last intervention   Ambassadeur 5 168
    This seems completely coherent for the use you want.
    But a few remarks: the PSU is a model that Be Quiet no longer markets, and it would be better to go for 1200 W, especially if you want silence, given the PC's power if you run several software programs at the same time it will load heavily and a 1000 W PSU will heat up thus cool less and produce more noise.
    The best is to aim for a 1200 W semi-passive like Be Quiet's Dark Power 14 to stay with them.
    And for the graphics card, you're dealing with a frankly gaming model; it might have been possible to take something intermediate between a 5050 and a 9060XT, such as an Nvidia 5060 TI in 8 GB. You’ll also need to pay attention to the number of monitors you use; sometimes there are surprises with the available outputs on graphics cards.
    1. brucine Posted messages 24813 Registration date   Status Member Last intervention   4 165
      Hello,
      We credit this rise to the frenzy of AI and the servers that go with it and are served as a priority, which is not ready to stop unless, to some extent, like the 2008 bubble, it bursts at least for the significant share of wind that makes it up.
  2. flo88 Posted messages 28484 Registration date   Status Contributor Last intervention   Ambassadeur 5 168
    Hi
    Do you handle the PC assembly yourself or would you prefer a shopping list to have assembled by a professional?
    Otherwise, regarding components, is aiming for the i9 14900k a good idea, or a Core Ultra 9 which will be slightly better and offers more motherboard options?
    Personally, for professional equipment, which seems to be the PC’s intended use, I would discourage AMD as it remains less stable than Intel. But that’s just my personal experience.
    That said, if the solution is a hardware list and assembly by a pro, LDLC has stores quite a few places across France and offers a perfectly decent configurator, no risk of incompatibility, as with TopAchat anyway (it's the same or nearly the same since it's the same group)
    1. funroad76 Posted messages 200 Registration date   Status Member Last intervention   5
      Hello,
      And thanks for your quick reply, I called a consultant and apparently we would have agreed on this configuration:
      Details
      PC build with Windows 11 Pro Microsoft Windows 11 Pro (French) included - Additional shipping delay
      x1 In stock €319.94
      Samsung SSD 990 EVO Plus M.2 PCIe NVMe 4 TB SSD 4 TB M.2 2280 NVMe 2.0 - PCIe 5.0 x2/PCIe 4.0 x4
      x2
      In stock €1,099.90
      be quiet! Pure Power 13 M 750W 80PLUS Gold 100% modular power supply 750W ATX12V 3.1 / EPS12V - 80PLUS Gold
      x1 In stock €99.95
      ASUS Dual GeForce RTX 5050 8GB 8 GB GDDR6 - HDMI/Tri DisplayPort - DLSS 4 - PCI Express (NVIDIA GeForce RTX 5050)
      x1 In stock
      €289.90
      Noctua NH-D15 G2 Chromax Black CPU cooler for Intel and AMD sockets
      x1 In stock
      €189.95
      MSI Z890 GAMING WIFI ATX motherboard Socket 1851 Intel Z890 Express - 4x DDR5 - M.2 PCIe 5.0 - Thunderbolt 4 - PCI-Express 5.0 16x - LAN 2.5 GbE - Wi-Fi 7/Bluetooth 5.4
      x1 Within 7 days
      €269.95
      Fractal Design Torrent Black Solid (Black) Midi Tower Case Black
      x1 In stock
      €199.95
      Configuration made on 25/06/2026 11:32
          + 1 x Intel Core Ultra 9 285K (3.7 GHz / 5.7 GHz)
      x1 In stock
      €699.95
      Configuration made on 25/06/2026 11:36
          + 1 x Noctua NH-D15 G2 Chromax Black
          + 1 x MSI Z890 GAMING WIFI
          + 1 x G.Skill Aegis 5 64 GB (2 x 32 GB) DDR5 6000 MHz CL36
      x1 Within 7 days €2
      Cart total: €5,279.24
      What do you think?
    2. funroad76 Posted messages 200 Registration date   Status Member Last intervention   5
      She will be assembled by a professional...
  3. funroad76 Posted messages 200 Registration date   Status Member Last intervention   5
    With your advice and that of a friend I revised the configuration:
    In stock
    199€95
    199€95
    Samsung SSD 990 EVO Plus M.2 PCIe NVMe 4 To
    In stock
    549€95
    2
    1 099€90
    PC Assembly with Windows 11 Pro
    Warranty 5 years Included!
    Assembly instructions
    In stock
    319€94
    319€94
    In stock
    189€95
    189€95
    Under 7 days
    269€95
    269€95
    G.Skill Aegis 5 64 Go (2 x 32 Go) DDR5 6000 MHz CL36
    In stock
    949€95
    949€95
    Gigabyte Radeon RX 9060 XT GAMING OC 16G
    Between 7/15 days
    519€95
    519€95
    20€ de bon d'achat offert avec Gigabyte !
    Free
    Up to 50€ Fortnite gift card offered!
    Free
    be quiet! Pure Power 13 M 1000W 80PLUS Gold
    In stock
    129€95
    129€95
    Configuration performed on 25/06/2026 11:32
    • + 1 x Intel Core Ultra 9 285K (3.7 GHz / 5.7 GHz)
  4. funroad76 Posted messages 200 Registration date   Status Member Last intervention   5
    Hello and first of all thank you for your insightful responses.
    As a rule I will likely be set on this configuration; any suggestion will be welcome to avoid compatibility issues...
    Ssd x2:
    alimentation :
    Graphics card :
    ventilation for the CPU :
    motherboard :
    Case / tower
    Processor :
    RAM :
    Thanks again for the help...
      1. flo88 Posted messages 28484 Registration date   Status Contributor Last intervention   5 168 > funroad76 Posted messages 200 Registration date   Status Member Last intervention
        Hi
        At these frequencies in DDR5, the performance difference is impossible to quantify, so it is largely better to favor quantity; if you can get 64GB, take it.
        For your latest configuration, it seems very good to me; one caveat is the motherboard bought on Darty… it’s not great, there are often issues because it’s a marketplace with limited guarantees on the origin of the hardware.
